Mesh Grill Mod.....with Pics! - Page 14 - JeepForum.com
post #196 of 246 Old 10-06-2013, 07:22 PM
gcan
I went with the original black plastic gutter guard, used JB weld to secure the little plastic things. That was early spring. It's been thru an aweful lot of mud and water since then, and looks the same as the day I installed it. There isn't a gap with the plastic, so nothing falls inside. And it's stopped a (ok, small) tree branch and all the other crap in the woods here from beating up my radiator. best $10 I ever spent!
gcan is offline
post #197 of 246 Old 10-06-2013, 09:39 PM
Gumby1
2014 JK Wrangler
What dept do you guys get the plastic pieces that stick on? Electrical dept? Like what are they actually for? I asked a guy at Home Depot and he looked at me like I had 3 eyes when I explained what I was doing, "we don't sell Jeep parts here, try the dealer just down the road" was what I got.
Gumby1 is offline
post #198 of 246 Old 10-06-2013, 09:46 PM
AlbertaJeeper
I don't remember specifically but anything that says electrical or computer should be the way to go. Generally for small electrical wires or computer cables
AlbertaJeeper is offline
post #199 of 246 Old 10-06-2013, 10:20 PM
Gumby1
2014 JK Wrangler
Perfect, I'll go have another look, thanks!
Gumby1 is offline
post #200 of 246 Old 10-06-2013, 10:54 PM
AlbertaJeeper
Here's what I found for reference:
Where abouts in Alberta are you?
post #201 of 246 Old 10-06-2013, 11:33 PM
Kiriesh
They're either ziptie mounts or cable mounts depending on who you ask. Should be in the wiring/electrical section of any hardware store. Be sure to remove the crappy adhesive pad they come with and just superglue the plastic mount directly onto the back of the grill.
Sent from my SAMSUNG using JeepForum
Kiriesh is offline
post #202 of 246 Old 10-07-2013, 07:11 AM
Gumby1
2014 JK Wrangler
Where abouts in Alberta are you?[/QUOTE]
I'm down in Medicine Hat
Gumby1 is offline
post #203 of 246 Old 11-25-2013, 09:21 PM
irishluck
I actually had to redo mine after 7 months of my guards on the grill.
The sticky pads finally came undone. Im actually redoing it right now and gluing down as well.
irishluck is offline
post #204 of 246 Old 07-29-2014, 04:39 PM
nimitz68
This is awesome... I was just looking for an affordable way to protect my EXPENSIVE radiator on my 01 XJ and my 92 XJ. Just bought the items on Amazon. I will provide pics when I get to the project!!! Thanks for the GREAT advice!!
nimitz68 is offline
post #205 of 246 Old 07-29-2014, 04:41 PM
nimitz68
while I am going with black (might paint it a gloss black) the green looks awesome!!!
nimitz68 is offline
post #206 of 246 Old 07-31-2014, 03:14 PM
nimitz68
Started to do this at work for my 2001 XJ Limited. The tie downs I saw on Amazon were like 80 bucks for the outdoor version so I bought emblem glue (3M) and started putting the tie's around each entry. I will post an update. I am also going to do this for my 1992 XJ Limited (it's black exterior, black wheels, grey/black interior).
UPDATE:
If you are going to use any sort of high temp or emblem glue let it sit for 24 hours. I wanted to do a test section about two hours after applying the mounts AND glue to much disappointment that the mounts started to peal up... I will post an update with finished pics and mounted pics for us XJ people
20140731_144550_resized.jpg   20140731_144255.jpg   20140731_144543_resized.jpg   20140731_144604_resized.jpg   20140731_144615.jpg
nimitz68 is offline
post #207 of 246 Old 08-04-2014, 05:17 PM
Vynks82
2016 WK
Thanks for the write up.... It inspired me to do my own with red plasti dip
Vynks82 is offline
post #208 of 246 Old 08-04-2014, 08:34 PM
Flexin
Question for everyone. How is the mesh you have made? The ones I found this weekend were like wires pressed into a diamond pattern. In certain directions you can rip it easier then paper. In other directions it seems tough enough. I worry about it pulling apart when I tighten the zip ties. I'm hoping to find one that is made as all one sheet.
James
Flexin is offline
post #209 of 246 Old 08-04-2014, 09:14 PM
nimitz68
Looks awesome
nimitz68 is offline
post #210 of 246 Old 08-05-2014, 07:21 PM
Vynks82
2016 WK
Mine was gutter guard from Home Depot and is super strong....I got blisters while using wire snips to cut it all!
Vynks82 is offline
'97 TJ Mesh Grill Insert Mushrabbit TJ Wrangler Technical Forum 16 07-26-2017 02:35 PM
Custom Mesh Grill A.B.C's TheGillz JK Wrangler Technical Forum 35 09-14-2009 07:09 PM
Mesh inserts for grill? Tufftoy TJ Wrangler Technical Forum 16 03-07-2008 01:06 PM
Grill Inserts/Mesh M2LJ TJ Wrangler Technical Forum 1 09-17-2007 11:11 AM
Where to find mesh grill?? bombadillo YJ Wrangler Technical Forum 6 06-02-2006 06:26 AM
