metalcloak game changer lite install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > metalcloak game changer lite install
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueRIGID LED Light Blowout Sale - All Sizes, All Series, all End of Summer Sale, 20% OFF!
Unread 08-30-2014, 12:15 AM   #1
Ljcrawler05
Hey guys, just visiting from the tj forum as I have an lj rubi, but I talked my dad into a metalcloak 3.5" lift for his 2011 JKUR and wanted to make sure everything is covered before it gets here and we install it. I've done all the work, except for some welding, on my lj so I'm pretty familiar with basic lift installation as I installed mine along with a tummy tuck, but I wanted to make sure there weren't any major differences that might would stump my dad or myself during the installation. If anybody ran across any issues during an install and has some advice/quick fixes then all of that info is welcome. Now for the real questions...
What was your final bumps top extension length (using the provided pucks) front and rear saying you have the OME shocks?
Will a new rear driveshaft be necessary for this setup?
How close were the lengths for the control arms to those on the website?
Ljcrawler05 is offline   Reply With Quote
Unread 08-30-2014, 12:29 PM   #2
SLADE
What size tires are you running and what is the collapsed length of your shocks?
I set my control arms to the measurements provided by Metalcloak and everything is good.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote
Unread 08-30-2014, 02:55 PM   #3
Ljcrawler05
He's currently got 33s, but will likely go to 35s in the very near future. We don't have the shocks in hand yet, but from what I can tell they are 11" travel shocks
Unread 08-30-2014, 09:54 PM   #4
SLADE
35,s will need about 3" bump stops with stock flares and no body lift. Can't give an estimate on the shocks without a compressed length. Shocks do not have the same compressed length for a given stroke.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread 08-30-2014, 11:56 PM   #5
Ljcrawler05
Should have mentioned he's got flat fender flares installed as well... and yeah I was hoping the crowd out there with the ome long travel shocks knew the collapsed length so we could use that as the minimum point of bumpstop
Unread 08-31-2014, 07:50 AM   #6
14Sport
2014 JK Wrangler
This may help. Bottom of page 4.
Specs
Edit: Also, I suggest you install the rear track bar bracket and driver's side track bar bolt (you can just rest the passenger of the track bar on the axle) at the same time as the lower driver's side rear control arm and driver's side rear shock. If you wait till after you will be undoing some stuff you just did.
2014 JK Sport, auto, 35x12.5x17, 3.73s.
I jeep therefore I am.
14Sport is offline   Reply With Quote
Unread 08-31-2014, 07:59 AM   #7
Ljcrawler05
Specs
Thanks! Now I've just got to Google the stock collapsed then I'll be set
Unread 08-31-2014, 08:59 AM   #8
invest2m4
You can run 2" of bump with those shocks. That's the min. We have a Jeep here with that lift that I installed. 35s and flat fenders with no rubbing (3.5" back space wheels though).
invest2m4 is offline   Reply With Quote
Unread 08-31-2014, 09:26 AM   #9
Ljcrawler05
Alright that's the info I was looking for thanks. It should be pretty easy to clear 33s and flat flares so we'll start with two pucks, and test the axles without springs at full bump.
Unread 08-31-2014, 09:34 AM   #10
invest2m4
You may know this, but I'll note it. When testing bump, be aware that the stock white bump will completely compress when offroad. Use the metal cup it sits in as your reference point for full bump.
Unread 08-31-2014, 09:41 AM   #11
Ljcrawler05
Yep well aware of that, thanks for making sure though because I've seen plenty of people on the forum stop when it hits the jounce.
Unread 08-31-2014, 09:44 AM   #12
14Sport
2014 JK Wrangler
Just for reference, I'm running 2" of bump with 35s on the 2.5" GCL and 4.5 backspacing and flatties with no problems. I actually got 3.5" of lift from the 2.5" kit.
