My turn to build... DIY Tube Fenders - JeepForum.com
post #1 of 27 Old 01-07-2011, 09:25 AM Thread Starter
Rutdigger
2015 JK Wrangler
After my lift install and 35" tire addition I had a slight rubbing issue at full flex, so I decided I wanted flat fenders. As usual I didn't want to pay the cost for the Bushwackers so decided to make my own.
I cut the template out of the paper and transferred it to the foam board, then to the metal. This piece will be the inside of the fender that the rails are welded to:
Then I bent the tubing to the basic shape of the stock fenders. This is when I realized that nothing on the friggin JK is straight..lol.
Welded to template:
Made the other side to match and began to add supports:
Wrapped in painters tape and cut out sheet metal template:
Transferred cutout to sheet metal and cut it out:
Bondo to smooth out then primed for paint:
1st coat of bed liner:
Installed:
Now I just need to get the rear done..lol.
Rutdigger is offline
post #2 of 27 Old 01-07-2011, 09:31 AM
austentatious
they look great! good job
O|||||||O
|ProComp|Rokmen|Zone|MetalCloak|RockHard|Mastercra ft|TomWoods|Novak|TenFactory|Synergy|
austentatious is offline
post #3 of 27 Old 01-07-2011, 09:34 AM
nufga
2010 JK Wrangler
x2, still saving up for flat fenders since I don't have the capacity to do what you did.
Also, not to deviate from the topic but is that a fabbed stinger on a stock stubby bumper?
nufga is offline
post #4 of 27 Old 01-07-2011, 09:57 AM Thread Starter
Rutdigger
2015 JK Wrangler
Thanks bro!
Thanks man...and yes, that is a home brew stinger. I posted a build thread to it just now. Let me know what you think.
post #5 of 27 Old 01-07-2011, 10:09 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Good chit, I like the kind of backwards flare at the bottom rear.
Mol is offline
post #6 of 27 Old 01-07-2011, 10:24 AM
krutj
2009 JK Wrangler
Very nice...from start to finish!
Excellent fab. job Bro..
-- Joel --
krutj is offline
post #7 of 27 Old 01-07-2011, 10:26 AM Thread Starter
Rutdigger
2015 JK Wrangler
Thanks guys! Hopefully I can get the rear done soon.
post #8 of 27 Old 01-07-2011, 12:22 PM
saharac
Great job man... great fabrication skills...
saw your thread on rock rails -- thats great too...
I am looking to get a simple set of rock rails, the prices on the brands are ridiculous, hopefully will find a welder in town who does something like the ones you made...
Only critique that I have is for the fenders,, they seem a little short in length to me,, I personally would have liked it to cover more of the inside support thats welded to the rail, probably to the point where the supports curve down again...
saharac is offline
post #9 of 27 Old 01-07-2011, 01:26 PM Thread Starter
Rutdigger
2015 JK Wrangler
Thanks man. No worries on your critique bro.. I didn't like how they looked further down (I made a proto type first) so I made mine a little shorter. Thats the beauty about building your own stuff, you can make it look like you prefer..
post #10 of 27 Old 01-07-2011, 02:04 PM
saceone
I need to buy a welder and take a few courses
sweet build, thanks for posting
saceone is offline
post #11 of 27 Old 01-07-2011, 02:10 PM
mclaggan123
jeepaholic
mclaggan123's Avatar
first off great job. second may i ask what you are using to bend the tubing? a pic of your bender would be helpful. thanks
2006 Rubicon unlimited, silver. 5.5" long arm lift. 35" BFG KM2's on 15" black steelies. skidrow steering skid and radiator skid . LOD rear bumper with tire carrier. Flowmaster 44 exhaust. .CB with tuffy Overhead storage . Offroad lights in bumpers front and rear plus 2 more on the winch hoop.
mclaggan123 is offline
post #12 of 27 Old 01-07-2011, 02:19 PM Thread Starter
Rutdigger
2015 JK Wrangler
I'm using this "pipe" bender Harbor Freight Pipe Bender. Now, in order to be able to bend tubing you will ned to make some modifications. I made a few clamp boots that fits over the top of the tubing when bending:
These boots keep the tubing from rising in the pipe boot and kinking.
For square tubing I made this die/boot:
With this I can bend 1" swuare tubing. I added removable shims that allow me to bend 3/4" square tubing also.
The last step is to fill the tubing with sand and tape the ends. This give it a bit more stability and produces cleaner bends.
You can find out more about me by visiting my website:
The more you play with it, the bigger it gets!
post #13 of 27 Old 01-07-2011, 05:05 PM
saharac
Absolutely... Keep it going...
saharac is offline
post #14 of 27 Old 01-08-2011, 12:44 AM Thread Starter
Rutdigger
2015 JK Wrangler
Yeppers batman..lol. I got some more coming soon!
post #15 of 27 Old 06-22-2011, 09:09 AM
usmc20c
Rutdigger those fenders look freakin awesome!!! Hope you don't mind but i'm gonna copy yours somewhat but with a little bit of my touch...
Sgt Carlile, Craig
USMC - Active
San Diego, CA
usmc20c is offline
TNT tube fenders -vs- overkill eng tube fenders CCJ TJ Wrangler Technical Forum 44 12-02-2011 03:24 PM
Front l.e.d. turn signals for tube fenders? jhoff TJ Wrangler Technical Forum 1 01-08-2010 04:27 PM
Tube Fenders with CJ Turn Signals roll call MillerTimeTJ TJ Wrangler Technical Forum 1 05-04-2009 09:01 PM
Tube fenders and turn signals bmxstreet15 TJ Wrangler Technical Forum 11 08-02-2007 07:29 AM
Turn Signals with tube fenders : ( Wheels4186 TJ Wrangler Technical Forum 3 03-06-2007 11:29 PM
