Mygig Nav GPS does not move - JeepForum.com
post #1 of 15 Old 08-29-2012, 06:45 PM Thread Starter
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Mygig navigation GPS is not moving, seems stuck at one location while Jeep is in motion. It does seem to sense directions, N, S, E, W, etc, not GPS car triangle stays stationary.
Do I need to replace GPS antenna or what's the fix?
2009 JK Rubicon
Shrockworks Mid-width Bumper, Warn 9.5Ti Winch; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - 8/2007
Rubicon - 9/2008
Thunderstrike is offline
post #2 of 15 Old 08-30-2012, 07:48 AM
Joevacs
2010 JK Wrangler
your radio is done. I hope your warranty is still in effect. If not go to Crutchfield or someplace and replace it with an aftermarket one. I have had 3 replaced on my Jeep , all covered under warranty
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #3 of 15 Old 08-30-2012, 01:07 PM
offcamber
Mine does this occasionally. Usually if I just shut the Jeep off and let the radio power down, it works when I start back up...
offcamber is offline
post #4 of 15 Old 08-30-2012, 02:17 PM
gogogooch
2009 JK Wrangler
I have had this happen twice while trying to navigate to an address - power down (open door to cut off) and wait a min or two fixed the issue.
gogogooch is offline
post #5 of 15 Old 08-30-2012, 03:42 PM
1AAdam
that sucks! joevacs - is it actually the radio that dies or did a dealer just replace it under warranty cause they wanted to fix it?
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #6 of 15 Old 08-30-2012, 07:20 PM
rirrgang
Mine does this once in a while. Sometimes it has me driving through water or over a mountain that doesn't have roads. Usually take a few minutes to fix itself. Has not done it in months.
Don't think your radio is done. It's just lost.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #7 of 15 Old 08-30-2012, 07:22 PM
rirrgang
the only way to "power down" mygig is to disconnect the battery. Even if it's "turned off" it's still really on.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #8 of 15 Old 08-31-2012, 07:28 AM
Joevacs
2010 JK Wrangler
The first one did exactly what the OP's is doing. The tracking would freeze occasionally, then it became more frequent, and then froze and wouldn't work at all. They flashed it at the dealership, hoping the update would fix it, but it didn't. The second unit , after 6 months, started telling me I was going a completely different direction than I was going. I wouldn't have noticed but since the digital compass on the dash is connected to the Nav unit it said I was heading south when I knew the road I was on, and was heading north. After a few weeks of that it started telling me I was driving in circles. Then white dots covered the screen and the satelite radio quit working.
So far the 3rd one is fine. It's been in now for 9 months so I hope it will last.
Joevacs is offline
post #9 of 15 Old 09-01-2012, 05:49 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Well, I am willing to replace the GPS antenna first. I already have extra after market antenna for Sirius radio Starmate. Can anyone tell me standard GPS antenna would fit mygig? Better yet, I would like to see a pic of rear view of mygig.
Thanks
2009 JK Rubicon
Ouray - 8/2007
Rubicon - 9/2008
post #10 of 15 Old 09-02-2012, 06:06 PM Thread Starter
Thunderstrike
2009 JK Wrangler
I put in a new GPS antenna, but it did not fix it. GPS Nav is still stationary, doesn't move.
Guess I'll be using a Garmin 2555.
2009 JK Rubicon
Ouray - 8/2007
Rubicon - 9/2008
post #11 of 15 Old 09-04-2012, 06:59 AM
Joevacs
2010 JK Wrangler
get one of these.
http://www.crutchfield.com/p_500INES....html?tp=20212
Joevacs is offline
post #12 of 15 Old 09-04-2012, 04:03 PM
smithjw
I had the same problem. Luckily mine was still under warranty. Nav would freeze up and A/C would stop working. Dealer had the part on backorder for 3 months finally swapped it out with new unit from dealer. No problems yet.
smithjw is offline
post #13 of 15 Old 09-05-2012, 05:37 AM
OH9JK
2009 JK Wrangler
Did you try removing battery cable or pulling the fuse to "reboot" the system?
OH9JK is offline
post #14 of 15 Old 12-08-2012, 05:01 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Yes, but did not do any good.
2009 JK Rubicon
Ouray - 8/2007
Rubicon - 9/2008
post #15 of 15 Old 12-08-2012, 05:03 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Originally Posted by Joevacs View Post
Can you rig it to watch DVD movie while driving like with a Lockpick?
2009 JK Rubicon
Ouray - 8/2007
Rubicon - 9/2008
RHB mygig into 09 Anonymous6915 JK Wrangler Technical Forum 6 11-11-2011 09:46 AM
New myGig? blue-coupe JK Wrangler Technical Forum 3 11-10-2011 05:49 PM
MYGIG or this? tomthbomb JK Wrangler Technical Forum 17 07-10-2011 01:37 PM
MYGIG in a TJ? cvaria TJ Wrangler Technical Forum 5 12-21-2008 02:14 PM
HELP with MyGig RFrazer JK Wrangler Technical Forum 15 06-13-2008 01:08 PM
