Need Gear/Axle HELP ASAP - Page 2 - JeepForum.com
post #16 of 20 Old 07-22-2010, 12:42 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
I would have to blame the installation!
If those are "Superior Gears" it's highly doubtful they were faulty.
Jim
JLC08JK is offline
post #17 of 20 Old 07-22-2010, 12:43 AM
Warlord2
I would make sure that nut is on the rear is tight, it should be torqued to at very least 170lbs and the flange should have very little, if any movement. I had to use around 210lbs to get mine back to spec. Also make sure they used the red (perma)? lock-tight
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #18 of 20 Old 07-22-2010, 12:45 AM Thread Starter
AFhockey31
2009 JK Wrangler
Thanks for that info. Im going to check this weekend when I get some free time..
Originally Posted by Toms87 View Post
Obviously the kid got farted on by the horse and then the duck pooped out an apple.
2009 Wrangler. XRC 10 winch
RE 3.5" basic lift. Poison Spyder Rockbrawler bumper
35x12.5 KM2. Poison Spyder Rockerknockers
Crager soft 8's. PS diff and evap skids
Bilstein 5100's. Light force 170's
KC Slimlights
AFhockey31 is offline
post #19 of 20 Old 07-22-2010, 10:56 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
"I did in fact... I was only charged 200 for front and rear install, plus lockers."
Sorry to say this in retrospect - you got what you paid for...when the going rate for install labor, gears and master install kit is running around 700 to 1000 per axle...a red flag should have gone up. Something has to give, or as they say, "When it sounds too good to be true, it probably is."
Truly sorry you have to go through this, but please let others use this as a learning tool and not as a bash to you. The photos show the picture of what can happen with a bad install because the gears are probably not the cause of this, bad preload, reuse of crush sleeve, improper torque or improper shimming might be, I am not a qualified forensic mechanic...hope all goes well and you get back on the trail again soon! Keep us posted...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #20 of 20 Old 07-23-2010, 12:57 AM Thread Starter
AFhockey31
2009 JK Wrangler
The guy normally charges a lot more. It was a friend of my buddies back in SA so he gave me a hook up since he wasnt doing anything. I dunno... at this point I can blame everything and nothing. All I know is I have to order some new gears, and hopefully not a new locker...
Ill be working on it quick cause winter is right around the corner to not have 4wd up here lol
KC Slimlights
front axle problem , front differential , front drive shaft , front end clunk , front end noise , JK Wrangler , wrangler
i need an axle!!!!!!!!!asap legend6009 TJ Wrangler Technical Forum 25 04-04-2008 02:27 PM
Gear oil mixing? Need info ASAP 06WranglerX TJ Wrangler Technical Forum 12 09-22-2007 12:38 PM
Need help with gear info asap SteelBlueTJ TJ Wrangler Technical Forum 2 08-03-2006 06:50 PM
Speedo Gear Help Asap Please!! GA TJ TJ Wrangler Technical Forum 5 10-11-2005 11:42 PM
Fifth Gear Question..please help... need to know asap Antelope YJ Wrangler Technical Forum 11 07-11-2005 10:12 AM
