MyGig anyone? - Page 62 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > MyGig anyone?
HID's from RuffStuff!Ruffstuff Axle Simple Swap Kit!The Original 3/8" Ruffstuff Diff Cover!
Unread 12-02-2009, 01:47 PM   #916
bzb
Originally Posted by 99TJSport View Post
For the MyGig, you only need to:
1. Add Uconnect mic kit - can be gotten from the dealer for about $40. Part Number is 82211743AB
2. Go into engineering menu (Press Seek Up+Seek Down+Menu all at once) and go down to page 4 or 5. You'll see a button labeled "Enable JK HF+VR". Press that button. It will change from Enable to Disable and the UConnect will now be active.
If you don't have a MyGig, then you need to add a module, and have it scanned. I have that info as well if you need it.
Hi there
I just installed the Uconnect mic kit. Went through 4 of 4 pages of the Engineering Menu and can't find one labeled "Enable JK HF&VR" on any of the pages.
Any thoughts/ideas?
Thank you
bzb is offline   Reply With Quote
Unread 12-02-2009, 08:22 PM   #917
99TJSport
Originally Posted by bzb View Post
Hi there
Any thoughts/ideas?
Thank you
What software version are you running? The older versions (I see you have an 07) didn't have the feature available. You can download the latest software at http://mofv.com/mygig and you'll be all set.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline   Reply With Quote
Unread 12-03-2009, 09:35 AM   #918
bzb
Thanks so much.
Yes, it is the original version. Mygig has worked perfect so figured I shouldn't mess with it!
Just downloaded latest version and will install it when I get home tonight.
Just found this forum a couple months ago and the wealth of knowledge is amazing!
Unread 12-09-2009, 09:05 PM   #919
IWantAGladiator
I thought the latest upgrade for mygig nav's was supposed to eliminate the Accept screen. if it didn't do it automatically, what needs to be done?
IWantAGladiator is offline   Reply With Quote
Unread 12-10-2009, 08:40 AM   #920
aristobrat
2010 JK Wrangler
I think they meant that after a few seconds, the Accept screen will go away on its own (vs. waiting indefinitely for you to press it).
aristobrat is offline   Reply With Quote
Unread 12-15-2009, 08:11 PM   #921
Offroad
I finally went from v. 9.807 to 2.043. Best new feature? The one I was asking for since I got my Jeep, a pause/play button
Offroad is offline   Reply With Quote
Unread 12-15-2009, 08:42 PM   #922
aristobrat
2010 JK Wrangler
Picked up my '10 Wrangler today and was happy to see it came with 2.043 already to go on it. Was expecting to have to burn a CD when I got home, ... instead I got an excuse to ride around for another half hour instead.
Unread 12-29-2009, 06:32 AM   #923
cali9dub
Anyone have their mygig quit working. Mine went black yesterday. When you hit the eject button the splash screen comes up then it goes out and the unit powers off. Any suggestions on what is causing this? Thanks for any suggestions.
cali9dub is offline   Reply With Quote
Unread 12-29-2009, 06:59 AM   #924
hscrugby
Did you install a lockpick? If so, sounds like the connections are loose. (Even if you didn't it still sounds like the connection in the back is slightly loose) and it's not getting the signal to turn on from the canbus.
Jeep TJ. Stuff added to it. Stuff broken. More stuff added to it. More things broken. Currently in adding phase. Hope to be in breaking phase on trails soon.
hscrugby is offline   Reply With Quote
Unread 12-30-2009, 02:03 PM   #925
Ron Burgundy
Team CANON
Ron Burgundy's Avatar
2009 JK Wrangler
question for someone who installed mygig themselves. I did a few days ago. my gps antenna arrives on monday. until then, I have no satellites obviously. but the jeep still thinks it's in another city, where the original owner lived. and in another area, I see NAVIGATION IS NOT ACTIVATED. is that b/c of no antenna. or do I need to do something.
I have lockpick arriving on monday with the gps antenna. Will that fix it all?
Best regards and Happy New Year!
iPhone Uconnect Software FIX is available 2/5/11
MYGIG Database Thread
I appreciate all of the info & good people on this site.
JK Sahara 2dr
Ron Burgundy is offline   Reply With Quote
Unread 12-30-2009, 02:11 PM   #926
rirrgang
You have to set up the default state and your home address. Press menu on the right side. The rest is pretty self explanatory.
-Rick
07 Sahara Unlimited
Helping People Create Wealthy Lives @
www.Livesafeandhealthy.net
rirrgang is offline   Reply With Quote
Unread 12-30-2009, 02:19 PM   #927
rirrgang
Here's a PDF of the MyGig manual. Just click and save
MyGig
Hope it helps.
-Rick
-Rick
07 Sahara Unlimited
Unread 12-30-2009, 04:11 PM   #928
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Install the lockpick where accessible easily. I had to disconnect and poweron mygig, then reconnect lockpick to fix occasional "no video-button while driving" issue.
Watching Pink Floyd's PULSE DVD while wheeling Steel Bender trail in Moab.
My microphone is here
2009 JK Rubicon (Daily Driver).
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta
Thunderstrike is offline   Reply With Quote
Unread 12-30-2009, 05:59 PM   #929
Ron Burgundy
Team CANON
2009 JK Wrangler
I set up the default state and home addie. still 0 satellites. did anyone get satellites without an antenna? prolly not, but i'll find out on monday if I have another issue or not. thx for the pdf mate, cheers!
JK Sahara 2dr
Unread 12-30-2009, 07:33 PM   #930
rirrgang
Can you receive tv signals without an antenna? Can you receive Direct Tv Or dish Network without an antenna? why are you so surprised that you cannot see GPS sats with out an antenna? Be patient and wait for your antenna. Your life will drastically improve as soon as you install the GPS antenna.
-Rick
07 Sahara Unlimited
JK Wrangler , my gig , mygig , navigation , navigation system , sound system , wrangler
