My first leak....input please - JeepForum.com
post #1 of 8 Old 06-25-2013, 10:50 AM Thread Starter
Utah_Jay
I walked out this morning and saw the dreaded "spot" on the driveway. Red and obviously transmission fluid. It was on good sized drop. It looks like it dripped from the bottom of the radiator. There is a plastic piece the fans sit on and that is where it dripped from.
Since the JK routes the fluid through the condenser I am assuming that is where it is leaking and running down the plastic. I checked the fitting and don't see any fluids or sweat. I got in there with a mirror and can't even see any more tranny fluid.
Is this a common issue on the JK? leaking from the condenser? Ironically I was going to install my B&M cooler today also, now I am debating on bypassing the condenser all together. Just turned 50k on the clock.
2007 JKU Sport
Utah_Jay is offline
post #2 of 8 Old 06-25-2013, 11:11 AM
JIMBOX
Go back about a foot, in the tranny lines and look at the two tranny cooler lines (rubber vibration coupling) either (hot) bottom, or cooler (top) lines develop a fluid leak at one of their pressed fittings--
Look at them from underneath/w light and you should see drops-
Chrysler Safety Recall J30 addresses that problem , although I'm not sure about '07--I gotit for mine '08-
Good luck-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #3 of 8 Old 06-25-2013, 05:57 PM
JIMBOX
Found another letter concerning tranny fluid lines leaking-the Recall, j30 concerns computer/dash icons
Good luck-
JIMBO
The Line Leak Letter, Dtd June 17, 2011 and extended the tranny/fluid lines warranty, for 7 years and 70,000 miles--
You might call the CHRYSLER CUSTOMER ASSISTANCE CENTER---MONDAY THRU fRI --8:00 am TO 8:00 pm, at 1-800-426-5337 and mention the "leaking" lines--IF THEY ARE=-
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #4 of 8 Old 06-26-2013, 09:24 AM Thread Starter
Utah_Jay
Jimbox, I appreciate the replies. I have checked the transmission lines and they are dry on all the fittings. It makes be think the leak is coming from the condenser but there really isn't a way to tell as it is covered with too much plastic. I had no drops on the driveway today.
I am going to go ahead with my supercooler b&m install this week, hopefully when I get in there I will be able to see where the leak is coming from.
2007 JKU Sport
Utah_Jay is offline
post #5 of 8 Old 06-26-2013, 09:28 AM
Magatetzz
Check power steering pump, lines, etc., same fluid
... and see what it's really going to take to build one...and then I'm going to triple that cost/time estimate and see how I feel.
Best gas milage from my Jeep to date: The time I pushed it across the lot at work.
Magatetzz is offline
post #6 of 8 Old 06-26-2013, 09:46 AM
JIMBOX
Kewl, you're probably OK with the tranny then-
Thats a good idea from Magatetetzz, cause the tranny/xfer case/power steering all use ATF-4 and all can leak-
Also dirty antifreeze from the rad. can be mistaken-
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #7 of 8 Old 07-15-2013, 05:51 PM Thread Starter
Utah_Jay
Good luck
JIMBO
Update:
I believe the fluid I found is actually antifreeze. I didn't think so at first as it looked and felt like transmission fluid, however upon close inspection this past week I found corrosion on the top of the radiator with dried anti-freeze on it. While the level is not really going down enough to notice it, I believe the radiator is bad.
I would rather replace a radiator than the condenser. This will be on my short list of things to do in the coming weeks.
2007 JKU Sport
Utah_Jay is offline
post #8 of 8 Old 07-15-2013, 06:10 PM
JIMBOX
OK, one final check, before you start messing with the radiator--
Drop a light just below the water pump and either with a mirror, or from underneath---look at the bottom two bolts of the water pump and look for rust trail down to the oil pan edge--
Depending on the magnitude of the leak, the antifreeze will either buildup and then drop to the floor, or just buildup and migrate back along the pan/engine block--
I'm interested, because mine used to doit, till I retorqued the pump bolts !
Post what you find, might be valuable to others/you-
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
