10-02-2009, 10:46 AM
#871
Originally Posted by IWantAGladiator
For you guys using a backup camera with your mygig, what camera did you choose, and why? I'm looking at CCDs with at least 120 degrees range. Where did you mount it? Primarily I want it for hitching up to trailers. And will a 4pin to RCA mini adapter work if the camera comes with 4pin connector?
As for the mics, which ones are best? I'll use the top plate mount position.
Don't have a backup camera yet, but for the mic, get the mopar one. I tried the coasteltech one and it performed poorly.
10-02-2009, 02:19 PM
#872
Agree on the Mopar mic have it and it works great. For the camera, I used one of the keyhole cams on eBay and mounted it flush in my bumper. Plenty of visibility, and since it's ner the hitch, good for seeing the trailer too.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
10-02-2009, 06:57 PM
#873
X2 on Coastaltech mic........fell apart in my hand, Mopar one much better !!
Todd
2008 Sahara 2-door
Red Rock / Khaki
6-speed, Dual Tops, MyGig, Power and Tow Package
and YES I like the silver bumper inserts !!!
10-03-2009, 12:33 PM
#874
Not really. He is probably talking about using the power button to enable/disable video/nav in motion. Regardless, that doesn't explain your mygig radio cutting off after a few seconds. I would make sure everything is connected tight. The first time I connected mine, my passenger speakers didn't work. I just squeezed all the connections and made sure nothing was crimped. It was fine after that. Also, I am assuming that your mygig came with your JK and is a high speed can bus.
Yes the mygig unit came with my JK. Only other thing i can think of.. do i need to set the uconnect to active before hooking the lockpick up?
10-03-2009, 01:56 PM
#875
BOUNTY HUNTER
nope you can activate it after if you like
10-03-2009, 08:05 PM
#876
Just installed mine yesterday on my 07. I bought P05064739AD which came out of a 09 Chrysler minivan. It was already updated to the latest rev of everything, and it was easy as cake to swap out. It even had a Sirius subscription activated!!!
Something funny I noticed when I first turned it on, the Chrysler logo came up, and then afterwards, it "knew" it has been installed in a Jeep, and from then on out the Jeep logo showed up. It also got the VIN number from the car as it shows it correctly in the setup screen. Creepy.
2007 Jeep Wrangler Sahara 2dr auto w/4.10, Green Metallic, Freedom Top, Goodyear MT/R with Kevlar 35x12.5x17, Procomp Series 7069 wheels, OME 2" suspension kit, K&N air filter, Optima Yellowtop D34/78, Superchips Flashpaq, MyGig RER 2.045, Hella 700FF, KC Daylighters 631.
10-12-2009, 08:48 PM
#878
Back up camera mounted on the cover of rear windshield wiper.
2009 JK Rubicon (Daily Driver).
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta
10-13-2009, 07:51 AM
#879
Can you remove the hard top?
10-13-2009, 05:38 PM
#880
Yeah, I know. I can remove the hard top by unhooking a connector near the camera.
4x4 Trips:
Ouray - 8/2007
Rubicon - 9/2008
10-18-2009, 06:11 AM
#881
Couple questions:
I've got a '10 JK Unlimited, if I buy a new or used MyGig, are there any compatibility issues when plugging it in? I've read about different BUS speeds affecting regular head unit installation.
2nd, is the Sirius subscription tied to the head unit, of the equip that allows Sirius to operate? Will I have to reactivate it and lose my free year that came on the stock Sirius unit (has the single disc Sirius radio that comes as an option)?
'10 JK Wrangler Sport Unlimited | Surf Blue
'12 MINI Countryman Cooper S All4 | True Blue/Chili Red JCW Appearance Pack
10-18-2009, 06:33 AM
#882
You defintely want to make sure and get a high speed bus unit, and the Wrangler uses the CAN C (high speed) bus.
The Sirius reciever is tied to the head unti, so if you swap, they'd have to move your year over. I;ve found after going through 3 different radios that it's a crapshoot with them, some are helpful, some are not.
Jeff
10-18-2009, 04:18 PM
#883
I didnt have the same experience with the Sirius part.
My JK came with the 6-disc CD + Sirius. Before I took it out, I wrote my Sirius number down. I then replaced that with the MyGig, which kept the same Sirius subscriber number.
I thought I read somewhere that the number was associated with the antenna somehow, not the head unit?
10-18-2009, 06:03 PM
#884
Defintely the head unit, not the antenna. I purchased my Jeep in July 08, came with a free year. When I got my 6 disc, it was from and older Jeep, and it's subscription ran out in April. Had to sweet talk them into extending it to July, which they did. Then I got my MyGig, and it had a free subscription until 10/8/2009, since it came from an 09 Ram. All 3 radios defintely had different Sirius ID's...
Jeff
10-23-2009, 02:31 PM
#885
Here's one for the people in Canada. My 1 year free subcription with Sirius is finished at the
end of this month. I've enjoyed the mygig "Siruis traffic" all year, it came in handy many times.
I wanted to renew the satalite radio "and" the Sirius traffic.....thing is the sirius traffic (even
though i have had it all year is not available for purchace in Canada...yet.....i've had it all year
but now can't renew??? I called and all i can renew is the radio...make's a lot of sense!?*&%
Anyone up here in Canada have this problem? Did you figure out a way to get the sirius traffic renewed?
2012 4 door Sahara / Black
2008 4 door Sahara / Rescue Green Jeep Club Member #15
1992 YJ / White
