Need help - JeepForum.com
post #1 of 6 Old 05-25-2013, 10:49 AM Thread Starter
Jeepzeroone
Need help
2008 sport manual..
When driving home wed, i turned up the hill to my house and it started making a loud odd sound.
It is kind of like the sound you get if you were to be two gears to high.
clutch felt fine give it gas and the sound was still there but it accelerates just fine.
Next day on my way to work nothing it sounds runs great.
on my way home i turn the corner and same sound.
Today i take it for a hour drive, it seems i get the sound when going up hill.
The steeper the hill the louder it is.
Anyone one have any idea?
Ill take it to the dealer ship but i know it wont make it for them.
Jeepzeroone is offline
post #2 of 6 Old 05-25-2013, 11:32 AM
222Doc
222Doc's Avatar
sounds like Pinging/predetination.
222Doc is offline
post #3 of 6 Old 05-25-2013, 11:47 AM Thread Starter
Jeepzeroone
Dont think its in the motor, run the RPM up to 4k sitting still and it sound fine.
almost a clunking sounds but thats not right.
post #4 of 6 Old 05-25-2013, 12:04 PM
choppachris
I'd check lug nuts on the wheels first, i've had wheels loosen up unexpectedly. If they are tight, i'd jack up each corner and check for excessive play in the rotating assembly. Hope you get it figured out, good luck!
choppachris is offline
post #5 of 6 Old 05-26-2013, 03:22 PM
thedirtman
thedirtman's Avatar
I would check the caliper bolts as well if you have had them off recently. I have seen them work loose if not torqued down properly.
If you learned something new today, you had a good day.
thedirtman is offline
post #6 of 6 Old 05-26-2013, 03:32 PM
Apostle
How many miles? Id start with the plugs.
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline
