Is my Jeep burning too much oil? (dipstick pic included) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Is my Jeep burning too much oil? (dipstick pic included)
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-30-2011, 04:47 PM   #1
dirtyjpwrangler
After doing some reading here on the forums I've found that it is generally accepted that many JK's burn about a quart every 1000 miles, and that Chrysler calls this "normal" (go figure).
By looking at my dipstick can you tell me how much oil is left? Am I burning more than 1qt/1000 miles?
The picture shows my dipstick @ 2500 miles after my previous oil change with me having added a quart of oil immediately before taking the picture. Hope that's not too confusing... I marked where the oil was before adding the extra quart.
Edit: I'm the 2nd owner and therefore not under the lifetime power train warranty.
'08 X, Jeep Green, 6 speed, 32" BFG MT's, power options, rubi rock rails, front grab handles, soft top all year round ...oh yea and dirt.
dirtyjpwrangler is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 04:49 PM   #2
PlatinumNiner
My ZJ with 185k and my XJ with 173K dont burn ANY oil between oil changes. if i had a new or newer truck burning 3 quarts of oil between oil changes id be back at the dealer right away. I say you have a problem.
PlatinumNiner is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 04:53 PM   #3
ronjenx
ronjenx's Avatar
The best thing you can do now is top it up to full, and check it once a week.
Add a quart each time it's at the quart low mark. Keep track of it on paper.
You can't really tell yet what it's doing with just one look at the dip stick.
ronjenx is online now   Reply With Quote Quick reply to this message
Unread 04-30-2011, 04:55 PM   #4
Dryseals
If you are making a lot of short trips, this can lead to oil consumption.
Dryseals is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 04:59 PM   #5
ncb
The bottom line of the safe range is one quart low. You were probably more than two quarts low. With that kind of oil consumption you should check the oil level every time you fill up with gas.
ncb is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 05:34 PM   #6
reznik572
2011 JK Wrangler
I had a 09 2DR JK X that I only ever put 30,000KM on, and it never seemed to burn a drop. I was in the habbit of checking it all the time as my previous vehicles always burnt a lot.
I'd go with what ronjenx's advice.
reznik572 is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 05:37 PM   #7
kik
You were down 2-2.5 qts. You definately need to check more often and keep a log when you have to add a qt. When you're down 1qt. add and note the mileage. On a side note: I believe that Chrysler indicating that "they" will accept an engine burning 1 qt. of oil every 1,000 miles as "normal" is BS. If that ever happens with my 10 Rubi, which at this point it doesn't burn oil, it's going. There is no way I could own a vehicle with an engine that is that defective, no matter what type of vehicle or who makes it. I really never heard of such nonsense with modern engines. I hope the standard for the new 3.6 is greater.
kik is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 06:42 PM   #8
Celtic
2011 JK Wrangler
How many miles on the odometer? Mine is new with 5000 miles and Dioscuri is still reading full.
Celtic is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 08:08 PM   #9
dirtyjpwrangler
what is Dioscuri? My engine is @ 52k
kik was right. I added another quart and was just about at the top of the "safe" area on the dipstick. So I was down about 2 qts, which means I'm burning 1 quart every 1250 miles.
I think what it comes down to is that some jeeps burn oil and some don't. I guess I'm just going to have to keep a closer eye on mine.
Thanks for all the responses
Unread 04-30-2011, 08:40 PM   #10
Discovery
2007 WK
Change brands of oil.Mobile 1 is not the end all of Motor oils.
Discovery is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 08:52 PM   #11
GeoBigJon
Cactus Hobbit
GeoBigJon's Avatar
2014 JK Wrangler
I wonder if they or you added the right amount of oil to begin with? I have 4.5k miles on mine and haven't used a drop, these post have me wondering though so I check it regularly. 1quart per 1k miles is BS. Just for my curiosity, do you drive with high RPM's, high speeds? My KLR650 uses oil if the RPM's are kept high for long periods of time, so I am wondering if that is playing a factor in those with oil consumption issues, just at thought.
2014 JK Anvil Rubicon
If you eat, drink, or wear cloths then you're involved in agriculture.
GeoBigJon is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 09:50 PM   #12
ncb
My JK didn't use any oil until around 18K miles. It's using around 1/2 a quart every 3K miles. I know it's full after the oil change because I do the oil changes, and I check it once a week and can see it slowly dropping. I found that the inside of the intake manifold is oily and wondered if maybe it's huffing oil through the PCV. I changed the PCV at the last oil change about 300 miles ago. It's too soon to see if this helps. I don't have any leaks because my garage floor is clean. I have the lifetime warranty on the engine so I'm not worried if it becomes worse, but I don't want to run it low on oil and be responsible for grenading the engine.
Unread 04-30-2011, 10:13 PM   #13
JK4Three
2009 JK Wrangler
Like GeoBigJon said, the prior change could have been low. The JK takes 6qts, and to save money they could have put in 5 to just to barely get to the safe zone. Also be sure to check it on level ground and also changing the pcv valve is easy, maybe stating the obvious here but ??. If it's mechanical it might be a valve guide and hopefully not rings at only 50k mi. Looking at your plugs can give a clue. Using a quart at just over a thousand miles isn't good, but livable if you watch it carefully. I think using 5W30 might help a little too.
JK4Three is offline   Reply With Quote Quick reply to this message
Unread 05-01-2011, 06:49 AM   #14
Celtic
2011 JK Wrangler
Dioscuri = Dipstick. It was late and I was tired. I must have totally fat-fingered the keyboard.
Unread 05-01-2011, 10:47 AM   #15
BlueLesPaul2006
Mine burns 1qt for every 1000 miles driven. I have switched types and weights of oil and it still burns. I warm the engine up before I drive and nothing helps. I have taken it to Jeep and they state it is normal. I disaree. I am the second owner (i bought it certified) so I dont know how it was driven before. I have 48K miles on it and I drive like a normal person and 1qt burned for 1000 miles on a 48K engine is not normal. I see that some have burn problems and it seems like I am one of the burners. I hope the 2012s with the new V6 will be better. By this time next year I will be trading in/up for a new engine.
OK, then...the hood is not supposed to flop up and down??
Dang, all this time and I thought it was the famous Jeep Wave!! ~bluegrassguitar
BlueLesPaul2006 is offline   Reply With Quote Quick reply to this message
