Miles to the gallon - JeepForum.com
post #1 of 26 Old 02-24-2007, 12:37 AM Thread Starter
chevyjeep
1952 M-38
Miles to the gallon
I have checked my miles to the gallon against what the computor tells me and it is off by 2 MPG higher (19 computor versis 17 calculated ). Is anyone else seeing this and is there a fix. My 1999 S-10 Blazer is almost perfect.
chevyjeep is offline
post #2 of 26 Old 02-24-2007, 04:57 AM
crankitdb711
It's not used to counting above 15?
crankitdb711 is offline
post #3 of 26 Old 02-25-2007, 09:11 AM
redpony03
are you stick or auto?
redpony03 is offline
post #4 of 26 Old 02-25-2007, 10:32 AM
jeremy2027
m computer says i only get 14mpg im going to fill up today and get some actual numbers if im only getting 14mpg it may be time for an intake and exhaust to try and boost those numbers
jeremy2027 is offline
post #5 of 26 Old 02-25-2007, 01:14 PM
bookerb
mine says between 22 and 23, lots of highway driving
1989 Sahara
2004 X
2007 X unlimited
bookerb is offline
post #6 of 26 Old 02-25-2007, 01:40 PM
jeepers3
I filled up my tank yesterday. Computer gave me 13.5mpg since last fillup (auto, city driving). That's down from 14 the previous time, and about 15 the time before that.
jeepers3 is offline
post #7 of 26 Old 02-25-2007, 02:06 PM
Matthew Davis
My computer reports 17.4 to 17.6. I have not checked to see if it is acurate.
Matthew Davis is offline
post #8 of 26 Old 02-25-2007, 02:26 PM
SecondTJ
SecondTJ's Avatar
sounds normal, the computer is not very accurate.
will it be close for some people, and off for others
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #9 of 26 Old 02-25-2007, 08:03 PM
jeremy2027
same here i avg'd mine today and it was 13.5 auto 255 70 18 4.10 gears i think im going to install a CAI and cat back
post #10 of 26 Old 02-25-2007, 11:36 PM Thread Starter
chevyjeep
1952 M-38
I am running a 2 dr automatic with 4.10, 32inch tires and mostly highway driveing.
post #11 of 26 Old 02-26-2007, 08:28 AM
4-cubed
Calculated 16.84 last night on fill up.
Manual Transmission and 3.21 gears.
4-cubed is offline
post #12 of 26 Old 02-26-2007, 09:01 AM
redrom01
JCOB-4-LIFE
redrom01's Avatar
I'm anywhere between 15.6 and 18.7. 15.6 for the normal day to day stuff (I only live a mile away from my office) and 18.7 when I'm taking long trips on the highway. So far the computer has been pretty accurate or as close as I would expect it to be.
-Jeep History-
1992 XJ - '00 till '04 - RIP (thanks alot dave)
1995 XJ - '03 till '07 - Sold to the HUB
______o00o
/__l_l_,\____\,__
l_---l_l__l----[ ]llllll[ ]
._(o)_)__(o)_)--o-)_)__
-Current Jeep-
2007 JK Rubi (Steel Blue)
Searching for an MJ
|»»l,[___],
l---L--OlllllllOČ
=~~~==oo==
()_) ()_)--<>-)_)
redrom01 is offline
post #13 of 26 Old 02-26-2007, 11:27 AM
bamrneck
6 speed, lots of rural and highway driving. Computer says 23.5 to 25. Manual check shows computer off. Getting right at 20. My GM's are right on the money. I've been wondering about this...................
bamrneck is offline
post #14 of 26 Old 02-26-2007, 02:08 PM
luckyjeeper
luckyjeeper's Avatar
When mine had the stock tires, my computer was 2mpg off as well. (when it read 21.5mpg, I calculated 19.5mpg)
With the 33's and the computer not yet recalib. for them, it's reading 18.8mpg and I calc. at last fillup 17.6mpg.
Not reallly any rhyme or reason to those numbers, so I'll be interested to see what happens when I take her in on the 10th.
BTW, 6spd, mix of hiway and intown, no hotrodding, even clutching/shifting, no evasive manuevers or transmission braking.
patrick
2007 JK X 2dr. 6spd.
Steel Blue Hardtop
Virescit Vulnere Virtus
luckyjeeper is offline
post #15 of 26 Old 02-26-2007, 05:06 PM
jeremy2027
I got only 13.5 miles real world hmm
10.01 Miles Per Gallon!!!...... :( stmpjmpr TJ Wrangler Technical Forum 44 06-19-2009 09:59 AM
22.5 Miles per gallon 06 LJ Rubicon Ole Yeller TJ Wrangler Technical Forum 4 05-02-2008 10:06 AM
Miles to gallon Jason21 YJ Wrangler Technical Forum 24 05-09-2007 06:05 PM
miles per gallon ejmonkey3 TJ Wrangler Technical Forum 33 12-26-2006 11:48 AM
Miles Per Gallon? skoke70 TJ Wrangler Technical Forum 12 05-19-2005 02:49 PM
