Need help - JeepForum.com
post #1 of 4 Old 04-18-2013, 02:54 PM Thread Starter
jbro27
Need help
I recently got 35 Nitto Mud Grapplers and 4 inch Rough Country lift. The tires are rubbing on the rear sway bar. I have the stock wheels on so would I be okay once I get new wheels?
2doorJK 07
2 door 07 JK
35' Nitto Mud Grapplers
4" Rough Country Suspension Lift
jbro27 is offline
post #2 of 4 Old 04-18-2013, 03:02 PM
PanthersFan
2doorJK 07
You have a couple of options:
1) Wheel spacers with existing wheels
2) Remove the rear sway bar (some people like it, some don't).
3) new Wheels with the right back spacing for your tire size. Check out the sticky called "will it rub"
THE Conventions of a number of the States, having at the time of their adopting the Constitution, expressed a desire, in order to prevent misconstruction or abuse of its powers, that further declaratory and restrictive clauses should be added: And as extending the ground of public confidence in the Government, will best ensure the beneficent ends of its institution.
PanthersFan is offline
post #3 of 4 Old 04-18-2013, 03:25 PM Thread Starter
jbro27
If you look at it it says I should be good but these tires have fat tread on the inside of the tire. Which is causing the rub on the sway bar.
2 door 07 JK
jbro27 is offline
post #4 of 4 Old 04-19-2013, 08:12 AM
KrawlOff-Road
Vendor
KrawlOff-Road's Avatar
http://www.krawloff-road.com/product_p/sptx-1.5.htm
This would be your best bet to push the wheels out to give you the clearance you need. The Nitto Mud's have a LOT of tread on the side wall!
-Jason
Phone: 864-437-8029
Forum Discount: KORJEEPFORUM
KrawlOff-Road is offline
