My JK vids/pics, stock, on 32's, lifted on 33's, offroading, etc - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > My JK vids/pics, stock, on 32's, lifted on 33's, offroading, etc
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 11-15-2006, 08:21 AM   #16
moloss
sweet pics and vids......looks like alot of fun!
"Do your duty in all things. You cannot do more, you should never wish to do less." Robert E. Lee
moloss is offline   Reply With Quote Quick reply to this message
Unread 11-15-2006, 11:21 AM   #17
Andrew F
Originally Posted by 2k2wranglerx
wow that one pic really does make it look like i have camber issues . . . . i havne't had it aligned. You cannot adjust camber on a solid front axle vehicle. There's no adjustment.
I think it's just the "fisheye" effect of my old digital camera. When i look at it in person they look ok.
I didn't even have to straighten the steering wheel. Unlike the TJ/zj/xj/yj's, the JK uses crossover steering. You don't even need to adjust your toe.
Cool, as long as it is only a camera issue. The camber can be adjusted, it's just a pain. Offset ball joints can be installed, but there probally aren't any out for your axle yet. Camber can also be adjsuted with the control arms by rotatng the pinion. But that process is tedious and does't yield as much of a result.
Anyways, your Jeep looks good. I would start looking for some new rims. Those stockers just don't cut it in my opinion.
04 LJ
4.5 RE SF w/ 3.5 springs
32x11.50R15 BFG MT
4.88, Lock Right F/R
[SIZE="2"][COLOR="Red"]Red Jeep Club Member #347[/COLOR][/SIZE]
Andrew F is offline   Reply With Quote Quick reply to this message
Unread 11-15-2006, 11:26 AM   #18
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Where were these pics taken?
My Hummer Hole video
SIRA 4x4 club
I'll be Savvy someday!
neZZr is offline   Reply With Quote Quick reply to this message
Unread 11-15-2006, 12:42 PM   #19
Karamba
Did you have a chance to check out how well does JK's electronic limited slip system work?
Karamba is offline   Reply With Quote Quick reply to this message
Unread 11-15-2006, 12:46 PM   #20
Conundrum
I like your idea of where to put the fogs lights too.
Matt
2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat
1981 DeLorean DMC-12 VIN: 2953
Conundrum is offline   Reply With Quote Quick reply to this message
Unread 11-15-2006, 02:54 PM   #21
2k2wranglerx
ya did you watch the video? it shows all 4 workin.
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline   Reply With Quote Quick reply to this message
Unread 11-15-2006, 03:18 PM   #22
BCwrangler
Long time Jeep fan
BCwrangler's Avatar
In his opening sentence, he states he's got an open diff
BCwrangler is offline   Reply With Quote Quick reply to this message
Unread 11-15-2006, 05:21 PM   #23
Karamba
Electronic limited slip is standard on all trims. It uses ABS hardware. It works over open diffs. Need more information on it?
Unread 11-15-2006, 05:30 PM   #24
neZZr
neZZr's Avatar
You're right, and if you check out the video's he posted you can see it doing its thing quite well!
SIRA 4x4 club
Unread 11-15-2006, 05:36 PM   #25
Karamba
Yes, I saw the video. I was interested in his comments.
When running Toyota FJ, ATRAC engagement is rather noisy. And you could see more slippage of individual wheels. It does not work well at all when both wheels are slipping, and not in 4Hi. Was the video in 4Lo BTW? Did not have a chance to wheel a JK yet.
Doeas brake assist (BAS) work in 4Lo?
Unread 11-15-2006, 06:30 PM   #26
rmcnelly
Got any video of how the short wheelbase Jeeps did in the same area? That stuff looked really slick!
rmcnelly is offline   Reply With Quote Quick reply to this message
Unread 11-15-2006, 07:27 PM   #27
famicom21
its really nice to see some trail pics for a change.
how much air were you rinnign in your tires? looks like airing down could've helped quite a bit too.
Yellow 86 CJ-7 Red 70 CJ-5
"Out on the road, out 'neath the stars, Feelin' the breeze, passin the cars."
famicom21 is offline   Reply With Quote Quick reply to this message
Unread 11-15-2006, 08:30 PM   #28
2k2wranglerx
The BAS does work in 4lo. I was in 4low there. It's not very noisy, as a matter of fact, it's hard to tell when it's working. i did feel a slight "tap tap tap"as i was going up the hill. I'm pretty sure that was the BAS working.
In high range (unless you turn it off) you have full esp. Which includes the BAS as well as an anti-roll over package. That is turned off automatically when you put the tcase into low range.
Rmcnelly: i'm waiting on my videos, but i should have more of the swb jeeps getting owned at that spot. where i popped over that hump at the very beginning (that's why mel laughed), nobody in a swb jeep could get over. They would just slide to the left. I popped right over, got cocky, and ended up too far left and had to work my way out.
Famicom21: 10 psi in the tires. . . . 12.2" wide tire on a 7" wide rim holds a bead pretty well.
Unread 11-15-2006, 08:39 PM   #29
YellowNJTJ02
Best lookin JK I've seen. I really do like them!! You've got a nice rig. All trims have the ESP, if thats what its called. It looks to work very well... have you used it on the rocks yet?
02 Yellow TJ
RE 4.5" SF, Teralow
D44 Rear Detroit, Alloy USA Chromo shafts - ZJ discs - 4.56
D30 Front Powertrax No-Slip - 4.56
33" BFGs, Snorkel, Warn x8ki w/ 5/16" synthetic
Bulletproof Bumper up front, Warn Rear SOTC
YellowNJTJ02 is offline   Reply With Quote Quick reply to this message
Unread 11-15-2006, 09:02 PM   #30
2k2wranglerx
a little, but my BAS light was on (i think the tone rings were just so covered in mud that it couldn't read). So it wasn't working (no big deal).
i'm still going to do selectable lockers int he axles with 4.88 gears.
