multipoint seat harness question - JeepForum.com
post #1 of 7 Old 09-15-2010, 09:13 PM Thread Starter
rballman
I am looking at buying a 4 point harness with the camlock style. Anyone have this setup? Any cons with it?
Also, with new seat belts how does this work with the JKs computer? Do I need to disable/update anything so that it doesnt think my seat belt is not fastened?
2007 Wrangler X - Jeep Green, 4" lift, 4.88s, locked rear, custom bumper/fender/cage, rolling on 35s w/ 15s
Colorado Jeep Club member #2007
rballman is offline
post #2 of 7 Old 09-15-2010, 10:54 PM
newjk
are they street legal, just wondering.
newjk is offline
post #3 of 7 Old 09-15-2010, 11:18 PM
Warlord2
Im also interested in this, planning on getting some suspension corbeau seats with the harness slots. I cant see how they wouldnt be street legal, but I really dont know. The seat belt chime would also need to be turned off somehow.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #4 of 7 Old 09-16-2010, 06:23 AM
Vin
I would write the company that makes the belt and ask how it intergates with the OEM seatbelt/airbag system. If you were just to disable the seatbelt chime (which can be done) you have the issues of the computer believing you don't have your seatbelt on, which will impact it's deployment of the airbag, which could get you hurt.
Vin is offline
post #5 of 7 Old 09-16-2010, 08:40 AM Thread Starter
rballman
Yeah I would want to figure out how to keep the airbags setup correctly....
rballman is offline
post #6 of 7 Old 09-16-2010, 01:10 PM
CDavisJK
2009 JK Wrangler
schroth makes a DOT legal harness. But it's not something that you'd want to run on the street, or even on the trail. A harness is only good if you want to stay in one spot, like for track or desert racing. They make clips to install the harness using the same bolts as the stock 3-point. So just run the regular belt on the street and use the harness racing.
CDavisJK is offline
post #7 of 7 Old 09-16-2010, 01:21 PM Thread Starter
rballman
well i ended up buy a 5 point JDM camlock harness off ebay...not bad for only $24. I will probably use it without the crotch strap though.
rballman is offline
4 point harness , harness , JK Wrangler , seatbelt , wrangler
3 point harness seat options Taco88yj YJ Wrangler Technical Forum 5 11-28-2009 11:49 AM
Wire harness under drivers seat austin703 TJ Wrangler Technical Forum 6 01-17-2009 03:29 PM
Best seat belt harness? ballallday89 TJ Wrangler Technical Forum 5 06-09-2008 10:23 PM
5-Point Harness Seat Question KKiowaTJ TJ Wrangler Technical Forum 9 12-10-2007 09:45 AM
Rear Seat Harness? TJEFF G TJ Wrangler Technical Forum 10 04-01-2007 07:08 AM
