Mesh Grill Mod.....with Pics! - Page 11 - JeepForum.com
post #151 of 246 Old 01-30-2012, 01:39 PM
LUNCHBOX_PGH
2009 JK Wrangler
Originally Posted by deerassassin22 View Post
Would a hot glue gun with these bases hold up, is people using super glue just wondering was thinking about doing this weekend looks like a nice weekend mod. And the metal mesh were could you get a piece long and wide enought to fit? I see everyone using gutter screen that is not very wide at lest if its what I'm thinking of.
I purchased the precut aluminum mesh gutter guard from lowes. Coated it with the black spray on tool grip. Been on for months now, and the coating has held up well, no resprays yet.
LUNCHBOX_PGH is offline
post #152 of 246 Old 02-08-2012, 08:59 PM
Johnnydenim
I did mine tonight...very happy with it!
$23 for everything at Lowes. Pulled the sticky off of the squares and used Loctite super glue gel. Black plastic mesh. It took longer to pull the sticky off than to do the mod!
Johnnydenim is offline
post #153 of 246 Old 02-08-2012, 10:02 PM
fooddude
Any pics of the process and/or finished project?
-FD
fooddude is offline
post #154 of 246 Old 02-08-2012, 10:20 PM
Johnnydenim
post #155 of 246 Old 02-09-2012, 07:41 AM
Johnnydenim
Back on the jeep. I am very happy with it!
post #156 of 246 Old 02-09-2012, 06:45 PM
fooddude
Looks great!
Will definitely have to do this when spring arrives.
Thanks or the pictures, really looks fantastic!
-FD
fooddude is offline
post #157 of 246 Old 02-28-2012, 05:55 PM
JKatfish
Just installed the Rugged Ridge mesh and love the way it looks. Its held in with 2 metal bars and 4 screws. Pretty easy job, solid and wont come off either. Well worth the $50, so if you spend $20 at Lowes, its not much more and looks like OE since the mesh is formed to fit in the slots and can be done in 20 minutes.
JKatfish is offline
post #158 of 246 Old 03-08-2012, 11:54 AM
FameFab
2009 JK Wrangler
Does Radio Shack have these 1"x1" clips?
http://www.facebook.com/?ref=tn_tnmn#!/pages/Famous-Fabrication-LLC/340545112634624
FameFab is offline
post #159 of 246 Old 03-08-2012, 12:32 PM
torange
1"x1" clips
lowes, Home Depot, or Menards in the electrical dept.
torange is offline
post #160 of 246 Old 03-08-2012, 04:46 PM
FameFab
2009 JK Wrangler
Radio shack had very similar ones. I will try Lowes so I can get a bigger zip tie into it.
FameFab is offline
post #161 of 246 Old 03-11-2012, 12:51 AM
jksmith93
i did this mod over the weekend, metal mesh from home depot, painted it black and zip tied it on. it's held up great so far, had to pick out a huge dead bee today. about $25 dollars and it looks like the brand name stuff!
jksmith93 is offline
post #162 of 246 Old 03-11-2012, 07:47 AM
smittycm
I'm towards the end of finishing this mod up myself. Didn't go as smoothly as I had hoped for me. I tried using Rustoleum Undercoating instead of just regular black spraypaint. DON'T DO IT! This stuff would not dry for anything. It stayed tacky and kept peeling off when I tried to touch it even though I let it dry inside my house for an entire day. Turned what should have been a few hours project into a full day and a half, and I wasted $5 on a stupid can of undercoating. I sprayed satin black regular spray paint over the top of the undercoating and let it sit overnight. It seems to have worked. We'll see if it holds up. I have a bad feeling I might end up buying new gutter guard and just doing it over with regular spray paint and a good primer.
2012 JKU Sport S, RK 2.5" Max Travel, Bilstein Shocks, AEV Savegre Wheels, GY Duratrac 315/70R17
smittycm is offline
post #163 of 246 Old 03-11-2012, 09:56 AM
2007UnlimitedNJ
I used animal screen from Lowes. It is a vinyl matetial. Once taught with zip ties, i think it looks terrific.
I even mounted my EZ pass behind it and it is unseen and works great!
2007UnlimitedNJ is offline
post #164 of 246 Old 03-11-2012, 01:36 PM
FameFab
2009 JK Wrangler
Ditto. I used gate mesh from Lowe's, already black, needed no paint. I ended up using the sticky clips from Radio Shack, 18 of them. And tie wire. BEEF! Also did this to my Tacoma with the same mesh. I hate bugs between the fins!
FameFab is offline
post #165 of 246 Old 03-11-2012, 03:10 PM
GreenRenegade
Does this have to be done one strip at a time, 7 times? No way to make it a one piece install?
Dan
2013 Wrangler Rubicon 2dr
GreenRenegade is offline
'97 TJ Mesh Grill Insert Mushrabbit TJ Wrangler Technical Forum 13 11-10-2009 05:13 AM
Custom Mesh Grill A.B.C's TheGillz JK Wrangler Technical Forum 35 09-14-2009 07:09 PM
Mesh inserts for grill? Tufftoy TJ Wrangler Technical Forum 16 03-07-2008 01:06 PM
Grill Inserts/Mesh M2LJ TJ Wrangler Technical Forum 1 09-17-2007 11:11 AM
Where to find mesh grill?? bombadillo YJ Wrangler Technical Forum 6 06-02-2006 06:26 AM
