My 2012 pings up steep hills. Is there a reflash to fix? - JeepForum.com
post #1 of 15 Old 08-23-2012, 08:50 AM Thread Starter
Dale_K
I have the base model 2012 with the manual trans, 3.73 gears and I live in a hilly community. On steep hills I get a pretty strong pinging from the motor and I think it's getting worse. The typical situation is 1,900 to 2,300 rpm with about 1/3 throttle in 3rd and 4th gear. At first I tried just going from 4th to 3rd and that does raise the rpm but it still pings about the same. Yesterday I filled up with 89 octane and that didn't seem to make any difference at all. Funny thing is on a different steeper and longer hill I don't get any ping at 2,300 in 4th at full throttle. The hill where the pinging is worse doesn't require full throttle but the curves limit how fast I can go so I can't just charge up it.
It's like the engine computer doesn't have a good map for part throttle, moderate load, moderate rpm. It's not reacting to the knock sensor or can't pull timing or maybe can't move the cam phasers enough to correct. At least that's my theory. I was hoping there might be a reflash. I know there's one for the head problem (that never works to prevent head failure) and I don't know if that reflash might do some good for my situation. I don't have the ticking or CEL issues on mine.
Dale_K is offline
post #2 of 15 Old 08-23-2012, 08:54 AM
gonwhln
process of elimination:
not using low octane fuel?
Superchips or programmer installed?
Large tires with no regear?
Evo rear King Coilovers, Recon front King Coilovers, Rock Krawler all 8 control arms & links, CV driveshafts, removed rear sway bar, Custom skids, Viair OBA with dual compressors mounted behind tailights & 2gal tank, Warn M8000, Body Armor rear bumper and carrier w/custom rotopax, front Poison Spyder Brawler lite bumper, Herculined tub, Cobra 75wx cb, daystar switch panel, Hella lights, custom cut fenders, 17" black alloys w/ 35" treadwright Guard dogs, Gusseted and regeared to 5.13's, Teraflex drag link flip, cut and dieted, Benchmark HD oil pan, RK deep sump HD tranny pan.
gonwhln is offline
post #3 of 15 Old 08-23-2012, 09:54 AM
jstrubberg
2009 JK Wrangler
The first issue would be a steep hill at 2k rpm. You are dogigng that engine hard.
jstrubberg is offline
post #4 of 15 Old 08-23-2012, 01:13 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Your theory is real strong Dale. I would get it in to the dealer asap and see if you have a bad knock sensor or something. It should not ping at all regardless of load, octane or steepness of hill.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #5 of 15 Old 08-23-2012, 02:56 PM
muddr1
Exacly what jwm said. There are knock sensors on the engine, it should not ping at all uless you got some really bad gas. if it still does it with gas from a different station, I would take it to the dealer.
If we knew what we were doing it woulnt be called research
Albert Einstein
There are no rules here, were trying to accomplish something.
Thomas Edison Keep Calm,Chive On
muddr1 is offline
post #6 of 15 Old 08-23-2012, 03:35 PM
WXman
Sure it's not the trans ? My trans rattles and it sounds identical to engine pinging.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #7 of 15 Old 08-23-2012, 08:15 PM
surfdogs
This is good info. I have a 2008 with 33s and 85k. It pings a bit, but if I put 89 octane gas in, it goes away. I'll need to look into the knock sensor.
surfdogs is offline
post #8 of 15 Old 08-24-2012, 08:48 AM Thread Starter
Dale_K
I guess I'll take it in. I realize that you can make almost any engine ping if you're lugging it but I drive several other manual trans vehicles on the same roads and they don't ping. I feel like I'm driving them about the same. The other reason I don't think I'm lugging it is the Jeeps is able to maintain pace and even accellerate a little while it's pinging. I don't know what the reflash for the head failure does but since Jeep is blaming those on a combination of fuel quality and driving patterns maybe it does something that might help my pinging problem.
I expect to be frustrated when I take it in since they won't be able to duplicate it in an area of flat terrain, which is the situation near the dealership.
Dale_K is offline
post #9 of 15 Old 08-24-2012, 07:02 PM
muddr1
Keep us updated Dale
Albert Einstein
muddr1 is offline
post #10 of 15 Old 08-24-2012, 07:49 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
does it sound like there is a rock floating around in the bottom of a barrel? thats your 6-speed. they ALL rattle since 2005.
My builds:
and
or follow us on
spyder6 is offline
post #11 of 15 Old 10-13-2012, 06:15 AM Thread Starter
Dale_K
A little update - there has finally been some cool weather here in Arkansas and the pinging totally stops when the temperature gets down around 60. I was really surprised by the huge difference in the way my Jeep runs. I was able to drive up hills where the pinging was bad and even at 2000 rpm there is no pinging at all. I really want to get the 3.6 reflash that came out with the head failures but I haven't talked to the dealer about it yet. I suspect the 3.6 would benefit from a lower temperature thermostat, too.
Dale_K is offline
post #12 of 15 Old 10-13-2012, 06:30 AM
jeepnie87
I've definitely noticed this on mine. Has there been any issue with this that you know of, or is that just the way it is? Thanks
jeepnie87 is offline
post #13 of 15 Old 10-13-2012, 04:00 PM
spyder6
spyder6's Avatar
2010
just the way it is
My builds:
and
or follow us on
spyder6 is offline
post #14 of 15 Old 05-05-2013, 10:12 PM
Schocker65
Dale - are you having the same problem now that the outside temps are going up again? I am having the same problem now that it is getting warmer outside.
Or did you find a solution?
Schocker65 is offline
post #15 of 15 Old 05-06-2013, 08:53 AM
222Doc
222Doc's Avatar
the reflash I think is cover up to delay the need for Jeep to replace the head. a software fix for a mechanical flaw.
The ping if not corrected with 89. Might well be sign of the valve going out in #2.
One thing I have not heard from at least found a post related. I might just go to my trusted mechanic I use for things I can not do. I do not trust the dealers. Have #2 checked with, leak down test or even a scope camera to see how that seat looks. Jeep is hidding this issue like the Goverment is Benghazi.
my 2$ adusted for inflation
222Doc is offline
New rebuilt 258 w/4.0 head now pings, HELP Tuffy1 YJ Wrangler Technical Forum 89 10-26-2012 07:55 PM
JK diesels and pings under load keogge JK Wrangler Technical Forum 5 09-18-2011 08:40 PM
How steep is too steep? (driveshaft) chadsmeltzer TJ Wrangler Technical Forum 20 11-06-2010 04:14 PM
Reverse Gearing, Steep Hills? tadst1300 TJ Wrangler Technical Forum 13 11-24-2009 06:01 AM
Gears slip going down steep hills TaskerTrio TJ Wrangler Technical Forum 3 04-09-2007 10:50 PM
