Missing courtesy Lamps - JeepForum.com
post #1 of 31 Old 01-04-2007, 04:13 PM Thread Starter
spolebitski
I know many people have been reporting missing courtesy lamps from under the hood and driver side foot well. When I picked up the vehicle (December) I noticed the wires under the hood and they swapped a lamp from another vehicle. I did not have a lamp in the driver side foot well. I contacted Chrysler they said it was listed on my vehicles parts but I need to contact the dealer to have this taken care of. When I contacted the dealer they said in the days after I picked up my vehicle they received a TSB stating that they were discontinuing the courtesy lamps (thus is I originally did not have the lamps to begin with).
Bottom line is that the dealer is saying these curtsey lamps are no longer available on the vehicles. What do you think? I could not find the TSB (Online) but then again I do not work in service either. If you took delivery did you have the courtesy lamps or were they missing?
spolebitski is offline
post #2 of 31 Old 01-04-2007, 05:15 PM
doojer
Go to jeep.com and print out the "options and upgrades" page for the 2007 Wrangler Unlimited. It clearly lists the footwell and underhood courtesy lamps as standard on every model.
- Jeep Green, Auto, 4:10, D30 front/D44 rear, RockCrusher Diff Covers
doojer is offline
post #3 of 31 Old 01-04-2007, 05:50 PM
Rokitt
Mine came with them. The dealer's response does not sound correct to me. I would definantely speak with someone else at the dealer on this matter.
Rokitt is offline
post #4 of 31 Old 01-04-2007, 08:07 PM
cmh2001
2013 WK
Footwell lamp? i didn't know i was supposed to have one...
cmh2001 is offline
post #5 of 31 Old 01-04-2007, 08:29 PM Thread Starter
spolebitski
Do you have a lamp under your hood?
post #6 of 31 Old 01-04-2007, 08:32 PM
Rocky529
Rocky529's Avatar
I believe those are the ones shining down on both the driver's and passenger's feet inside the vehicle.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #7 of 31 Old 01-05-2007, 05:49 AM
Rokitt
Passengers feet ?? uh oh. Im missing that one.
Rokitt is offline
post #8 of 31 Old 01-05-2007, 10:02 AM
jeeptj19992001
ask the dealer to show you the tsb......if he can not show you it then get your light
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #9 of 31 Old 01-05-2007, 10:56 AM
doojer
There is no passenger side footwell light. Only driver's side....
doojer is offline
post #10 of 31 Old 01-05-2007, 12:06 PM
paul olllllllo
Location: royal oak michigan (hometown of DR. JACK KEVORKIAN)
sounds like the dealer is blowing you off. your jeep should have the same "standard" features as the jeeps that they have on the sales lot.....look at the jeeps on your dealers lot and see if they have the light.
2008 Flame Red "Captain America" Unlimited.
paul olllllllo is offline
post #11 of 31 Old 01-08-2007, 11:43 AM
JRunner01
Missing Lamps
I just picked up my 07 Ruby 4dr last week and it too does not have a bulb under the hood. All that exists there is a wire harness zip tied to the hood with an empty socket, which I assume takes a bulb.
Havent checked for a similiar situation under the drivers footwell, but I know I have no light coming from under there.
Does anyone have a wire with a socked under the footwell with no bulb as well?
Thanks...
JRunner01
JRunner01 is offline
post #12 of 31 Old 01-08-2007, 12:17 PM
07RUBI
My 2 dr Rubi also just has the harness and no light. I think I read somewhere that a '06 under hood light works with the harness.
07RUBI is offline
post #13 of 31 Old 01-16-2007, 12:33 PM
JRunner01
Dealer is requesting a copy of my window sticker to get this issue rectified. Not sure why, the sticker doesn't indicate these two lamps as standard equipment anyway, but the website does. Unless he needs some code from the build plant. Has anyone else got their two lamps added? Also has anyone found a wire harness for the lamp under the driver foot well? I cant find one. Only under the hood I can see one clear as day.
post #14 of 31 Old 01-17-2007, 04:33 AM
JoiseyJeff
JoiseyJeff's Avatar
My 07 had no lamp under the hood either. However when I checked my receipt/invoice from my climate control cable repair I noticed this was on the bill as well:
INSTALL UNDERHOOD LAMP AS PER CHRYSLER
Qty 1 Part 56021441 LAMP UNDE 8014001
Qty 1 Part 6502632 RIVET NON 18050043
Looks like if you are missing the lamp just bring it to the dealer for a free one. They did this without me even asking..........
89YJ Sahara, Best Jeep I ever had to sell
90MJ 2nd Best Jeep I ever had to sell
93ZJ Might sell soon.
07JK Sahara Rescue Green
JoiseyJeff is offline
post #15 of 31 Old 01-17-2007, 06:56 AM
JRunner01
Does anyone have or have gotten installed the lamp under the drivers foot well???
Tks...
Courtesy lights johnson1178 YJ Wrangler Technical Forum 8 05-11-2010 08:18 PM
No power to courtesy lamps radio lighter rmorrison9773 YJ Wrangler Technical Forum 3 10-06-2009 11:00 AM
99 TJ Courtesy Light VLT TJ Wrangler Technical Forum 0 10-10-2007 12:12 PM
H4 Headlight Upgrade - Cibie Lamps/IPF MG or IPF920H Lamps w/IPF 80/110 Bulbs selmo_yidna TJ Wrangler Technical Forum 6 12-26-2005 03:51 PM
courtesy light kstt YJ Wrangler Technical Forum 5 05-30-2003 07:14 PM
