#1 | |
most popular lift kit ?
hi i just bought a 08 4 door wrangler unlimtied x and i would like to put a lift on it . i was wondering what the most popular lift kit being used is? I would like a 3 to 4 inch lift . thanks for all the help !
#2 |
full traction seems to be popular where I live. I put one on my jeep and love it, a little stiffer then stock but I like it this way much better. My 3" lift with HD springs got me actually 4" rear and 5" front, prolly will drop a little once I put bumpers and winch on though.
Other populer lifts are the black dimond and skyjack both make a sweet 3 or 4" lift. Depends on what you want and how much you wanna spend, mine was the ultimate lift thats $2k but nice ones are as low as $650. ![]()
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights. Last edited by Warlord2; 01-20-2008 at 01:23 PM.. |
#3 |
you have a great looking truck ,thanks for the information. i was looking at the 4 inch skyjacker. but i will also check out the one you recomended. i was just looking for a nice mid level lift. anyone use rustys lift the local jeep dealer here installs them ,also how much does installation usually cost ? thanks alote !
#4 | |
you didn't indicate if you bought an auto or manual?
I've been researching a bit, and have discovered that the Unlimiteds with auto transmission have a problem with tearing up the front driveshaft boot with any lift over 2". The problem is that the new angle of the driveshaft causes the boot to rub against the transmission skid plate, especially when flexing off-road. Again- only occurs with auto transmission Unlimiteds And from what I've been reading- Jeep does not sell a new boot, you have to replace the entire driveshaft. But that is really irrelevant because if you just replace the boot, it is going to tear again. The only real solution is a smaller diameter aftermarket driveshaft.
for details and info on our JK's, check out http://n2rock.com His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list Hers: '08 X Red Rock, soft top, auto. Bunch of mods Quote:
#5 |
hey thanks for the information about the boot . it is a automatic , i really would like a 3 1/4 or 4 inch lift, what do you think the best option would be . is their anything else to do beside stay with a 2 inch lift ? thanks
#6 |
The Road Goes On Forever
Out of curiosity, why do you want a 4" lift? What are you trying to fit under there? From the CJ to YJ to TJ, 4" was common. With the JK, you don't have to lift it that much to slap on some 33s or even 35s.
'08 JK Unlimited Rubicon, Steel Blue Metallic, Auto, 33"s, 2.5" RE, 6" KC's, Drake Hood Latches |
#7 |
well i was going to just put on 35 " tires so maybe your right maybe 3 or 3 1/4 would be fine. i just figured if i was goin to lift it , i would go ahead and get a 4 inch but maybe thats to much? i like the look of the bigger lifts . but maybe that would nt be smart ? just figured i would see what everyone thinks? anyone use BDS lifts they seem to have a nice 3 " lift ?
#8 |
im about to get a rubicon express lift i have herd alot of good things about them, my other advice is to go with the bigger 4in because i wished i had lifted mine the right way first
Build Thread: http://www.jeepforum.com/forum/f9/2001-tj-build-thread-attempt-2-a-683648/
2001 Jeep TJ, 1in JKS Body Lift, 35x12.50x15in Goodyear Mtr's and a RE 4.5 SF with AA sye, tom woods custom cv drive shaft, tnt tube fenders w/3in flares and flush mounted led turn signals, 1in mml, cobra cb and firestik, custom rock sliders, herced, trail scars Looking for 4.88s (R&P) for a d44/d30 PM me |
#9 |
the rubicon express lift is not for the 4 door right ? is their a rubicon lift made for the 4 door ?
#10 |
Gold Member
I have Black Diamond 3" with 35's and an automatic. No issues here with my cv boot.
N2Rock, the problem is with lifts 3" and greater and is worse on the 2 door than it is on the 4 door. The reason is because of the angle of the driveshaft. The stock driveshaft uses a cv joint on one end, which cannot handle as much of an extreme angle as an ordinary universal joint. The solution is to replace the driveshaft with one that uses regular universal joints. Several companies make these. I just checked mine the other day when I had it jacked up and it is fine after 7,000 miles of being lifted with 35's and seeing mud and severe pot holes daily.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, BFG AT TA KO 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Bilstein 5100 series shocks, 5.13 gears, Alpine IDA-X001, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650 http://www.jeepforum.com/forum/f129/hothead-headliner-1237401/ http://web.me.com/stevenpeltierjr/Living_It_Up/Welcome.html |
#11 |
there is a 3.5 and 4.5 for the four door
Build Thread: http://www.jeepforum.com/forum/showthread.php?t=683648
#12 |
DETN8R
R.E. makes great kits for the 2 dr and the 4 dr. in 2", 3.5" and 4.5". They have super flex and long travel kits.
http://www.rubiconexpress.com/Jeep.aspx?Vid=4142FE4725216
'08 DETN8R Yellow Unlimited Rubi 6-Spd / Soft top / Power / Side Air Bags Installed: R.E. 3.5" (4" now) Super Flex Kit & Ft. driveshaft/Full Traction Rear Adj. Trackbar/Rancho (4" long arm) 9000XL shocks/Superior 4.88 Gears & Evo Rear Axle Shafts/37" Goodyear MTR's/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Prototype Rear Bumper/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant/Cobra 75 WS XT C.B./Prototype Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on custom mount & brace... ____oooo [ l_,[____], l---L -[OlllllllO] ( )_) ( )_)--)_) |
#13 |
I have a Black Diamond 3" lift, auto trans. I was very happy with the kit. I did distroy my front driveshaft boot on my last off road trip. I was told that this will happen sooner or later, so it was no surprise.
08 jeep green rubicon unlimited, Dual tops, 3" Black Diamond lift, Poly Performance rear adjustable track bar 3/4 front leveling spacers, Reel drive lines, 35/12.50/17 BFG KM2's, Shrock works mid-length front bumper, warn 9.5ti winch, windshield mounted kc lights, trail guide navigation, uniden 510 cb. |
#14 |
Gold Member
Most popular? No, it's not-- in fact though Fabtech is super popular around where I live, it doesn't seem to be terribly popular on this board.
But just for another option, here is my 3" Fabtech lift (with 35s) |
#15 |
thats a great looking truck ! one of my favs that ive seen here, yeah i always have liked fabtech lifts, i had one on my last truck. and i really liked it but i have noticed not as many people where using them here. i like the rockstars also i had them to .. nice combo ! are you happy with the fabtech lift ? did it turnout to be exactly 3 inchs of lift ?
| Tags |
| JK Wrangler, lift advice, lift choices, lift oppinions, wrangler |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
