My JK unlimited cage - Page 2 - JeepForum.com
post #16 of 80 Old 01-02-2013, 04:41 PM
spedly
2011 JK Wrangler
Looks good. Makes me wonder if I could get a hard top back on mine.
Poser Jeep.
spedly is offline
post #17 of 80 Old 01-02-2013, 04:48 PM
1shotwonder
Holy **** rollcage! I'd like to see how that would do in the case of a roll over, looks beefy and BA
Save 1000 elk. Smoke a wolf pack
Sometimes the light at the end of the tunnel is a muzzle flash
1shotwonder is offline
post #18 of 80 Old 01-02-2013, 05:34 PM Thread Starter
Dr.Dirty
Spent a couple hours today modifying the soft top to make it fit. It no longer folds like the factory one did but im ok with that.
Heres the new rear mount
The factory door surrounds no longer had holes for the bolts to go through and i dont plan on drilling the new cage.
So I cut the surrounds and added a maglite flashlight holder clip.
Dr.Dirty is offline
post #19 of 80 Old 01-02-2013, 05:35 PM Thread Starter
Dr.Dirty
Factory freedom tops can still be ran without the rear half of the hard top.
I had to remove two of the quick clamps so i just added a tab and bolt to secure the top
mounted the radio
Dr.Dirty is offline
post #20 of 80 Old 01-02-2013, 07:25 PM
Wonk
How much tube did you use on this? Very clean looking cage. Nice work.
Wonk is offline
post #21 of 80 Old 01-02-2013, 07:39 PM Thread Starter
Dr.Dirty
So far I have used 108 feet of 1.75 DOM
Dr.Dirty is offline
post #22 of 80 Old 01-02-2013, 11:23 PM
Molonlabemike
Very nicely done sir....insert golf clap
Molon Labe
Molonlabemike is offline
post #23 of 80 Old 01-03-2013, 11:25 AM
MKE_Mike
2016 JK Wrangler
Great work
MKE_Mike is offline
post #24 of 80 Old 01-03-2013, 12:03 PM
Rancho_Lifts
Vendor
Rancho_Lifts's Avatar
Love this work!!
Rancho_Lifts is offline
post #25 of 80 Old 01-03-2013, 11:17 PM
fratis
fratis's Avatar
if you are going to use the tic-tac or continuous-tac technique you can back the tip slightly to get more overlap and cover the craters. it also blends the heat more thoroughly.
most people sandwich plates rather then run the tubing actually through the body. if you cut a wider hole it will keep the body from grinding (squeaking) against the tube when the body and frame twists during articulation.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #26 of 80 Old 01-04-2013, 05:13 PM Thread Starter
Dr.Dirty
Dr.Dirty is offline
post #27 of 80 Old 01-05-2013, 11:18 AM
Tanimal
Make. Me. One.
Learning as I go and it's worth every penny!
Tanimal is offline
post #28 of 80 Old 01-05-2013, 09:35 PM Thread Starter
Dr.Dirty
Ok I lost my dome lights so I started looking for a solution. I just snagged this guy on ebay for 99 so I figured its worth a shot
Dr.Dirty is offline
post #29 of 80 Old 01-05-2013, 10:15 PM
Godholio
This is unreal. That looks awesome, and the maglight mount was a great idea.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #30 of 80 Old 01-06-2013, 09:53 AM
Wonk
Do you by chance use Bend Tech for your design work? And if you do would you be willing to share your file?
Wonk is offline
