Mesh Grill Mod.....with Pics! - Page 2 - JeepForum.com
post #16 of 246 Old 05-27-2009, 10:03 PM
Kryptes
I am surprised how good that looks and after checking out how much it is to buy the real deal I am really considering doing this on the up comming weekend....nice job!
Kryptes is offline
post #17 of 246 Old 05-27-2009, 10:19 PM
tkn1437
I done the exact same mod a few months back. Posted materials but never done a write up. Good job. I also used fewer blocks. One at top and bottom of each opening and two on each side of opening. Holding up well so far. I did use a little sandpaper to rough up areas where blocks were going to be placed and then cleaned area well with rubbing alcohol.
tkn1437 is offline
post #18 of 246 Old 05-28-2009, 07:34 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Originally Posted by bamajk View Post
1. Start out by removing the grill. Just pop the plastic retainers out of the top of the grill and pull on the bottom and it comes off.
the ruggedness amazes me
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #19 of 246 Old 05-28-2009, 08:03 PM Thread Starter
BAMAJK
2009 JK Wrangler
But plastic doesn't dent
BAMAJK is offline
post #20 of 246 Old 05-29-2009, 12:08 AM
EugeneTheTJ
Tar Heel
I prefer to call them battle scars...haha
2016 TJ of the Year
Founder,
post #21 of 246 Old 05-29-2009, 12:09 AM
connor0770
i wonder how it would look on an XJ???
nice mod
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #22 of 246 Old 05-29-2009, 09:36 AM
EugeneTheTJ
Tar Heel
BTW, you can pop a dent. You cant pop a crack
2016 TJ of the Year
Founder,
post #23 of 246 Old 05-29-2009, 10:14 AM
drvnwheel
Completed the Grill Mod
I just finished the mod as described...plastic mesh, glued the adhesive squares, wire ties, etc. LOOKS GREAT!! Was very inexpensive and easy to do.
drvnwheel is offline
post #24 of 246 Old 05-29-2009, 11:51 AM
tazzerboy
This is an awesome mod. Ya'lls look great. One question though, how much harder/easier is it to take off a TJ grill as compared to a JK? Anyone have any directions or pics?
2003 Rubicon
Groups
Christian Jeep Club member #207 ~ Black Jeep Society ~ Homebrewing Jeepers (Founder)
tazzerboy is offline
post #25 of 246 Old 06-01-2009, 06:12 AM
Jmacaws
2009 JK Wrangler
I just did this mod but used the metal material. I also used double the strips of it. I figured it's there to protect the radiater so it better be storng. I also used less anchors than you did. Funny 'cause I was at the HD and saw this and thought I would try it. Then I come here and see that you all had beat me to the punch.
09 rubi 4dr
Jmacaws is offline
post #26 of 246 Old 06-01-2009, 06:54 AM
USAntigoon
Retired from Forum
I removed the original 2 sided tape from the square mounting base and replaced it with 3M automotive double coated tape used for trim parts etc. Along the edges, I applied epoxy glue.. Did pull tests with both set up's and the application with the 3m tape and epoxy was the strongest.. My grille mod went already through a Michigan winter without any issue..
(I used Alu mesh and painted it black..)
USAntigoon is offline
post #27 of 246 Old 06-03-2009, 05:23 PM
Captain56
2009 JK Wrangler
I saw this thread earlier today and ran to the local home improvement store to buy the needed materials. I spent $22 and have enough zip ties, mesh, and the mounting blocks left over to do it again. Looks great! Thanks for the idea and the photos.
The Captain
OlllllllO
Captain56 is offline
post #28 of 246 Old 06-03-2009, 11:13 PM
badazzelanore
I went out to buy the material and while i was at home depot I forgot it lol, walmart doesnt carry any of that other than the zip ties. I have the ties now i need the mesh and the mounting base. wish me luck!
badazzelanore is offline
post #29 of 246 Old 06-04-2009, 06:54 PM
SASQUATCH
Looks pretty good.
SASQUATCH is offline
post #30 of 246 Old 06-05-2009, 08:01 AM
toyota4x405
Does anyone know if I can pick up that 3M tape or any kind of a good epoxy at Home Depot? I plan on running out during my lunch break to pick these up and I only have 30 minutes.
Green Jeep Club Member #254
2007 Jeep Wrangler Unlimited, Jeep Green
Originally Posted by GonzoTJ View Post
'REAL Jeepers don`t cry about other Jeepers not waving at them!'
toyota4x405 is offline
'97 TJ Mesh Grill Insert Mushrabbit TJ Wrangler Technical Forum 14 Yesterday 07:13 PM
Custom Mesh Grill A.B.C's TheGillz JK Wrangler Technical Forum 35 09-14-2009 06:09 PM
Mesh inserts for grill? Tufftoy TJ Wrangler Technical Forum 16 03-07-2008 12:06 PM
Grill Inserts/Mesh M2LJ TJ Wrangler Technical Forum 1 09-17-2007 10:11 AM
Where to find mesh grill?? bombadillo YJ Wrangler Technical Forum 6 06-02-2006 05:26 AM
