Must order kit to lineup front end - JeepForum.com
post #1 of 10 Old 12-06-2012, 10:34 PM Thread Starter
oldmanintexas
Took my 2008 wrangler Rubicon in today for my 5 year check up, and oil change , they said my front end was out of line some but they would have to order a kit to line it up, it has 23,000 miles and never been off road the only reason I got it was to pull my boat up the steep moss covered ramp that I use at Lake Texoma. What and why is a "kit" required to line up front end?, that is my question, quoted me $200.00 for kit and front end alignment.
oldmanintexas is offline
post #2 of 10 Old 12-06-2012, 10:38 PM
1222
RIP John
1222's Avatar
Perhaps your axle housing is bent and you need off-set ball joints to bring it back to specks.
(2011-2016)
1222 is offline
post #3 of 10 Old 12-06-2012, 10:41 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
That would be a good question to ask your dealer that said you needed it!
Mike
08 Rubicon
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #4 of 10 Old 12-06-2012, 10:41 PM
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Is it lifted? Maybe they're talking about a camber kit.
2010 Rubicon, Auto, Stone White, 3.5"Synergy Coils, DL and TR, MetalCloak TB's and CA's Fr/Rr, 37"Coopers 18" Ions , Adams 1310's, G2 5.13 gears, Synergy Sleeves and Gussets, ORF, PSC, JCR, PIAA,Rancho equipped...
HighandLow is offline
post #5 of 10 Old 12-06-2012, 10:42 PM
Coolcatracing
I'm not sure what they're talking about with the kit. I would get a better explanation and look at the actual alignment sheet. The toe is the only thing they can really change so if its not lifted and nothings bent you shouldn't need anything.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #6 of 10 Old 12-06-2012, 10:43 PM
Coolcatracing
Camber isn't ever adjustable.
post #7 of 10 Old 12-06-2012, 10:44 PM Thread Starter
oldmanintexas
No not lifted bone stock
post #8 of 10 Old 12-06-2012, 10:48 PM
Coolcatracing
Then you can only adjust toe and something would have to be really worn out or bent to need anything to align it.
post #9 of 10 Old 12-06-2012, 11:50 PM
1222
RIP John
1222's Avatar
The ball joints, which by the way is somewhat common for the JKs.
(2011-2016)
1222 is offline
post #10 of 10 Old 12-07-2012, 07:30 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
What he said.....
The ball joints (at least when I purchased them) came as a kit, one "kit" per side.
Side note to other posts....camber is adjustable...with offset balljoints, of which I had to purchase to offset a bent outter "C"....worked like a charm.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
