Multiple clicks, no start. Help! - JeepForum.com
post #1 of 8 Old 03-10-2013, 10:02 AM Thread Starter
Phil6mac
I was installing a daystar switch panel and shifted the shifter to 1 (moved towards me for more space to install lower dash panel). Also moved the 4wd shifter back too. 08 jk started fine before this...now, when I try to start, it seems to have enough power, but I just get a click...click...click... Checked battery and iod fuse, disconnected the battery and hooked back up, still no start. The keyless entry still works. Thoughts?
Phil6mac is offline
post #2 of 8 Old 03-10-2013, 10:28 AM Thread Starter
Phil6mac
Also, it does not start in neutral.
Phil6mac is offline
post #3 of 8 Old 03-10-2013, 12:17 PM
wilywillie
If you have the elec package, that's a huge can of worms....but have you tried with your spare key? Did you disconnect your battery before you modded the wiring? Triple-checked that the wiring was all as it was? UNDID it all back to OEM?
just some ideas...
I'm just here for the gasoline. --Max
wilywillie is offline
post #4 of 8 Old 03-10-2013, 04:23 PM
442Wrangler
In like Flynn.
442Wrangler's Avatar
Sounds like a dead battery, did you try charging it?
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #5 of 8 Old 03-10-2013, 06:49 PM Thread Starter
Phil6mac
Yep. Battery was completely dead. Needed a good charge. Going to look into an optima yellow top...
Phil6mac is offline
post #6 of 8 Old 03-11-2013, 07:17 AM
xkuzme1
I'd read up on the Optima. People have been saying that they are not as good as they used to be. General consensus is the Die Hard is the way to go.
X
JEEP - The original "search engine".
Ask me why you should not buy anything from 4 Wheel Online
xkuzme1 is offline
post #7 of 8 Old 03-11-2013, 08:35 AM
442Wrangler
In like Flynn.
X
I have had good luck with my energizer for what it's worth.
2008 JK Rubicon
1959 Willys Wagon
-Steve McQueen
post #8 of 8 Old 03-11-2013, 12:57 PM Thread Starter
Phil6mac
I'll look into those options as well. Also, the optimas are a bit pricey.
Phil6mac is offline
