MYGIG Database Thread - Page 5 - JeepForum.com
post #61 of 199 Old 01-28-2013, 03:24 PM
exbauer
I have a 2008 Jeep Wrangler with a RER unit. I wanted to see what unit can I get that is interchangeable with my current unit that is plug and play. Any help is appreciated. What are the newer models that I can get that will work?
exbauer is offline
post #62 of 199 Old 01-29-2013, 06:56 PM
SirCody
The RHR is the Newest and prob will be the last one made as the Newer Chrysler Models will be changing the Can Bus system to the new system Like the new Ram and 300 and the Systems will have more Features, similar to GM's On-Star, and be internet connectable.
If you go with the RHR, only thing extra you will need is the GPS and Sat Radio combo Antenna.
SirCody is offline
post #63 of 199 Old 02-01-2013, 08:46 AM Thread Starter
Ron Burgundy
Team CANON
Ron Burgundy's Avatar
2009 JK Wrangler
RER update 2.404 is now available
I appreciate all of the info & good people on this site.
JK Sahara 2dr
Ron Burgundy is offline
post #64 of 199 Old 02-01-2013, 09:24 AM
MikeTHIS
Any major changes?
MikeTHIS is offline
post #65 of 199 Old 02-12-2013, 10:11 PM
LtChris
2009 JK Wrangler
Basically my question is that I am wondering if Part # #82211743AB is what I need.
Background Info:
I have the RER Radio in a 2009 Unlimited. (Im pretty sure)
Navigation works, Sirius works, the only things that don't are the voice command and handsfree buttons, when I press them it says something along the lines as not equipped with uConnect.
The part number I mentioned above, is the standalone mic that plugs into the back of the head unit and comes with a CD to enable uConnect and the buttons that don't work.
I am assuming that with that, and the update to the MyGig to the newest version firmware that I will be able to connect my iPhone via bluetooth and stream music. I am not too concerned with being able to navigate playlists through the head unit. I will be coming from my old truck where I had the cassette-audio jack converter so at this point anything is better. I just want hands free dialing and the ability to stream music.
Am I going in the correct direction or am I way off in my assumptions?
I got confused when I started reading about the part that is the iPod connection cable, that lets you connect your iPod and store it in the glove box and stream music through that.
Thanks!
LtChris is offline
post #66 of 199 Old 02-12-2013, 11:31 PM
SirCody
Background Info:
Thanks!
RER and RHR are Plug and Play with a simple, nothing fancy Mic....Plug it in and reboot the Head Unit buy disconnecting the Neg Side of the Battery for a few mins....reconnect Battery. Turn unit,
Go into the Engineer Menu and turn it on.....It doesn't have to be that mic if you don't want to throw out 30 to 60 bucks for one. It's a pretty standard connection for these kind of Voice Recognition....get one for under $10...
SirCody is offline
post #67 of 199 Old 02-12-2013, 11:33 PM
SirCody
Background Info:
Thanks!
That Disc isn't for the mic , it's just a way to make you feel like you got more for your money. It's prob an Old Update....The only people that are up to date are the good people that hang out at Unofficial MyGig Place...LOL
SirCody is offline
post #68 of 199 Old 02-12-2013, 11:47 PM
SirCody
Here is a Mic For A Dollar
9' cable. 1.70" x 0.92" x 0.50" rounded rectangular ABS case. 2-conductor cable (1-conductor with shield).
CAT# MIKE-95
$1.00 each
Quantity:
I buy tons of Gadgets etc from them...lol
http://www.allelectronics.com/make-a.../9-CORD/1.html
SirCody is offline
post #69 of 199 Old 02-13-2013, 12:06 AM
SirCody
Dollar Mic
Designed for use with a Bluetooth "hands-free" kit, microphone and pushbutton are housed in a 1.53" x 1.90" x 0.71" rounded case. Microphone connected to a 12ft, 2-conductor shielded cable, and membrane push-button connected to a 10ft 4-conductor cable.
CAT# MIC-64
$1.00 each
SirCody is offline
post #70 of 199 Old 02-13-2013, 12:12 AM
SirCody
Mopar Mic Installation Manual......
http://www.moparsupercenter.com/pdfs/82211743AB.pdf
SirCody is offline
post #71 of 199 Old 02-13-2013, 12:22 AM
SirCody
This is what i installed as my Mic and Not to Brag, but the First Location I chose to DRILL a hole in my Instrument Panel Between Speedometer and the Radio, flush and invisible, and it Receives my Country slang voice while driving 80 down the interstate with top off and doors off and Music Roaring....every single word she hears correctly...lol...
SirCody is offline
post #72 of 199 Old 02-13-2013, 06:16 AM
LtChris
2009 JK Wrangler
Sir Cody,
Thanks for the info,
I'm assuming that with the uConnect enabled and which ever mic installed, that I can then stream music from the iPhone as well since it'll already be connected via bluetooth, is that correct? or is that not even possible?
Thanks!
LtChris is offline
post #73 of 199 Old 02-13-2013, 06:54 AM
SirCody
Sir Cody,
Thanks!
When you plug the mic in, the mic is what activates it....and yes you will have full bluetooth function for the calls, The RER doesn't have that music streaming thru Bluetooth feature, Just the RHR...and lower end models RHB etc..but it plays better and louder thru the stereo port..
SirCody is offline
post #74 of 199 Old 02-13-2013, 06:56 AM
SirCody
Sir Cody,
Thanks!
You have an Amp don't ya? which one? I have the 368 watt Infinity/Harman Kardon Amp and it hasn't been used and these are better then the 2013 Alpine Amps....lol
SirCody is offline
post #75 of 199 Old 02-13-2013, 04:14 PM
LtChris
2009 JK Wrangler
Originally Posted by SirCody View Post
You have an Amp don't ya? witch one? I have the 368 watt Infinity/Harman Kardon Amp and it hasn't been used and these are better then the 2013 Alpine Amps....lol
I only have what came stock. so.. I'm not exactly sure, but its plenty good for me.
LtChris is offline
database , information , JK Wrangler , mygig , wrangler
Got my Mygig uconnect working highoctane JK Wrangler Technical Forum 11 07-14-2009 03:12 PM
Iphone 3.0 and uconnect Cavi JK Wrangler Technical Forum 2 06-17-2009 08:44 PM
Uconnect, Iphone G3, Worked now dosen't, No Dealer Help! consultJK JK Wrangler Technical Forum 13 06-16-2009 12:28 PM
uConnect on '08 JK w/MyGIG? OffRoadRyder JK Wrangler Technical Forum 5 10-20-2008 06:05 AM
MyGig Uconnect set up Scootr JK Wrangler Technical Forum 0 05-05-2007 08:46 AM
