More of a Tinkering Thread than a Build Thread (smcutter) - Page 5 - JeepForum.com
post #61 of 205 Old 02-18-2013, 05:40 PM Thread Starter
smcutter
LED Interior Lighting
Having grown incredibly frustrated with the terrible interior lighting in my Jeep, I decided I wanted to implement a solution that would provide very even lighting in the front and back of the Jeep, wired to the battery and controlled by a single switch. I wanted to avoid the solutions that provided a single halogen or LED lamp and the awful shadows that you get when the light comes from a single point of origin.
Last summer, I removed substantially all of the roll bar cover and styrofoam and sold it on Craigslist. All it was doing was getting dusty anyway, so I figured removing the padding would enable me to utilize the roll bar for more creative purposes. Not having the padding is the only reason I was able to use the adhesive backing on the LED strip, so if you aren't willing to scrap the padding you may not be able to implement this as cleanly.
First, the materials used:
HitLights LED Flexible Lighting Strip Cool White or Bright White, 5 Meter or 16 Ft, 3528 Type, 300 SMD, 24 Watt
HitLights LED PCB Strip to Strip Connector, 2 Conductor, Any Angle Turn, For SMD3528 LED Strip Lights (4 Pcs Pack) (You will have to cut this in half and strip the wire so it will connect to the switch and ground)
Daystar KU80014 20 Amp Red Light Rocker Switch Kit
In addition, I used 18-gauge red and black wire along with the necessary terminals and connectors to get power to the Strip to Strip Connectors. I put an ATM mini fuse holder and 10 Amp fuse between the battery and the lights, just to keep things safe. I ran the positive cable across to the driver's side and through the firewall, then up to the Rugged Ridge A-Pillar Switch Pod. From there, it's as easy as grounding the negative side of the LED Strip and running the positive side through the Daystar rocker switch. Carefully route the LED Strip around the roll bar using the adhesive backing where possible, and you're golden. The end of the LED Strip that does NOT connect to the switch should just be left completely unattached to anything.
NOTES
  • As mentioned above, you will need to cut the Strip Connector in half. Each end of the Strip Connector is designed to connect to a specific end of the LED Strip. If you get no light and are certain that you are getting current, either try plugging it in to the other end of the LED Strip, or try it with the other half of the Strip Connector. If I had realized this sooner, I would've saved myself 45 minutes of frustration.
  • You don't technically *need* the Strip Connectors, actually. But you will need them if you want to be able to trim either side of the LED Strip as needed. The LED Strip came with a black and red wire coming off of one end, so if you don't trim that side you can forego the Strip Connectors.
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #62 of 205 Old 02-18-2013, 06:19 PM
1222
RIP John
1222's Avatar
I have to be honest; the first thing that came to mind was the movie Close Encounters of the Third Kind.
Now that I said that (sorry) what you did is pretty unique.
1222 is offline
post #63 of 205 Old 02-18-2013, 06:28 PM Thread Starter
smcutter
I have every intention of driving it across the New Mexico desert with the top down and door off this summer. Between the HID headlights and the LED interior lights, I'm certain to be mistaken for a UFO.
smcutter is offline
post #64 of 205 Old 02-18-2013, 06:41 PM
1222
RIP John
1222's Avatar
^^^That would be so cool if calls started to come into the local news about a low flying UFO in your area.
Iím just having fun with you but in all seriousness I think your light mod is really cool and definitely solves the crappy interior lighting of the JKs.
1222 is offline
post #65 of 205 Old 02-25-2013, 09:32 PM
bamfurlough
I'm liking the modest nature of your build/tinker thread. It also seems to have a photography theme as well. I'm not complaining.
It's easy to get discouraged reading some of these build threads. I'm not really gonna have 20 grand and a shop full of tools when I get a Jeep.
Saving for a Jeep.
Y'all are helping me do research.
bamfurlough is offline
post #66 of 205 Old 02-25-2013, 10:30 PM Thread Starter
smcutter
Thanks! Aside from the winch and bumper, I probably only have about $800 into my Jeep. I don't think any of those projects have cost more than $200 (the HID headlights were $199 even), so I'm pretty pleased with how well I've been able to get my tinkering fix without having to sell my photography equipment to do it.
smcutter is offline
post #67 of 205 Old 02-26-2013, 06:27 AM
BigBlue7
2010 JK Wrangler
Yep! Subscribing for more pictures! Def dont sell your equipment, you should come to AL and take some pics for me!
Rock Krawler | TeraFlex | Synergy | Fox | Poison Spyder | Genright | Nemesis |Beer
BigBlue7 is offline
post #68 of 205 Old 02-26-2013, 09:04 AM
Tanimal
Very unique mounting idea but how are those things when you're driving? I feel like you turn them on and instantly blind yourself and other drivers.
Learning as I go and it's worth every penny!
Tanimal is offline
post #69 of 205 Old 02-26-2013, 07:06 PM Thread Starter
smcutter
They're a little brighter than I'd like, but they aren't blinding if I'm ready for it. I think I'm going to order a waterproof strip that has a gel-like coating over the LEDs, then use black spray paint to both dim the lights and make it blend in better with the roll cage when they aren't lit. I have a 12" strip left over that I'm going to spray to test how bright the strip is after painting it.
smcutter is offline
post #70 of 205 Old 02-27-2013, 11:38 AM
Tanimal
This sounds like a good idea and I'd recommend VHT Nightshade which you can pick up at Autozone. I did my marker lights over a year ago and it has held up awesome and the light shines through without completely covering it like spray paint would.
Tanimal is offline
post #71 of 205 Old 03-03-2013, 08:51 PM Thread Starter
smcutter
I'll definitely give the VHT Nightshade a try. I placed an order for weatherproof *warm white* LED strip after receiving feedback from two girls that they found the cool color temperature to be unflattering and harsh. They weren't wrong, either. I should have the LED strip replaced at some point this week and I'll be sure to post up comparison photos. I'll set my camera on manual exposure and manual WB so I can get a true comparison.
smcutter is offline
post #72 of 205 Old 03-04-2013, 12:51 AM
MeatCurtains
That is some killer interior lighting. I'm really planning on doing something along those lines, but my roommate is bailing, and I've got to find a new place. So my Jeep funds for the short term expired.
MeatCurtains is offline
post #73 of 205 Old 03-04-2013, 01:37 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Try this before painting over em...
Dimmer
The wife and I just remodeled a china cabinet and added LEDS - this works GREAT.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #74 of 205 Old 03-04-2013, 04:05 PM
442Wrangler
In like Flynn.
442Wrangler's Avatar
Just keeps looking better and better. Just noticed the Pearl Pass pictures. Did you happen to stop in Ashcroft? Probably one of my favorite ghost towns out that way.
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #75 of 205 Old 03-04-2013, 04:06 PM
442Wrangler
In like Flynn.
Dimmer
Where would he put it? Just a curious question as it looks a little large...
2008 JK Rubicon
1959 Willys Wagon
-Steve McQueen
Bob's Build Thread cubewhiz YJ Wrangler Technical Forum 67 08-11-2012 09:25 PM
TJ on 42's (Build Thread) TrailWorthyFab TJ Wrangler Technical Forum 743 03-27-2012 07:50 PM
Got my build thread, what does this mean iceman123187 TJ Wrangler Technical Forum 4 04-12-2010 06:34 PM
Just Another YJ Build Thread MYYJ93 YJ Wrangler Technical Forum 13 01-29-2010 10:23 PM
TJ Build thread? moparjunkee TJ Wrangler Technical Forum 6 03-05-2008 01:40 AM
