Need a bigger tire please - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Need a bigger tire please
Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955XHD Heavy-Duty Hood Latches for JK and TJ available at OcoFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-10-2014, 01:13 PM   #1
Mitch72
Hello all,
I need to upgrade my brother's 2013 wrangler (4 doors) tires to a bigger ones without lifting his wrangler. what is the maximum tires size that he can install without lifting his wrangler?
stock tires
245/75 R17 after I convert it -----> 31.5 x 9.7 R17
Also, do I need to regear or other modification?
many thanks
p.s I did the same thing to my 2001 tj, and love it.
Mitch72 is offline   Reply With Quote
Unread 09-10-2014, 01:16 PM   #2
rirrgang
Check Tirerack.com. They have a tire calculator for plus sizes
-Rick
07 Sahara Unlimited
rirrgang is offline   Reply With Quote
Unread 09-10-2014, 01:19 PM   #3
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
The largest a JK/JKU can accommodate w/o a lift is 35".
I wouldn't take it off-road like that however.
If it is strictly for street looks, install a 2" spacer lift and be done with it.
I hear the 3.6L does not need a regear until you get over 35" tires.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel lift, Fox 2.0 shocks, 37" Nittos, 5.38's, River Raider skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Re-inventing the circle and straight line.
HappyTrails is offline   Reply With Quote
Unread 09-10-2014, 01:29 PM   #4
Mitch72
thanks
He gonna use it for mild off road,..
so, he better install 35" on 17" rims ?
Unread 09-10-2014, 01:30 PM   #5
HappyTrails
That's what I'd do, 35" tires, 17" wheels.
If just mild off-road, just go with the 2" spacer lift and call it a day.
Unread 09-10-2014, 07:58 PM   #6
Jodyblip
35s with no lift is gonna look not good
Jodyblip is offline   Reply With Quote
Unread 09-10-2014, 10:36 PM   #7
Kdailey13
2011 JK Wrangler
In my opinion, if you have no plans to alter the suspension at all, i would go with 33s. Fills up the wheel well and gives the jeep some legs, but still gives you enough travel and capability to do what you would like on a mild off road trail. As far as tires goes i recommend a set of 33x12.5 goodyear duratracs or mt/r with kevlar. With that tire size and a 4.5" back spacing on your rims it will give you a stanced look without rubbing. Keep the thread updated, love to see what you decide to do. I hope i helped out at least a little bit.
Kdailey13 is offline   Reply With Quote
Unread 09-11-2014, 07:12 AM   #8
JIMBOX
You don't "NEED" to do anything-
Originally Posted by Mitch72 View Post
Hello all,
stock tires
many thanks
Have your brother join the Forum-
If/when he has questions--he'll ask
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote
Unread 09-11-2014, 08:23 AM   #9
VTJay
2010 JK Wrangler
Your opinion, I have 35's with no lift and trimmed fenders and love the look.
VTJay is offline   Reply With Quote
Unread 09-11-2014, 08:29 AM   #10
JIMBOX
Curiosity-
Do you get "rubbing"/interference/hit fenders-got any pics??
Do you takeit off-road??
Do you have spacers??
JIMBO
Yellow Jeep No. 683
Unread 09-11-2014, 08:36 AM   #11
duneslider
I am curious about some of this too.
I bought my 33's originally while I was waiting for my lift to arrive and on road the 33's caused no issues or rubbing. Offroad the back tires hit the flares pretty good and the fronts when stuffed and turned rubbed the flares and I wasn't disconnected. I suspect if I had disconnected the front the tires would have ripped the fenders off.
35's with 2.5 bump stops in the front still rubs the stock fenders pretty good.
Now, trimmed fenders gains several inches but I would think 35's would still get pretty close?
duneslider is offline   Reply With Quote
Unread 09-11-2014, 10:00 AM   #12
fastfreddie
315 Duratracs measure numerically at 34.4". Real world measurements on my JK, using 8.5" rims w/ 4.63", sit at 33.5"
If wheeling without a lift and only mild flexing, I would rip the stock rear fenders right off. IDK what would've happened with the front fenders but the air dam definitely got hit on flat ground when turning.
With stock wheels, you may be able to stuff this size tire inside the stock fenders but clearance for hard parts may not be adequate.
This little berm taken at an angle, not straight on as in the pic, ripped half my rear fender off...no lift.
fastfreddie is offline   Reply With Quote
Unread 09-12-2014, 06:50 AM   #13
Mitch72
Thanks Kdailey for the info...
then 33s would be more suitable because no rubbing.
Unread 09-12-2014, 06:52 AM   #14
Mitch72
JIMBO
I will advise him to do so.
Thanks
Unread 09-12-2014, 07:11 AM   #15
JIMBOX
Thanx
Thanks
I'm notta curmudgeon, but I've seen "second hand" info screw things up too many times-
If he follows your info--then more questions will popup and he/we could really benefit if he joined our forum=
Good day
JIMBO
Yellow Jeep No. 683
