Massive repair bill - JeepForum.com
post #1 of 17 Old 05-13-2013, 04:16 PM Thread Starter
adkjk
Massive repair bill
So the dash light for the electronic sway bar disconnect started flashing intermittently the other day on my 2008 Rubicon Unlimited (25,000 miles, only moderate trail use in the NE) Took it in and was told $2,700 to replace the sway bar. After I picked myself up off the floor they told me my TIPM was reporting error codes and needed to be replaced for another $350. I haven't had any of the usual TIPM problems (inoperable lights, locks, etc.). Wondering if the TIPM could be causing the sway bar fault? Anyone had to replace the sway bar? If so how much? I know from other posts they are expensive but $2,700 is ridiculous. Finally, anyone know if driving with the sway bar intermittently flashing would be unsafe? It doesn't feel like it is actually trying to disconnect....
Thanks.
adkjk is offline
post #2 of 17 Old 05-13-2013, 04:23 PM
222Doc
222Doc's Avatar
seems high the part is only 1495$ simple install. whats 1k labor? must be making up for the 012 heads.
I use mine rather hard and at 17k its still working? might be one of the, 'use it or lose it' things. When it dies i go Currie call it aday for 500$
222Doc is online now
post #3 of 17 Old 05-13-2013, 04:48 PM
brianjw
I just removed the sway bar motor from my 2012 (working fine) and installed the EVO manual sway bar disconnect. Works great with the spin of a knob. I think it's $80, super easy to install.
brianjw is offline
post #4 of 17 Old 05-13-2013, 05:56 PM
222Doc
222Doc's Avatar
You could mount a servo to that knob and have a poor mans e-disco.
post #5 of 17 Old 05-13-2013, 06:00 PM
MKWrangler
The sway bar light flashing only means that you will not be able to use that feature. It should be ok to drive, just annoying. Try unplugging it, disconnect your battery for 5 minutes, reconnnect sway bar, then battery to see if it fixes it. If it doesn't work go for the EVO spin knob fix.
MKWrangler is offline
post #6 of 17 Old 05-13-2013, 06:02 PM
ncb
The AEV Procal (other programmers might) will kill that light if you decide to go with a different sway bar.
ncb is online now
post #7 of 17 Old 05-13-2013, 06:55 PM
Filthy-Beast
Yes the Procal will kill the light. I'd go with a antirock at this point.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #8 of 17 Old 05-13-2013, 07:28 PM
brianjw
Manual disconnect or used sway bar motor. Both are much less expensive.
brianjw is offline
post #9 of 17 Old 05-13-2013, 07:38 PM
maniacal_rick
Antirock.
Better offroad performance and never have to worry about being connected or not.
2012 2Dr JK - Metalcloak - Currie - Prorock - ARB - Poison Spyder - RCV - Synergy - Etc...
maniacal_rick is offline
post #10 of 17 Old 05-13-2013, 07:49 PM
SoK66
2009 JK Wrangler
Lunacy from another stealer. If it's really faulty get rid of it and go Currie, Tera or ORO.
Jeeps: Where my 401(k) went to die!
SoK66 is offline
post #11 of 17 Old 05-14-2013, 08:41 AM
CF1973
2014 KL Cherokee
I'm looking to replace my OEM electronic sway bar, 2012, with a stock non-rubicon version. The electronic sway bar disconnect for me is wasted as I disconnect it for an entire day at a time. I've had a WTB OEM non-rubicon front sway bar post on another site for over a month, no luck. Dealer quoted me $144 for the OEM non-rubicon front sway bar. I'm looking for a the cheapest front sway bar replacement possible, then I can sell the OEM electronic one.
CF1973 is offline
post #12 of 17 Old 05-14-2013, 09:13 AM
brianjw
Man, buy or make a manual disconnect for the rubi bar!
The normal quick disconnects are a huge pain to re-connect. The last pin normally involves lying on your back in the dirt/mud and bouncing the jeep, trying to re-align the holes/pins. With the manual disconnect, just turn the knob and drive (or bounce it once) and it reconnects when it aligns. I leave mine disconnect for longer times and higher speeds too, sand, washboard roads etc. Unless you're just hoping to get a bunch of money for the stock rubicon piece?
brianjw is offline
post #13 of 17 Old 05-14-2013, 11:49 AM
CF1973
2014 KL Cherokee
I may be grasping here, but I would like to slowly lighten the Jeep. Replacing the rubicon sway-bar with the standard and removing the lower bumper skid plate that protects it, will remove X? pounds from the front end. If I can get some cash out of it, that's a bonus. Hell, given the nature of my wheeling trips, an entire day or a weekend at a time, it could be removed completely before the trip.
More potential changes to reduce front end weight...
- Synthetic winch line
- lighter hood
- temporary removal of the the front fender flares while wheeling, http://www.metalcloak.com/Jeep-Wrang...are-p/3281.htm
If I had to do it over again, I would have gotten aluminum fenders. I'm not sure about aluminum skid plates though. I'm comfortable with aluminum on the parts that rarely, if ever, take big hits like skid plates and rock sliders do. The fender flares in the rear have kept me off of trees numerous times.
I don't want to hijack this thread, but I would be interested in a list of mods to reduce weight, front end specifically.
CF1973 is offline
post #14 of 17 Old 05-14-2013, 07:58 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
I found one on another forum for $60 or $70 shipped. Installed quick discos and didn't look back. I sold my rubi sway bar for $400 ish on eBay
Post wtb on all the forums, you'll have better luck. Buy the tapatalk app to track your classifieds all in one place.
Mol is offline
post #15 of 17 Old 05-15-2013, 07:25 AM
Imped
Imped's Avatar
Sell Rubi sway bar assembly for $.
Purchase Currie AR, a sway bar that actually helps you offroad.
Forget about the rest.
OlllllllO
IndyORV
Imped is online now
