Mopar Speed Control Install? - JeepForum.com
post #1 of 4 Old 03-20-2008, 09:01 PM Thread Starter
Kastiron
Has anyone tried to install one of these yet? http://www.4wd.com/productdetails.aspx?partID=15952#
Mopar Part #82210216
I am thinking of adding it to the 08 JK with the 6 speed.
The same part on quadratec sells for much more, but has a difficulty level of "easy".
According to the picture, it looks like it may be pretty straightforward, nearly plug and play. Would it require a trip to the dealer to get flashed, or would it goof up some warranty?
EDITED TO ADD: Search is my pal, found the answers and plan to try it soon.
08 JK 4 Unlimited in Jeep Green. 6 speed manual, soft top. Miles to date: 15,472 since Jan 18, 2008.
Kastiron is offline
post #2 of 4 Old 03-21-2008, 06:20 AM
Impster
I installed this yesterday in my 07 X
I am not sure on the warranty. It's a mopar part, so I don't think it should void it.
After installing, it worked without a problem. No need for a trip to the dealer.
Here is a decent write up of the install:
http://jk-forum.com/showthread.php?t=14412
A quick search on this forum showed no results for a write up of the install.
They are not kidding when they say use a "stubby" screwdriver. I didn't have one and ended up destroying the plastic cover (which is replaced with the install anyway) to get at the airbag clips.
Impster is offline
post #3 of 4 Old 03-22-2008, 12:42 AM
ogre45
I got mine off ebay for about 185 shipped.
X2 on the airbag clips and no need to go to the dealer. definitley make sure the battery is disconnected messing with the airbag was a little nerve racking for me even with the battery disconnected.
Alex
07 Unlimited X, Red Rock, Daystar upper & lower dash panel, RR side steps, Delta fogs, Skid Row front skid & engine skid
ogre45 is offline
post #4 of 4 Old 03-22-2008, 10:31 AM
sightor
I installed the Mopar unit on my 07 X. Plug and play when you finally get the center section of the steering wheel off that contains the airbag.
sightor is offline
Mopar Speed Control Install wTheOnew JK Wrangler Technical Forum 20 03-05-2014 05:43 PM
Jet Accu Speed Control Unit Install Help flightmechs TJ Wrangler Technical Forum 0 10-31-2009 12:33 PM
2006 Mopar Cuise control help burn1ch TJ Wrangler Technical Forum 6 05-21-2009 10:05 PM
Speed Control Install, 2.4L SpitNine TJ Wrangler Technical Forum 1 07-24-2007 08:18 AM
Install Speed Control? solbergg TJ Wrangler Technical Forum 20 11-05-2006 11:27 AM
