NAPA=Wix???? - JeepForum.com
post #1 of 12 Old 12-05-2010, 03:15 PM Thread Starter
monkers
2010 JK Wrangler
NAPA=Wix????
I was told the "Napa Gold" was made by Wix and is the same as the Wix filter for a 2010 JK. Is this true?
monkers is offline
post #2 of 12 Old 12-05-2010, 03:17 PM
tjkj2002
2002 KJ Liberty
Yes,but just beware some Wix filters are not the quality they once where.
tjkj2002 is offline
post #3 of 12 Old 12-05-2010, 03:18 PM
qf4phlyer
qf4phlyer's Avatar
That is correct.
08 Wrangler X DETN8R Yellow Rough Country 2.5" progressive rate coil lift, 2.2 shocks. 1.25" body lift, disco's, steering stabilizer. Benchmark EVAP skid. TeraFlex front bumper with shackles. 35x12.5x15 BFG A/T KO's on MB72 wheels.Cobra 75 on a Firestik. Arizona Rocky Road antenna mount. Ward bug shield, DayStar hood wranglers, upper dash panel. Qtech arm rest.
2002 Wrangler Sahara RIP
1979 CJ 7 258 RIP
1975 Cherokee S 401 RIP
qf4phlyer is offline
post #4 of 12 Old 12-05-2010, 03:40 PM Thread Starter
monkers
2010 JK Wrangler
Oh, I thought I read on here a while back that Wix was a great JK filter, any suggestions?
monkers is offline
post #5 of 12 Old 12-05-2010, 03:56 PM
rirrgang
They still are great filters.
Here's a list of filters for the 3.8 liter JK engine. The list on the bottom are for extended length filters which is a good idea to use.
Oil Filters
Regular Length
Mobil 1 - M1-102
K&N - HP1002
Pure One - PL10241
Amsoil - EAO57
Wix - 51348
AC Delco - PF53
Motorcraft - FL793
Fram - PH3614
Purolator - L10241
Napa - 1348
Bosch - 3330
Extended Length
Mobil 1 - M1-209
K&N - HP2009
Pure One - PL20195
Amsoil - EAO34
Wix - 51516
AC Delco - PF56
Motorcraft - FL400
Fram - PH3600
Purolator - L20195
Napa - 1516
Bosch - 3422
-Rick
07 Sahara Unlimited
rirrgang is offline
post #6 of 12 Old 12-05-2010, 04:02 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Thanks for the list (rirrgang)
I added it to the F.A.Q.
Jim
JLC08JK is offline
post #7 of 12 Old 12-05-2010, 04:55 PM
J_Westy
Just picked one up last week. The box says:
AFFINIA
Wix Filtration Corp.
J_Westy is offline
post #8 of 12 Old 12-05-2010, 05:22 PM Thread Starter
monkers
2010 JK Wrangler
thank you for posting the list, have any of you guys used the extended filters? how much more oil does it hold when you do a change? this will be my first change (the dealer did the first one free, this will be my first one)
monkers is offline
post #9 of 12 Old 12-06-2010, 06:20 AM
napajeep
2011 JK Wrangler
i've worked at napa for 11 years now. napa gold is made by wix. i went to classes on filters awhile back. i can assure you that the wix and napa gold filters are some of the best filters on the planet... the napa pro select filters are a cheaper grade. stay away from them. pay the extra couple bucks and get the napa gold...
napajeep is offline
post #10 of 12 Old 12-06-2010, 11:07 AM
rirrgang
I use extended Napa gold filter. It might hold a cup more oil. I still change the oil with 6 qts.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #11 of 12 Old 12-06-2010, 06:41 PM Thread Starter
monkers
2010 JK Wrangler
thanks guys
monkers is offline
post #12 of 12 Old 03-16-2012, 03:57 PM
4DFUN
Good Thread!
Rirrgang- Why do you say it's a good idea to use the extended oil filter?
4DFUN is offline
Dealer vs. Napa samger2 TJ Wrangler Technical Forum 26 07-24-2007 07:57 AM
Napa U joints jmhat98 YJ Wrangler Technical Forum 11 06-24-2007 09:42 AM
Napa ???? bende030 TJ Wrangler Technical Forum 2 02-27-2005 09:13 AM
Anyone using a NAPA relay ST-85 Fastbeeatch TJ Wrangler Technical Forum 6 10-03-2004 06:06 AM
Die Napa 93 Blue Demon YJ YJ Wrangler Technical Forum 2 04-23-2003 11:20 AM
