Is my axle dying? - JeepForum.com
post #1 of 7 Old 10-28-2013, 08:47 AM Thread Starter
nicholasburr
Is my axle dying?
Hi guys don't know anything about my rest diff in my rubicon. It seems to be leaking oil very slowly.
Here's a pic
nicholasburr is offline
post #2 of 7 Old 10-28-2013, 09:31 AM
biffgnar
biffgnar's Avatar
First, not advanced. Second, is there any oil leaking on the other side of the diff and up by the pinion? Either pinion seal or just cover seal. Both readily fixable.
Romney in 2020!
biffgnar is offline
post #3 of 7 Old 10-28-2013, 09:49 AM Thread Starter
nicholasburr
I'm not very familiar with this forum. Where should I have posted it? Sorry about that.
I'll have to look later. I'm not home right now. I'm glad I noticed it while I was bedlining the tub yesterday.
post #4 of 7 Old 10-28-2013, 12:04 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
You posted correctly. Leaking diff seal, remove/replace or have someone do it for you. As noted, might want to check pinion seal too (where the Drive shaft connects to the front of the diff).
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 7 Old 10-28-2013, 01:24 PM
Pokey02
Here's a pic
Check to make sure the bolts at the bottom of the diff cover are tight. Otherwise you just need to real seal it ... I'm a huge fan of using LubeLockers instead of RTV.
13 10a JKUR - Metalcloak 2.5" lift
06 LJ Impact Orange - Savvy 3" lift, Savvy UA and 33s
Pokey02 is offline
post #6 of 7 Old 10-28-2013, 09:34 PM Thread Starter
nicholasburr
How much would a new seal cost, what do I buy for the Dana 44? And how easy would it be to do myself? Would I have to replace any oil? I really have no mechanical experience. But want to learn the ways
Thanks!
post #7 of 7 Old 10-28-2013, 10:23 PM
RustysOffroad
Thanks!
Not too tough. Buy some Right Stuff gasket maker or another gasket (stock or something like a Lube Locker).
http://www.permatex.com/products/our...he-right-stuff
Get the right gear oil.
Get a catch pan remove/inspect/use the Right Stuff and reinstall.
Complete details and info at
We are available via Phone 256-442-0607
Follow us at
RustysOffroad is offline
