Missing air dam, what to do - Page 2 - JeepForum.com
post #16 of 27 Old 05-02-2013, 09:23 PM
Derrick_Merwin
Where did you find that skid plate and how much is it?
Derrick_Merwin is offline
post #17 of 27 Old 05-02-2013, 09:28 PM
ncb
ncb is offline
post #18 of 27 Old 05-03-2013, 09:28 AM
Spike6901
I took mine off while in the middle of the bumper install that I could not finish all at once. So, I drove without it for a couple of weeks and hood would flutter bad enough that it would hit the stop with a clunk.
After intalling a stubby, it was better but would still dance around enough to make my wife squirm. It would also 'feel' like it was catching enough wind that it would slow down the Jeep.
I replaced the rubber hood straps with a pair of Daystar ones and that sucker is solid as a rock now.
'17 JKU, '97 ZJ - Built
Past: CJ-7, XJ, KJ, JKU
Spike6901 is offline
post #19 of 27 Old 05-03-2013, 09:28 AM
starscream
1981 CJ5
Aside from the hood wobble, it adds about 1 extra mpg to your fuel economy. I know this because I took mine off, drove for about 2 weeks with it off, saw the mpg drop, put it back on, saw the mpg go back up.
starscream is offline
post #20 of 27 Old 05-03-2013, 09:44 AM
Wavedatya
2010 JK Wrangler
Mine got ripped off. Favorite mod yet!
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #21 of 27 Old 05-03-2013, 11:00 AM
Derrick_Merwin
If you put that mopar skid plate on does it do the same thing as the air dam so it would add protection and be used as a replacement to the air dam?
post #22 of 27 Old 05-03-2013, 12:06 PM
tomthbomb
CJ7 1/2 Top Club mem. #1
tomthbomb's Avatar
1978 CJ7
I tossed mine in the garbage
Same here!
The air dam helps keep the hood from fluttering
Could be. I did this:
This is true. Still didn't put it back on.
1978 CJ-7 original owner; AMC 401 V-8 (w/some goodies);NP4500;D300 (w/Curry 4:1); D44 front;AMC20 (Warn one piece axles) rear
tomthbomb is offline
post #23 of 27 Old 05-04-2013, 05:17 AM
tankinyj
Took that piece of crap off with less than 1k on the odometer
2012 JK, 44s, rubi case, 37" PBRs, stretched 8"
Crush Orange Jeep Member #55
NYC Jeep Club
tankinyj is offline
post #24 of 27 Old 05-04-2013, 06:35 PM
metaldemon7
I had hood flutter the first day I own my JK, with that piece of plastic on. This was on the drive home from the stealership. A big gust of wind made the hood jump pretty good. The next day I went to OK4WD, and got the Daystar straps. I took off the air dam, and installed the straps. Never looked back.
metaldemon7 is offline
post #25 of 27 Old 05-04-2013, 06:45 PM
rha600
Mine is still in the garage if anyone wants it.
I am trying to find a good skid that will protect mine. The rampage products bumper doesn't have a counterpart for the stubby I have.
rha600 is offline
post #26 of 27 Old 05-06-2013, 09:27 AM
Derrick_Merwin
Originally Posted by ronjenx
Another thing the air dam does is lower the pressure in the engine bay, which promotes air flow through the radiator.
I removed the plastic air dam, and installed a steel skid plate.
In the second picture, you can see how it protects the e-disco.
Did you have to cut anything to instal that and how much does it weigh
post #27 of 27 Old 05-06-2013, 09:37 AM
ronjenx
ronjenx's Avatar
Didn't have to cut anything. I think the weight was around 20 lbs.
ronjenx is online now
