MyGig anyone? - Page 96 - JeepForum.com
post #1426 of 1437 Old 06-11-2013, 09:27 AM
jryano
Well it's been about 2 months and I'm getting ready to go on vacation. I took my RER out and put in the original 6-disc. It worked for about 2 weeks then it started the same thing. So it's obviously not the head units. Can it be something wrong with my computer or the CANBUS system? I just don't understand how sometimes it comes on and others it won't. But it never stays on more than about 1.5 hours. All of the fuses I have checked have been fine.
jryano is offline
post #1427 of 1437 Old 08-18-2013, 09:17 PM
AlbertaJeeper
Hey everyone, I'm having troubles with my 430 (RHB) on my '13 JKUR not ejecting the disk. The cover slides down a tiny bit and kicks back up again. Any tips?
AlbertaJeeper is offline
post #1428 of 1437 Old 12-17-2013, 05:14 PM
08blkjk
I have an 08 with the RER. Tonight I pudhed the open close button and the screen went blank and nothong happened. I manually pulled the screen open and got the CD to load. I pushed the button again and nothing happened. I again manually pushed the screen closed and still nothing. The only button that works is the U Connect button. Thought or suggestions?
2008 Black JK
Mods: DIY Disco's, DayStar Upper Dash Panel, Grab Handles, DIY Grill Mesh, Black Rock Wheels, 285/75R16 Cooper Discoverer STT Tires
To Do: 3.5" Rugged Ridge ORV Lift, DIY Stock Bumper Mod, Winch (TBD), Cobra 75 WX ST Radio
08blkjk is offline
post #1429 of 1437 Old 12-17-2013, 09:11 PM
meon2wheels
2011 JK Wrangler
I would pull the fuse for 5 mins, put it back in and try again. This worked for me.
meon2wheels is offline
post #1430 of 1437 Old 12-18-2013, 05:01 AM
08blkjk
Thanks, I'll give it a shot.
2008 Black JK
08blkjk is offline
post #1431 of 1437 Old 05-29-2014, 12:25 PM
gumbydammit
Anyone install a switch to interrupt power from the infamous J13 or have tips on how to do that??
Sometimes my RER will run for weeks without having to reset it, however the last couple of weeks (since it's been parked outside interestingly enough) I have to pull the fuse every time I get in it, otherwise I get a blank screen. Pushing the nav/menu buttons will make the Jeep logo come up, but that's it. Once I pull the fuse for a few seconds I'm good to go again... for a while.
I'm considering putting a small switch under the dash that will interrupt/disconnect whichever line leads to the J13 fuse so I can reset it from inside the cab. As it is, I'm going to wear out my hood hinges and the lid to the fuse box!
gumbydammit is offline
post #1432 of 1437 Old 06-05-2014, 12:17 PM
kevinwayne20
I just purchased a RER unit (5064080AB a High SPD Buss unit) off of Ebay to put into my 2012 JKU. I plugged the unit in and the screen was blank. A fan kicked in on the side but I couldn't get it to do anything else. I took it out so I could do some more research on it thinking I may have screwed up and got the wrong unit. If that was the case, I was going to bite the bullet and resell it back on ebay as it would have been my mistake.
I looked through this thread and countless others and didn't see anywhere that the old RER units wouldn'g work in the 2012's. Did I miss it or should it work? I'[ve got the convinence package if that helps. For a short time after I traded in my 08, I had a REN unit in it so my gut says I've got a DOA unit t hat I need to send back to the vendor.
Any help is greatly appreciated!
kevinwayne20 is offline
post #1433 of 1437 Old 06-06-2014, 09:39 AM
alben
Do you know what year the RER radio was manufactured? I can't recall if it is the year of the radio or the year of the vehicle, but at some point Mopar tied the vehicle VIN and the radio together so that only a dealer could make a radio swap. From what I read it was to discourage theft. Google it and you might come up with something related to this topic. Also you might want to consult your local Mopar dealer.
alben is offline
post #1434 of 1437 Old 07-02-2014, 09:56 PM
jschwab1
2014 JK Wrangler
I have a 2014 JKUR with 430N unit with a problem I can not seem to solve and I am hoping someone here can advise. Jeep has replaced the nav unit and worked on ground wires. When I hit a bump in the road the right way, the 430N cuts power and reboots. Why is it doing this and what can be done to fix it? This happens several times on each drive. A solution would be amazing!
14" JKUR W/ RE 3.5" 4 LINK, 35" MT2 ON 17" ANZA RIMS, 4.56, 1310 SHAFTS
jschwab1 is offline
post #1435 of 1437 Old 07-07-2014, 05:31 PM
amr42
Well if the unit has been replaced and the ground wires confirmed good, then it can only really be the power (+12V) supply that is being interrupted on the bump... What about fuses? Tried to rule out them? I've never heard of a bad fuse connection, but it's worth a try...
amr42 is offline
post #1436 of 1437 Old 07-07-2014, 06:35 PM
jschwab1
2014 JK Wrangler
Does the 430N unit have it's own 12V power supply? There does not seem to be a fuse for it within the TIPM box on my 2014 JKUR.
jschwab1 is offline
post #1437 of 1437 Old 12-04-2016, 01:01 PM
rickou812
I have a 2011 wrangler unlimited with the RHB unit. It had software vers. 20.xxx on it and travel link would not work. I downloaded an update iso for 33.xxx update and burned a cd-r. I loaded the disk and and followed the update prompts. It is now in a never ending boot loop. The JEEP boot screen displays and stays on for about 30 seconds then the unit turns off and repeats... None of the buttons work. I can not get the cd out..etc.
I have tried pulling the fuse etc.. I have even disconnected the battery for over an hour with no change.
Is there any way to get the cd out?
Is there anything else I can do to try and recover the unit?
Thanks in advance for any help
Rick
rickou812 is offline
JK Wrangler , my gig , mygig , navigation , navigation system , sound system , wrangler
new jk mygig ? whyknot JK Wrangler Technical Forum 6 12-16-2012 12:40 PM
Mygig mic for REN or Need whole kit? rgt75 JK Wrangler Technical Forum 2 07-16-2009 08:14 AM
MyGig ver. 9.711 Zaphoid JK Wrangler Technical Forum 2 03-12-2008 10:05 PM
MyGig is here plyzie JK Wrangler Technical Forum 7 03-10-2007 08:01 AM
Mygig Bamoman JK Wrangler Technical Forum 0 02-25-2007 07:02 AM
