My 2010 Rubicon - JeepForum.com
post #1 of 27 Old 07-24-2010, 01:07 PM Thread Starter
MoparToYou
2014 JK Wrangler
My 2010 Rubicon
I thought I would share with you all what I have done with my little 2 door Rubicon.
When the JK first came out I had a 2004 TJ that was very well equipped. It had Currie axles, 4.88 gears, Detroit lockers, 6" suspension lift with long arms and coilover shocks, and 37" tires. It was my fifth TJ, and it worked very well off road, although it was not the most pleasant vehicle in the world to drive on road. I have always been able to build great off road performing Jeeps, but when I look back over the years, and analyse why I sell them, it is because I get tired of their lack of power and poor handling on road. I wanted to focus more on performance and handling if I bought a new vehicle, and less on pure capability. I didn't want another vehicle that followed the "bigger is better" philosophy, with 37" or bigger tires. I wanted a vehicle that would be great to drive every day, but still be capable enough to make it through most anything I might encounter while exploring the backcountry.
I looked around at every vehicle I could think of, trying to find the best base vehicle to set up for back country exploring. I looked at Toyota FJ Cruiser's, Toyota Tacoma's, Ford Ranger's, Chevy Colorado's, and even a Land Rover. The Jeep JK has a few minor shortcomings, but all of its shortcomings can be addressed, unlike the shortcomings of the other vehicles. The Rubicon was the best choice for me.
The two main flaws with the JK Wrangler are: 1) Pretty much the whole front axle was under engineered; the tubes are weak and can bend or even break, the c-gussets bend, and the axle shafts break easier than they should. The axle shafts themselves are strong, but the axle u-joints have a half circle style c-clip that keeps the u-joint cap on. The half circle clips tend to come off, which lets the cap come off the joint, then the joint binds in the axle and breaks the ears off the axle shaft. 2) The steering box is also under engineered, and even a stock JK can break the sector shaft.
Here is what I did to make my Rubicon work a little better.
Teraflex Elite LCG 2.5" long arm suspension
Dynatrac Pro Rock 44 front axle w/ Motive Gear chromolly shafts
5.38 gears
Tom Woods driveshafts
35" Goodyear MT/Rs
Rock Hard 4x4 Parts front bumper w/ Warn M8000
Expedition One rear bumper
By purchasing the chromolly axle shafts I now have the stock axle shafts that can be used for spares if I ever have an axle shaft problem on the trail. I have also obtained an OEM steering box and power steering pump from a friend that upgraded his JK's steering with a PSC hydraulic ram assist, so I have spare parts for the steering.
Here is a photo after welding on the new brackets for the long arm suspension.
New JB Conversions spring perch used on rear axle.
Checking the contact pattern on the new 5.38 gears.
Completed rear axle / suspension.
Completed front axle / suspension.
And here is the finish product.
The work was done by Impulse Off Road, in St. George, UT. I've only put 500 miles on the Jeep so far, with 100 miles being off road miles, but so far I'm very happy. This is the best driving Jeep I've ever owned, and it is still very capable.
Thanks for reading.
2014 Grand Cherokee Laredo: 2" Eibach lift, 265/70R-17 BFG KO2's, 17x9 KMC Addicts
MoparToYou is offline
post #2 of 27 Old 07-24-2010, 01:12 PM
Kenbo-Slice
Damn, that is a clean, practical and overall good looking Jeep you have there. Nice job.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #3 of 27 Old 07-24-2010, 02:30 PM
allibaster
Thank you very much for sharing your experiences. Great read, and great JK!
allibaster is offline
post #4 of 27 Old 07-24-2010, 02:45 PM
fan45acp
2010 JK Wrangler
Really NICE....
fan45acp is offline
post #5 of 27 Old 07-24-2010, 04:30 PM
BeerGut
Junior Member
Cool - I would like to see bigger tires though
BeerGut is offline
post #6 of 27 Old 07-24-2010, 06:17 PM
Warlord2
Thank god someone still is staying with the 2 door. I cant wait tell I can get some RCV axles, the stock spare would be nice to have...
Nice looking rig, why the long arm with only 2.5" lift though? looks like they would make good rock grabbers
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #7 of 27 Old 07-24-2010, 08:16 PM Thread Starter
MoparToYou
2014 JK Wrangler
Yes, I stayed with the two door. It took me three years to finally buy a JK, because every time I would go to a dealership with thoughts of buying one, I would go there thinking I wanted a four door. I would test drive a four door, and come away from the test drive so underwhelmed that I could not bring myself to buy one. The four door is just too big and heavy for these little 3.8 engines. Acceleration is too sluggish, and climbing a mountain grade is downright painful. Finally I test drove a two door, and to my surprise it felt just like most other Jeeps I've owned, only better. It was much more peppy, sporty, and better handling. I came back from test driving the auto trans sport JK and told the dealer to locate me a Rubi with leather. And the rest, as they say, is history.
I went with the long arm suspension for improved ride quality and improved handling. A friend had access to several different brands of suspensions for JKs, for a magazine article he was writing. He tried several combinations of springs, control arms, shocks, and came up with the best ride quality from Teraflex 2.5" springs, Elka shocks, and JKS control arms. I test drove his Jeep with that set up, and then test drove it again after he put Teraflex long arms on it, with the same 2.5" springs and Elka shocks. Just changing to the long arms made a substantial improvement in how well it drove. So that is what I decided to go with. I didn't want a Jeep just for rock crawling, with great big tires. These 3.8 engines don't have enough power to turn the bigger tires well anyway. This Jeep is for backcountry exploring, where I will typically cover a hundred miles or more of backroads in a day. I want it to be capable enough to cross obstacles I may come upon, but I don't intend to go find a stream bed somewhere and spend all day going 1/4 mile in the bottom of a stream.
That spring experiment my friend conducted was interesting though. There are a lot of suspensions out there that really don't work all that well, and some are pretty bad. Some of them even cause the ESP to continually go off, just driving around town.
post #8 of 27 Old 07-24-2010, 08:30 PM
Warlord2
WOW, I would of never known that a long arm would make that much difference being at only 2.5" of lift. Im working on a baja style jeep wich is kinda what your talking about but for desert runs. Sounds like a long arm system might be in the future for me. I was hoping to get by with just stock arm mount sense I already have all the adj control arms and am upgrading to coilovers soon. I wish I had that kind of access to lift kits! So you tested a few different shocks I take it and Elka were your favorites? Just wondering, I want to start with coilovers up front and getting really good springs and shocks for the rear tell funds let me buy more coilovers, the rear mount is what is really expensive for them unless I make my own...
When I tested the 4 door I had the same problem as you did, just gutless and heavy. I went with the 6 speed 2 door but even the auto was much more peppy then any of the 4 doors. Really is the only thing I really hate about the JK's is the retarded 3.8l engine...
Warlord2 is offline
post #9 of 27 Old 07-24-2010, 09:30 PM Thread Starter
MoparToYou
2014 JK Wrangler
Yes, the long arm suspension was significantly better. And my friend liked the Elka shocks the best, but I actually liked Icon 2.5 reservoir shocks better than the Elka shocks, so I went with Icon shocks on my Jeep. The Icon shocks are a little more firm than the Elka shocks, but are super super well controlled.
post #10 of 27 Old 07-24-2010, 10:13 PM
jonnytc
Your jeep looks amazing. Congrats and thanks for sharing!!!
jc
2008 JK Sahara Unlimited Steel Blue--For the Beach and Family
2005 LJ Rubicon Unlimited Black--For anywhere I want to go
Did you Wave to a JK today???
jonnytc is offline
post #11 of 27 Old 07-24-2010, 10:16 PM
LuckRider
LuckRider's Avatar
Needs bigger meat though.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #12 of 27 Old 07-24-2010, 10:24 PM
Lastshot
I would only go with bigger tires if you did the equiv of a highline, or high clearance fenders. The 2.5 long arm on 35"s looks very clean, almost sleeper to the untrained eye (meaning everybody but jeepforum members)
In short, Sweet
{Project
-'05 LJ build }~{SOLD '98 TJ -
{You know you drive a TJ
gily25 Says...
Issues only become problems when you don't have the tools or time to fix it.
Mike318 Says...
I like my 4.0L like I like my ****... stroked and blown. :duhrock:
Lastshot is offline
post #13 of 27 Old 07-25-2010, 07:03 AM Thread Starter
MoparToYou
2014 JK Wrangler
I would only go with bigger tires if I had a hundred more horsepower under the hood. The goal was to make this Jeep fun to drive, and I think I succeeded. Bigger tires = a real dog in the performance dept., which gets old in a real big hurry. Been there, done that, with the last Jeep.
post #14 of 27 Old 07-25-2010, 07:40 AM
Dadstoys
2010 JK Wrangler
Its perfect imo for what you use it for. Congrats on a great looking rig.
Dadstoys is offline
post #15 of 27 Old 07-25-2010, 08:22 AM
saceone
very neat setup
saceone is offline
Going to look at a 2010 4Dr Rubicon tonight jeffself JK Wrangler Technical Forum 13 07-20-2010 10:58 AM
New 2010 Jeep Rubicon Tinga Wrangler General Discussion 25 04-22-2010 04:20 PM
2010 rubicon unlimited CaseyC6 JK Wrangler Technical Forum 0 03-04-2010 06:05 PM
2010 Unlimited Rubicon xinys JK Wrangler Technical Forum 2 12-14-2009 11:02 AM
2010 Sahara or Rubicon Jeratbp JK Wrangler Technical Forum 24 10-02-2009 08:11 AM
