Ne Half Door Kit - JeepForum.com
post #1 of 13 Old 07-10-2010, 07:43 PM Thread Starter
Vin
Ne Half Door Kit
So I have my half door kit from Jeepaserus. Should have them painted now, or put them together, and have them painted in the winter?
Vin is offline
post #2 of 13 Old 07-10-2010, 10:24 PM
yoda13
Force Wheeler
yoda13's Avatar
Um, it shouldn't take too long to have them painted...that is what I would do...
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, †John 3:16†
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the
forum...
yoda13 is offline
post #3 of 13 Old 07-10-2010, 11:52 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
What I would probably do is put them together now then take them apart tomorrow then have them painted then put them together again next weekend
How come I always do things the hard way?
Jim
JLC08JK is offline
post #4 of 13 Old 07-11-2010, 12:04 AM
waterboarder
waterboarder's Avatar
Isn't it summer now where you are? Don't need doors in the summer.
waterboarder is offline
post #5 of 13 Old 07-11-2010, 06:36 AM
Jiblet
when is up to you but I think you'll want have them painted before you assemble them. Unless you want to disassemble them later for the painter. But you'll get better coverage of the e-coated shell if the trim, etc. are not attached. No taping necessary.
And you'll want the shell and hinges painted separately in case you need to make adjustments to the fit when you hang the doors.
Jiblet is offline
post #6 of 13 Old 07-11-2010, 10:26 AM
Abner
2010 JK Wrangler
I'm on the fence on getting these doors... they are a little pricey. Do they come with the upper soft window?
(what do you suppose a body shop would charge to paint those - 4 door set?)
Abner is offline
post #7 of 13 Old 07-11-2010, 10:47 AM
chumpmann
Have them painted first.
Easier without everything on them.
I got mine cheaper from the dealer....Got a discount. The mark up is pretty big, should be able to talk them down....
"Never trust quotes on the internet" - Bejamin Franklin
ˇɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
Other Jeeps...
1994 YJ - 2.5" RC lift, 31x10.5 BFG AT
Hers - '07 XK
chumpmann is offline
post #8 of 13 Old 07-11-2010, 12:40 PM Thread Starter
Vin
upper doors are extra.
Vin is offline
post #9 of 13 Old 07-11-2010, 12:50 PM
Abner
2010 JK Wrangler
ok - thanks....
I've done some searching on-line and can't find the upper portion of the doors... any idea where I can look and/or what they run? If I do this and take a road trip or something I just want a way to keep unexpected rain out!
Abner is offline
post #10 of 13 Old 07-11-2010, 03:58 PM Thread Starter
Vin
ok - thanks....
Check with Jeep Wrangler accessory and original Jeep parts and accessories - only from Jeepsareus.com. They have the whole kit there. For a 2 door the kit was just over $2000. The uppers were $400.
Vin is offline
post #11 of 13 Old 07-11-2010, 07:29 PM
Jiblet
That's a little pricey but maybe the assembly is worth it for some folks. Any dealer can get the kits and uppers. From what I see, people are paying $15-1800 delivered. The assembly is easy and the power option (as far as I can tell) only requires changing a 2-pin connector block to a 10-pin. That is, a 10-pin block that only has in it the two pins from the 2-pin block. Takes about 5 minutes with a small screwdriver and needle-nose pliers. no cutting required.
Plus painting ($4-500) and matching the lock cylinders to your VIN key at a dealer or equipped locksmith ($25-50)
Its best to have the painting done to the un-assembled shells, I am told.
Jiblet is offline
post #12 of 13 Old 07-11-2010, 09:12 PM Thread Starter
Vin
My dealer quoted me $2200 for just the doors (upper and lower) and regular locks. Through JeepsAre Us I have upper and lower doors, power locks and mirrors for $2000. I'm local, so I saved them money on delivery and they cut me a deal (even if it was a tiny one) by rounding off to an even 2000.
Vin is offline
post #13 of 13 Old 07-12-2010, 08:39 AM
chumpmann
If you want power locks, you have to order the power latches extra.
I kept mine manual so that when I have the alarm set and someone opens the door the alarm goes off.
I dont want the doors locked with the soft uppers, if they are locked then the windows are getting slashed....
Other Jeeps...
Hers - '07 XK
half , door , JK , wrangler
half door rubber seal issues (2nd sent of half doors) sail78385 TJ Wrangler Technical Forum 0 06-19-2010 01:59 PM
Does a half door plus an upper half = a hard door? Grinner JK Wrangler Technical Forum 2 04-10-2010 10:51 PM
Questions about Half Door and Full Door Locking Mechanisms... atticus_ar TJ Wrangler Technical Forum 8 12-04-2009 01:26 PM
Will TJ half door panels fit on a YJ half door? shinerm02 YJ Wrangler Technical Forum 0 07-02-2009 09:41 PM
Where to purchase half upper half door absentiabanish TJ Wrangler Technical Forum 3 04-11-2005 08:26 AM
