Manual transmission problem - Page 2 - JeepForum.com
post #16 of 33 Old 02-20-2010, 03:00 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
There is a TSB for the 07's and 08's in regards to them having a double boot on the shifter. It seems that the inner boot is stiff enough to prevent full engagement.
I have had second gear pop out a few times in the past, I now practice firm/positive shifts with no more problems.
I don't know if this relates to your problem but more info never hurts
Jim
JLC08JK is offline
post #17 of 33 Old 02-20-2010, 07:36 AM
qf4phlyer
qf4phlyer's Avatar
The 6 speed has an inner boot that is very stiff, it will cause the shifter to pop out of 1st and makes it difficult to shift into 2ndwhen it's cold. There is a tsb, but it doesn't solve the problem, If you have a lift, or body lift this makes it worse. There is a thread that shows how to trim the inner boot, I did it, and haven't had any issues since. I'll try to find it and post the link.
08 Wrangler X DETN8R Yellow Rough Country 2.5" progressive rate coil lift, 2.2 shocks. 1.25" body lift, disco's, steering stabilizer. Benchmark EVAP skid. TeraFlex front bumper with shackles. 35x12.5x15 BFG A/T KO's on MB72 wheels.Cobra 75 on a Firestik. Arizona Rocky Road antenna mount. Ward bug shield, DayStar hood wranglers, upper dash panel. Qtech arm rest.
2002 Wrangler Sahara RIP
1979 CJ 7 258 RIP
1975 Cherokee S 401 RIP
qf4phlyer is offline
post #18 of 33 Old 02-20-2010, 07:46 AM
qf4phlyer
qf4phlyer's Avatar
Rough Country 1.25" Body Lift Problem. - Page 5 - JK-Forum.com - The Ultimate Jeep JK Wrangler Bulletin Board
This shows the steps on how and what to trim.
1979 CJ 7 258 RIP
post #19 of 33 Old 03-05-2010, 01:06 PM
dirtyjpwrangler
Just wondering - how much would it cost to fix/replace the first gear syncro with a regular auto mechanic?
Mine happens almost once every 2-3 months, but I'm out of warranty and the 2nd owner so I don't have the lifetime powertrain. If this ever gets really bad I'm just wondering how much mula it would cost to fix it in the future.
'08 X, Jeep Green, 6 speed, 32" BFG MT's, power options, rubi rock rails, front grab handles, soft top all year round ...oh yea and dirt.
dirtyjpwrangler is offline
post #20 of 33 Old 03-05-2010, 01:34 PM
kudah
There is a new TSB for this issue now. If they can confirm that the shift boot is not causing the problem then they will replace the 1-2 synchronizer.
Chrysler is paying 5.4 hours to replace the synchro.. a shop will likely charge 8-9 hours labor.
Robert
kudah is offline
post #21 of 33 Old 03-05-2010, 01:38 PM
dirtyjpwrangler
hmm so 5.4 hours @ $90/hour would cost roughly $490 at the dealership. That's actually not too bad. Now I just wonder how much the parts would cost. Thanks
post #22 of 33 Old 03-05-2010, 02:07 PM
USAntigoon
Retired from Forum
Here is the TSB in question...they will only replace the 1/2 synchronizer with a "field fix" synchronizer..
USAntigoon is offline
post #23 of 33 Old 03-05-2010, 06:40 PM
kudah
The dealership is not going to fix it for 5.4 hours if you have to pay for it. They are going to book rate the labor time just like any other shop. 5.4 hours is what Chrysler pays for a warranty repair
Robert
kudah is offline
post #24 of 33 Old 03-15-2010, 09:29 AM
joeranger
Has anyone done this? Are there any tips on dealing with the service dept?
joeranger is offline
post #25 of 33 Old 03-15-2010, 10:36 AM
USAntigoon
Retired from Forum
In another forum, (on the same subject) I read that the repair with the service synchronizer fix was successful.. I am convinced that the transmission OEM resolved the issue.
Be informed once you walk into your dealership.. have a copy of the TSB with you and not bad to have as background material a few copies of all the posts here and in other forums..
post #26 of 33 Old 03-15-2010, 01:19 PM
joeranger
Thanks. I called my local dealer and they were not familiar with the fix. I had brought it in before and they were unaware of the issue. I brought the printout from the forum and they said, "Oh, you read this on the INTERNET?"
The issue will be if they can replicate the problem. Then they can order the parts for it. I might wait a bit to see more responses.
post #27 of 33 Old 04-07-2010, 09:28 AM
boostedboxer
2010 JK Wrangler
I took mine in for this today and they're ordering me a new transmission now
boostedboxer is offline
post #28 of 33 Old 04-21-2010, 12:37 PM
USAntigoon
Retired from Forum
This TSB has been updated ... follow thread here..
post #29 of 33 Old 04-21-2010, 12:42 PM
redrockin7
Sounds like a warranty claim to me... try another dealer, you'd be surprised how much of an a-hole one can be and how nice as pie another might be.
What you don't want to do is "learn to live with it", then get past your warranty (unless u have lifetime of course), and have the synchro (or whatever else is causing it) totally be destroyed and never let you in, or out of first.
Then it would be pretty much undrivable and on your dime to fix...
Had syncrho issues with 3rd in my old 350z (yeah yeah not a jeep) and had it replaced under warranty with 35,600 miles on it (when warranty expired at 36,000) LOL. However, mine was to the point that it would do it every shift into 3rd over 3500 RPM or so (never below), so it was easy to duplicate.
redrockin7 is offline
post #30 of 33 Old 04-21-2010, 12:44 PM
redrockin7
You could give them something to replicate pretty easily I would think, if you really wanted to... Abuse first gear until it fails anyone? Haha.
manual transmission
Since I am new to the whole Manual transmission... Yellow09Jeep JK Wrangler Technical Forum 12 12-23-2009 09:47 AM
6 spd manual transmission problem/death cyberiv TJ Wrangler Technical Forum 5 09-08-2009 02:58 PM
99 Manual Transmission Help lilngineer TJ Wrangler Technical Forum 8 12-11-2007 04:49 PM
87 Manual Transmission duke32 YJ Wrangler Technical Forum 5 08-06-2006 08:13 PM
HELP! manual transmission reverse problem jeep75 YJ Wrangler Technical Forum 3 10-08-2004 09:45 PM
