Mopar Bumper Light Bar Wiring - JeepForum.com
post #1 of 6 Old 12-01-2012, 06:31 PM Thread Starter
Gregg-Roc
2012 TJ Wrangler
Does anyone know if the Mopar bumper mount light bar (link below) allows the wires to be run through the bar? I like the look of the bar, and the fact that it holds three lights, but I would rather run the bars through the bar than through the grill.
If not, can anyone suggest a bar that allows the wires to be run inside the bar?
http://www.quadratec.com/products/12010_5100_07.htm
Thanks!
Gregg
Gregg-Roc is offline
post #2 of 6 Old 12-01-2012, 06:43 PM
J33PNSL33P
No it's not set up to have the wiring ran through it. It is hollow though and what I did is drill a hole behind each of the three light brackets and ran my wiring through the inside. Worked perfectly
J33PNSL33P is offline
post #3 of 6 Old 12-01-2012, 07:11 PM
JTPhoto
JTPhoto's Avatar
This one, MBRP Grille Guard, you can run the wires inside the pipe..
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline
post #4 of 6 Old 12-07-2012, 03:00 PM Thread Starter
Gregg-Roc
2012 TJ Wrangler
Does anyone know what this wiring harness is for on a 2012 rubicon unlimited?
post #5 of 6 Old 12-07-2012, 03:28 PM
pmraider12
Ambient temp sensor.that gives you your degrees in your evic.
'12 JK Wrangler-Oscar Mike-2.5 rock krawler,5100's,315's
'97 Cherokee-6.5,Locked,35's,Sold
'92 Mustang 347,5sp,373
pmraider12 is offline
post #6 of 6 Old 12-07-2012, 03:59 PM
JTPhoto
JTPhoto's Avatar
That's your outside temp dash thermometer sensor.
^^Jeff^^
JTPhoto is offline
