My turn to build... DIY Dual Battery Tray - JeepForum.com
post #1 of 4 Old 01-07-2011, 09:52 AM Thread Starter
Rutdigger
2015 JK Wrangler
Start by removing the monster battery tray. This thing is one huge molded plastic piece that connects the battery tray, fuse box stand, and air box mounting locations all in one mold...take it out:
Next you will need to cut off the section that your fuse box and air box mounts to. You will keep this section and discard the other:
Remove this reservoir from the front of the Jeep to allow easy installation of your new tray:
Make a template using foam poster board for your main mounting plate on the firewall:
Transfer that pattern to your 10 gauge and cut out the template. Next measure the battery width of the batteries you want to install. I found that you can't go much more than 7.25" on each battery compartment side for a total of 14.5" floor plate. It just fits, but barely, weld the sections together after you find your center line and cut a center support:
Remove and fabricate the plate the fuse box and air box base will sit and attach to:
Add a mounting post for the Evap solenoid, drill holes for water drainage, and prime for paint:
Paint your choice of paint:
Install in the Jeep:
Second Bat in, everything hooked up and working properly. Good to go.
Rutdigger is offline
post #2 of 4 Old 01-07-2011, 02:45 PM
Grecy
Grecy's Avatar
2011 JK Wrangler
That's really slick. Great work.
Are you concerned at all about the battery closest to the engine getting too hot and possibly boiling?
I buddy of mine constantly has this problem in his 4Runner.
-Dan
Around Africa in a Jeep Wrangler JK @
(previously Alaska->Argentina in a TJ)
Follow:
- Everything you need to know to Travel Overland across a country, continent or the world.
Grecy is offline
post #3 of 4 Old 01-07-2011, 02:58 PM Thread Starter
Rutdigger
2015 JK Wrangler
-Dan
No..there should not be a problem. This DIY is exactly what you would get from the other manufactures like Rugged Ridge, Benchtop, etc. If there was an issue with the battery overheating I think that would have worked out already. However, it wouldn't be to much of problem to line the battery with some type of insulation.
You can find out more about me by visiting my website:
The more you play with it, the bigger it gets!
post #4 of 4 Old 02-16-2011, 09:41 AM Thread Starter
Rutdigger
2015 JK Wrangler
Project complete. THe other battery installed; connections hooked up; everything working as it should.
Smittybilt Dual Battery Tray & Battery Temp Sensor. 05jeeper TJ Wrangler Technical Forum 6 07-23-2010 08:32 AM
Dual battery tray Que89YJ YJ Wrangler Technical Forum 5 01-10-2010 08:15 PM
which dual battery tray is better? jeepgunner12 TJ Wrangler Technical Forum 3 10-24-2009 10:53 PM
Dual Battery Tray Snake Man TJ Wrangler Technical Forum 6 11-12-2005 04:43 PM
Tomken Dual Battery Tray chaZo TJ Wrangler Technical Forum 4 01-22-2003 07:17 PM
