Need advice on shocks - Swapping coils/suspension on a 2DR - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Need advice on shocks - Swapping coils/suspension on a 2DR
JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFAlloy usa heavy duty ball joint kitsROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 06-05-2014, 08:31 AM   #1
apoto11
I'm planning on doing a suspension swap on my 2DR JK Sport sometime in the near future. Already bought some take off coils on ebay, I have 19's to swap in on the front and 60's to swap in on the rear(currently have 13's front and 55's rear). Now I just need some shocks to go with them.
Question is should I be looking for some take off shocks from say a Rubicon or would I be better off going after market? Any after market shock recommendations if I go that route?
2000 XJ Cherokee Sport
apoto11 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2014, 11:29 AM   #2
222Doc
well if you were close enough i would give you my rubi take offs. with what you are doing you just need stock length at a price you can afford.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 06-05-2014, 11:50 AM   #3
apoto11
Well shoot I'd pay for shipping if you'd be willing to ship to IN. I've been thinking aftermarket isn't really necessary because I'm not actually installing a lift although I've read on some other forums about guys doing a swap with some Bilsteins and being happy with the ride so I was just looking for some more input.
Unread 06-05-2014, 12:16 PM   #4
222Doc
Blisteins are good about 80$ each? I think the people here are liking the adjustable rancho's? Shipping would mean boxing them up enough to get there and just not worth it. Like i said if you were close enough we could just meet and wheel a day i would just give them away. Been hanging on to these since 2012. wife last clean up in the garage wanted them in the trash. Its hard to toss away something that is not broke. I had a guy in cali that wanted me to ship as well. But like i said to him, i can meet him in Parker save him 1hr. show him around some of our trails down there, nope he said...........You are bit to far for that though. Though if you wanted to meet in Moab i could be talked into that
Unread 06-05-2014, 12:47 PM   #5
SLADE
You ARE installing a lift (about 1.5"-2" lift) but if you don't add bump stop to increase tire clearance, you do not have room for a much longer collapsed length shock than your factory shocks.
You can however get a shock with a collapsed length of around 15" that will have a longer stroke than your factory shocks. Stock shocks only have about 8" of travel.
Try Bilstein 5100 front part # 24-146708 which measure 14.98" collapsed and 24.63" extended and have 9.65" of travel, and Rear part # 24-146715 which measure 15.39" collapsed and 26.38" extended and have 10.99" of travel. With a small increase in bump stop, you can run the slightly longer front Bilstein 5100.
Bilstein 5100's are a good match with the stiffer 19/60 coils.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote Quick reply to this message
Unread 06-05-2014, 02:31 PM   #6
Rancho_Lifts
Vendor
Ours are on rebate until the end of this month.
RS 9000's pair up well with the JK.
http://www.gorancho.com/promotions.php
Rancho products are proudly made in the USA!
Ask about our 90 day money back guarantee and lifetime warranty.
https://www.facebook.com/ranchosuspension/
http://www.jeepforum.com/forum/signaturepics/sigpic302198_9.gif
Rancho_Lifts is offline   Reply With Quote Quick reply to this message
Unread 06-06-2014, 06:50 AM   #7
apoto11
Thanks for the info and detailed recommendation. The 1.5" - 2" of lift is why I wanted to do the swap in the first place as it seems like the easiest and most cost effective way to get some lift without any complications.
Unread 06-06-2014, 08:15 AM   #8
Tbasham
When you install this, can you let us know how much lift you actually received with this swap. Front and back, before and after measurements would be beneficial. This is talked about alot on this forum but the more testimonaisl we have the better.
Tbasham is offline   Reply With Quote Quick reply to this message
Unread 06-06-2014, 08:50 AM   #9
apoto11
Absolutely. I have no timetable for when I'll get this done but I'll either start a new thread or revive this one when finished and post the measurements.
Btw, I know a Priller who went to Marian HS in Mishawaka with a Tyler Basham, that you by chance? Also, go Boilers just graduated from Purdue back in December.
Unread 06-06-2014, 09:59 AM   #10
JIMBOX
Gotta second the RS9000XL adj shocks---
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote Quick reply to this message
Unread 06-06-2014, 10:12 AM   #11
Rancho_Lifts
Vendor
JIMBO
You are slipping.
Don't forget to tell him to spin the shock body around in the rear to protect the knob. ( I learned/remembered that from you years ago) and often suggest it.
JIMBO
Unread 06-06-2014, 10:29 AM   #12
JIMBOX
Hey, I stand on the fifth (empty) !
Originally Posted by Rancho_Lifts View Post
JIMBO
You are slipping.
That pic is over 3 years old and every thing is still copasetic !
Thanx Rancho-
JIMBO
Yellow Jeep No. 683
Unread 06-06-2014, 11:49 AM   #13
Tbasham
That is not me, Im from NWI. Thats awsome, I will be graduating at the end of December. Kind of excited to finally be making money so I can start throwing it into my jeep.
Unread 06-06-2014, 11:53 AM   #14
SLADE
http://www.jeepforum.com/forum/f96/2...-swap-1506132/
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread 06-06-2014, 11:56 AM   #15
SLADE
Could you provide the shock part numbers front and rear with the extended and collapsed lengths for your shocks in the 15"- 17" collapsed length range?
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
