My 37's aren't? - JeepForum.com
post #1 of 34 Old 04-16-2014, 11:02 AM Thread Starter
Ripped08
My 37's aren't?
I have BFG Mud Terrain KM2 37x10.50r17m tires on Walker Evans 8.5x17" Bead lock Wheels with 2000 miles that measure 35 3/4" tall at 35psi. Is this the norm for 37's? Do most tires measure less than advertised? Thanks
'08 Rubicon 2dr. Yellow-Ripp Supercharger-BFG 37" -AEV 3.5 lift- 5.13 Gears-Tom Woods Shafts
Ripped08 is offline
post #2 of 34 Old 04-16-2014, 11:05 AM
Agent620
Yes, this is normal.
Thanks to Anticanman who gave me a membership!
Chris Hansen is reading this thread.
If you've ever been in that traffic, you would have ground down the steering wheel with a death grip too. "Just ****ing GOOOOOO!!!!"
I pitty anyone who tries to reach into that netting unaware.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
post #3 of 34 Old 04-16-2014, 11:17 AM
SLADE
It's normal for tires to measure less than their labeled size. BFG is even more known for measuring smaller than other manufacturers of the same labeled size.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #4 of 34 Old 04-16-2014, 11:26 AM
Garza
A more accurate measurement is horizontally across the tire while it is on the rig, not from the ground to the top of tire.
Garza is offline
post #5 of 34 Old 04-16-2014, 11:32 AM
Lenny7
2006 WK
Jack the tire off the ground to get an uncompressed measurement.
Lenny7 is offline
post #6 of 34 Old 04-16-2014, 12:50 PM
SubAtomicGenius
2011 JK Wrangler
I thought BFGs were notorious for being smaller than the rated size anyhow.
SubAtomicGenius is offline
post #7 of 34 Old 04-16-2014, 12:56 PM
duneslider
My 35bfg's are like 33.5. But my 33's in both goodyear and toyo were less than 33, both about 32 new.
My mtrk 35's were about 34" though.
duneslider is offline
post #8 of 34 Old 04-16-2014, 12:58 PM
SubAtomicGenius
2011 JK Wrangler
Its common to be about an inch off, however 1.5" is disappointing when you spend all of that money. That is why I'd avoid the BFGs in the first place. My 35" GT Grabbers are only off by 3/4", and that's measuring from the road to the top of the tire.
post #9 of 34 Old 04-16-2014, 01:00 PM
ncb
This is true. My 35" KM2s measure a bit under 34". I call them chubby 33s.
ncb is offline
post #10 of 34 Old 04-16-2014, 01:08 PM
paul84043
They never are man....just the way it is. Don't sweat it.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #11 of 34 Old 04-16-2014, 01:09 PM
cyberpyrot
Man that sucks $1,800 and they short you some rubber?
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
cyberpyrot is offline
post #12 of 34 Old 04-16-2014, 02:57 PM
ancientspear
Don't Interco and Pit Bull tires measure closer to what is printed on them?
EDIT: Don't forget the width of your rim will adjust the diameter of the tire. In theory the manufacturer is quoting number for a rim in the middle of the range tthey say to put it on... but if you go to the lower or higher end on rim width your mounted tire will change footprint/height somewhat.
ancientspear is offline
post #13 of 34 Old 04-16-2014, 04:30 PM
JIMBOX
it's a crap shoot-
My Hankook Dynapros are advertised at 33.6" and are 33.2"/30psi--installed on 16x8-1/2" rims
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #14 of 34 Old 04-16-2014, 04:36 PM
ROCKR8R
Actually I don’t think manufacturers give you the measurement of it mounted on a wheel. They are true to measurement un-mounted. So technically they are producing a 37” tire, “oh you wanted them mounted on a wheel?” Seriously though, most if not all are under what they claim when mounted.
BFG is notoriously small. Aside from that, they have no siping and have a weaker sidewall compared to other M/T tires on the market, which is why I tend to avoid them. They do have great traction in mud and slick rocks and their lugs don’t chunk away.
-Dan
ROCKR8R is offline
post #15 of 34 Old 04-16-2014, 08:38 PM
ancientspear
My stock BFG lugs are chunking... but way less than the Duratracs I had on my WJ, I guess it depends on the types of trails you subject them to. You are right about traction when things get sloppy and I have run them 37 psi on rocks and they did fine. Just don't air them down below 20 LOL
