My Attempt At The Mesh Grill Mod - Page 3 - JeepForum.com
post #31 of 61 Old 04-02-2013, 09:49 PM
Filthy-Beast
Originally Posted by xraypat23 View Post
i peeled all the bases i used for mine and glued them down with gel loctite. by the time i finished putting all the bases on, the ones i did first were already dry. I also have the black emblem, looks so much better, go mine off amazon for the same price, right around $10!
I did the same peeling the bases took most of the time for this mod.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #32 of 61 Old 04-03-2013, 08:41 AM Thread Starter
john304
2010 JK Wrangler
Originally Posted by IrishBullfrog View Post
Buy?!?!? Plastic dip you emblem!!!! My Jeep emblem, trail rates badges and rims have been done for 8 months with Zero issues.. $5 bones a can...
I didn't trust myself removing the emblems, I was sure I would have damaged them, which is why I bought new ones.
john304 is offline
post #33 of 61 Old 04-03-2013, 04:42 PM
JoeJackson
2011 JK Wrangler
Where exactly at Home Depot would you find these base mounts? I have been looking for 30 mins with no luck.
I live vicariously through myself
JoeJackson is offline
post #34 of 61 Old 04-03-2013, 04:43 PM
Filthy-Beast
electrical section ask for cable tie mounts made by gardner bender.
For Sale:
post #35 of 61 Old 04-03-2013, 06:34 PM
janders82
2010 JK Wrangler
You don't have to remove your emblems to plastiDip them. Plasti Dip is some really cool stuff. You should YouTube it
2010 JKU Automatic w/ 5.13 Gears
2.5" TeraFlex w/ Rancho XL9000s
17" XD Addicts
295/70/17 Nitto Trail Grapplers
janders82 is offline
post #36 of 61 Old 04-03-2013, 09:47 PM
irishluck
I never could find them at the home depot where I live.
Had to go to lowes. Should be in electrical with zip ties around the zip ties
irishluck is offline
post #37 of 61 Old 04-04-2013, 04:36 AM
rha600
Use dental floss. You will need a good amount because it likes to break, but pull off enough to loop twice and then slide it behind the emblem. then just work it back and forth. the wax on the floss will help protect the paint from scratches and the emblem won't be touched, you're just cutting through the tape. you'll have a bit of cleanup to do after but that part is easy.
Also, if you do it on a day where you can park in the sun and let it heat up the emblem and glue it will work even better.
You have to go into the isle usually where all the wire is. Down that isle there should be a section that has the zip ties as well as electrical tools like multimeters, coax crimp, wire strippers...they are usually in there. But if you found them at Lowes then
rha600 is offline
post #38 of 61 Old 04-04-2013, 09:08 PM
IrishBullfrog
You can spray your whole jeep with plastic dip and it will peel off whenever you want it to.. I did all of my badges and taped nothing off, and it came right off my paint right around it.. YouTube is your friend :-)
IrishBullfrog is offline
post #39 of 61 Old 04-21-2013, 10:21 AM
davidsonlaw
I did a similar mod yesterday, except I used a large sheet of aluminum mesh instead of the gutter guard. It's the material used in screen doors. It's not as big of a cosmetic change as I thought it would be, but I mostly wanted to keep rocks and other debris off of my radiator.
http://www.davidson-law.net/blogs/jeeplaw/
davidsonlaw is offline
post #40 of 61 Old 04-28-2013, 10:04 AM
zenman
I haven't popped the hood yet to look but how easy is it to get the grille off? I had some hail damage to my radiator so I'm going to just cover it up.
New Jeep: 10th Anniversary Rubicon, Anvil with Red Leather seats
Old Jeep: 2012 JK Sahara Dozer
zenman is offline
post #41 of 61 Old 04-28-2013, 10:07 AM
janders82
2010 JK Wrangler
Super easy! Takes less than a minute. Just pop the rivets out with a flat head and gently wiggle the grill out starting at one of the turn signals. Don't forget to unplug the turn signals once the grill is loose.
17" XD Addicts
post #42 of 61 Old 04-28-2013, 10:09 AM
davidsonlaw
Ditto. I found that it was easier to just take the whole bulb assembly out rather than just unplugging the wiring.
post #43 of 61 Old 04-28-2013, 10:51 AM
janders82
2010 JK Wrangler
I do the same thing. Way easy
17" XD Addicts
post #44 of 61 Old 04-28-2013, 12:46 PM
Teeka
2011 JK Wrangler
Electrical section
Teeka is offline
post #45 of 61 Old 04-28-2013, 03:09 PM
Deuskid
subscribed for future reference. I'll want some kind of mesh behind the grill.
Deuskid is offline
