Mopar Speed Control Install - Page 2 - JeepForum.com
post #16 of 21 Old 10-11-2010, 05:58 PM
Charles
2017 WK
Originally Posted by Warlord2 View Post
hey, that looks pretty nifty. That option has been really the only thing that Ive been missing on my jeep. I wanted to know if the speed control works even when you are at 3500+ rpms? Ive had some vehicles that stop working at a certain rpm and I have a high crusing rpm after the regear.
It will.
Charles is offline
post #17 of 21 Old 10-11-2010, 06:44 PM
tavic
2010 JK Wrangler
If Chrysler hasn't changed it, the cruise will not work under 35mph.
tavic is offline
post #18 of 21 Old 10-11-2010, 07:32 PM
Charles
2017 WK
I use mine at 25...I think it doesn't work below 25.
The manual does say though:
When engaged, this device takes over the accelerator
operation at speeds greater than 35 mph (56 km/h).
Charles is offline
post #19 of 21 Old 10-15-2010, 03:39 PM
ve7it
2010 JK Wrangler
Airbag removal tool
I just completed installing the cruise control option using the parts as above.
Notes:
  • Take an old screw driver and bend it just past 90 degrees as shown in attached picture. Mine broke, so i re-bent it and ground a flat tip with the angle grinder. Heat will help.
  • Use a mirror and flashlight to look into the opening on the bottom back of the steering wheel. You will be able to see the wire loop you are trying to release.
  • Park the jeep with the wheel straight and level before you disconnect the battery. This makes things more intuitive when putting the wheel back on.
  • Release the loop at the 6 o'clock position first... it is the easiest one. With the bent screwdriver, the loops are quite easy to release. As you release the loops, dont let the airbag fall off and damage the connections.
  • I just cut a slot in the plastic trim piece instead of buying a new trim piece. Saves $8 or so. You need about 1/8" (3mm) clearance around the control shaft so the control can move up, down and toward the driver without binding on the plastic trim piece.
  • Control and wiring harness cost just over $100Cdn from dealer parts desk with new owners 10% discount.
  • After you remove the steering wheel bolt, look carefully at the 12 o'clock position at the spline... there is an arrow on the steering wheel center casting and a punched dot on the steering column shaft.. makes things easy to line up again.
  • Cruise will engage at 40kph(25mph) or greater on my 2010 model.
  • cruise control lever: Mopar 4671929AB list $33.15Cdn
  • horn switch harness: Mopar 68003477AA list $75.40Cdn
  • wheel cover trim: Mopar 1GA31XDVAA list $ 7.45Cdn Not needed, check color
Last edited by ve7it; 10-16-2010 at 04:16 PM. Reason: picture not working, added mph conversion, added part numbers and prices
ve7it is offline
post #20 of 21 Old 03-05-2014, 04:01 AM
3S00W
2009 JK Wrangler
How do I verify that the engine needed components are there before doing this? Did all the engines come preinstalled and just needed this to complete it? The ECM alrdy programmed too?
3S00W is offline
post #21 of 21 Old 03-05-2014, 04:43 PM
ve7it
2010 JK Wrangler
The new wranglers are already fly by wire. (you will not need under hood parts like the old throttle servos). The ECM seems to be quite happy without any programming. In my 2010, the throttle control arm plugged in and worked.
cheers
ps, in the post a couple of items up, the picture of the bent screwdriver seems to have been deleted.... any old flat blade driver with the shaft bent at 90 degrees should work... once you find the wire loops to release, the tool required should be obvious.
ve7it is offline
cruise control , installation , installation kit , JK Wrangler , troubleshoot , wrangler
Jet Accu Speed Control Unit Install Help flightmechs TJ Wrangler Technical Forum 0 10-31-2009 11:33 AM
Mopar Speed Control Install? Kastiron JK Wrangler Technical Forum 3 03-22-2008 09:31 AM
Speed Control Install, 2.4L SpitNine TJ Wrangler Technical Forum 1 07-24-2007 07:18 AM
Install Speed Control? solbergg TJ Wrangler Technical Forum 20 11-05-2006 10:27 AM
Cruise Control - has anyone installed the Mopar kit? NewYorkCity_TJ TJ Wrangler Technical Forum 1 05-06-2005 03:24 PM
