Moony's "Big Red" 08 JK Build Thread - Page 18 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Moony's "Big Red" 08 JK Build Thread
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 09-07-2013, 09:46 PM   #256
BamaJeepman21
Love the Jeep man. Those Moabs really made the look.
What camera do you use?
Wanted: Savvy/Currie 3" front springs
-Jack
BamaJeepman21 is offline   Reply With Quote Quick reply to this message
Unread 09-08-2013, 12:00 AM   #257
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
I actually ended up getting my other wheels and tires back, I like them both equally. Will always like the moabs but the km2's ride way better than the kevlars.
I use a Nikon D90 with a 50mm 1.8
MoonyJohn is offline   Reply With Quote Quick reply to this message
Unread 09-08-2013, 12:25 PM   #258
platinum5.9
platinum5.9's Avatar
2003 WJ
What gears are you running? Would it make sense to do gears first to see how it feels before dumping that much $ on a Ripp system?
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline   Reply With Quote Quick reply to this message
Unread 09-08-2013, 01:09 PM   #259
BamaJeepman21
This.
3.73s, 35's, and the 42rle has to suck worse than 33's and 3.07s...and that's pretty bad.
-Jack
Unread 09-09-2013, 02:12 PM   #260
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
Yeah I was over reacting a little lol, what gears should I be running? The max tire size I would run is a 37.. 4.88?
Unread 09-09-2013, 03:40 PM   #261
BamaJeepman21
5.13 for 35's.
5.38 for 37's.
Pretty sure the deepest a JK D30 can go is 5.13 though. Might be wrong on that.
Edit: My God, you're running at 1600rpm at 65mph right now. That has to be awful.
-Jack
Unread 09-09-2013, 09:13 PM   #262
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
5.13 for 35's.
5.38 for 37's.
I dont think its 1600.. Ill have to re look, I usually keep OD off anyways. But that low RPM is nice on the flats, better mileage Before the hills I was getting around 18 going 70.
I wouldnt got any lower (or higher) than 5.13) those teeth are tiny from what I've heard.
Unread 09-10-2013, 09:06 AM   #263
jaidmaster
I regularly switch between the stock wheels/tires and the 35" Kevlars. I think the kevlars actually ride smoother than the stock bfg muds.
I opted for the Superchips FlashCal for speedo correction.
4.10's with the 3.6l is pretty good even in the CO mountains. Getting about 18mpg with the 35's and 20mpg with stock (2 door).
Happy Jeepin!
jaidmaster is offline   Reply With Quote Quick reply to this message
Unread 09-11-2013, 02:22 PM   #264
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
Ok so it's 1600 at 65.. What would 5.13 be?
Unread 09-11-2013, 03:17 PM   #265
BamaJeepman21
Happy Jeepin!
18mpg and 35's? I need to get a new JK.
It would put you right below 2,300. Perfect RPM for cruising.
-Jack
Unread 09-13-2013, 07:31 PM   #266
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
Hm, sweet. Tax returns next year will go towards that then haha.
Picked up a set of those smittybilt tire deflators, look nice. Will try them out tomorrow with my buddy chad (blackwhiteriot).
Pictures tomorrow ofcourse!
Unread 09-15-2013, 03:46 PM   #267
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
As promised pictures. Didnt do anything too hard but it was still really fun. Deflators worked great, doors off is the best thing ever. Especially when its almost 90 degrees out
When it was clean the day before..
Aired to 15psi, tires flex good, room for a 37 maybe?
And a nice drive back home with no breaks!
Unread 09-19-2013, 02:24 PM   #268
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
Thinking of getting a 50" led next week, was looking at getting a spot light instead of a flood light. Any preference? I would mainly use it for back roads driving..
Unread 09-19-2013, 02:41 PM   #269
DangFoo
I Had Bacon Today
DangFoo's Avatar
Wow, Jeep is looking very nice - excellent setup you have going there.
DangFoo is offline   Reply With Quote Quick reply to this message
Unread 09-22-2013, 04:18 PM   #270
zjilla
bumpers in the near future?
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
www.annirlane.blogspot.com
October 2013 JK of the month
My Slowly but surely JK build thread:
http://www.jeepforum.com/forum/f96/s...hread-1562595/
zjilla is offline   Reply With Quote Quick reply to this message
