Might be an old question but thought I would ask. - JeepForum.com
post #1 of 5 Old 07-25-2014, 09:04 AM Thread Starter
bdhinkson
2010 JK Wrangler
So I am brand new to the forum and to the Jeep life. Just bought a 2010 JKU and was curious what ya'lls thoughts were on upgrading the air intake and exhaust. Searching through it looks like these mods seem to be a waste, so I wanted to know if my money was better spent somewhere else.
Thanks!
bdhinkson is offline
post #2 of 5 Old 07-25-2014, 09:36 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
For the most part - unless you change compression ratio, Cam profile/timing, valve size, cylinder head port shape/size, intake runner shape/size, ignition timing and fuel curve (last two controlled by computer algorithms) all of which determine the engines volumetric efficiency - changing intake and exhaust has negligible effect over the entire torque curve. It may have an effect to say the amount of torque at 3100 is increased but the amount at 2800 is decreased - no real gain and no way to measure it - seat of pants is NOT reliable because other senses (sound smell etc) effect your opinion (sounds faster and smells leaner so must be right?).
AND we drive at 1100 to 3500 - that range works best with small diameter (thus higher air velocity) intake. Increasing the size of the intake has the same volume of air moving much slower - less effective at lower RPMs. Just compare a 360 magnum head to a 360 head - the magnum makes more torque sooner than the 360 - and the ports are noticeably different!
If you have a 1/2 pipe supply a faucet with a 3/4 inch hose attached - would you get more flow by hooking a 1" hose to it? NO - same gallon per hour, as the faucet (just like the compression ratio, cam profile/timing, port shape and volume) is the limiting factor.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #3 of 5 Old 07-25-2014, 10:42 AM Thread Starter
bdhinkson
2010 JK Wrangler
Thanks for the detailed response! Having used those items in the past on other vehicles, I thought I would ask. Looks like I will be using those funds towards towards better off-road experience. Thanks again!
post #4 of 5 Old 07-25-2014, 06:05 PM
HappyTrails
HappyTrails's Avatar
In other words....NO!
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #5 of 5 Old 07-26-2014, 05:54 AM
HAFICON
Exactly.. *L* However there is nothing wrong with ditching the oversized stock muffler for something smaller and adding a snorkel.
315/70/17 Duratrac on MB Wheels
AEV 2.5 with M.O.R.E 1" body lift
Viair 450c, ARB Air lockers,
4.88's and TNT truss.
My build thus far.
HAFICON is offline
exhaust , intake , mods
