Manual Trans blew - I know, why did you get manual... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Manual Trans blew - I know, why did you get manual...
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 12-08-2010, 06:20 PM   #1
joeranger
SO a while back I printed out a bunch of information from this forum on the "popping out of first gear" issue and took it to my dealership. They said they had to replicate the issue to cover it under warranty. They were unaware of the issue. I was waiting for a more definitive answer before I took it back.
So this afternoon, the transmission blew. Engine ran, but gears would not work.
2008 4dr Wrangler Sahara. Manual trans. 33k miles. I just had it towed to the dealer. I have the extended warranty.
Is there anything I need to know before i have a conversation with the service dept?
joeranger is offline   Reply With Quote
Unread 12-08-2010, 06:34 PM   #2
JLC08JK
What was I thinking?
JLC08JK's Avatar
Could you please define "blew" and describe the event's leading up to the final result?
Jim
Jim's Jeep; THE OBSESSION LIVES ON!
Jim's JK D44 Rear Axle Build
99% of Your JK Questions will be Answered Here
JK F.A.Q./WILL IT RUB and Popular Threads
Protect Our Rights to Freedom and the Environment
Visit the EnviroBeat
JLC08JK is online now   Reply With Quote
Unread 12-08-2010, 06:36 PM   #3
JeffinWesternWA
2010 JK Wrangler
print/refer dealer to the X ysler TSB number for the existing known problem. HAve your service records for previous attempts (copies) of asking/fixing your tranny a vailable. Go for a "new/rebuilt" vice "rebuilt in shop" tranny, it'll be faster fix and probably a better tested/inspected unit. Ask for a synthetic fluid. Might a well have a look at clutch disk, TB and flywheel while it's there....if you wanted to upgrade, now is a good time. Never, except w/ VOILENT shifts, have I seen any manual tranny (HD tranny's in busses, trucks included) "fail" though seen plenty of auto's doing so. My '10 has "popped" out of first a dozen times, usually it's not "fully engaged" or some slight "hand pressure, etc.," on shifter seemed the cause. It is LOUD and surprising though, not fun...should be no problem under waranty. Less problem w/ extended warranty...
JeffinWesternWA
JeffinWesternWA is offline   Reply With Quote
Unread 12-08-2010, 06:38 PM   #4
paul84043
They guy with the dog glued to his hood brings up a good point...what happened when things went "booom"!
paul84043 is offline   Reply With Quote
Unread 12-08-2010, 07:56 PM   #5
boostedboxer
2010 JK Wrangler
boostedboxer is offline   Reply With Quote
Unread 12-08-2010, 07:59 PM   #6
paul84043
Originally Posted by boostedboxer View Post
what?
Unread 12-08-2010, 08:04 PM   #7
OregonVette
Originally Posted by JeffinWesternWA View Post
I have never seen any manual tranny (HD tranny's in busses, trucks included) "fail" though seen plenty of auto's doing so..
X 2
Interesting, I too have never thought auto trans was a safer build either. Typically, the only problem with a MT is a worn out clutch or throw out/fork etc. All very replaceable and quick fixes. But, to repair an auto?!?! No way.
There are hundreds of Auto transmission repair shops around Portland. I've never seen a Manual Transmission repair shop I think, ever.
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline   Reply With Quote
Unread 12-08-2010, 08:10 PM   #8
paul84043
My son "blew" a tranny....never bothered to figure out what he did, but it sure as hell was broke.
Unread 12-08-2010, 08:33 PM   #9
tjkj2002
2002 KJ Liberty
Originally Posted by OregonVette View Post
X 2
A trans shop does both auto and manual trans,even t-cases and diffs.
tjkj2002 is offline   Reply With Quote
Unread 12-08-2010, 08:35 PM   #10
JeffinWesternWA
2010 JK Wrangler
I got some ideas...
JeffinWesternWA
Unread 12-08-2010, 08:42 PM   #11
paul84043
I got some ideas...
Well, I know what he "did", but never bothered to find out what was broken.
Yes....he thought he was on The Fast and the Furious, and he dumped it one too many times...
Unread 12-08-2010, 08:51 PM   #12
JLC08JK
JLC08JK's Avatar
Glued?
You are going to get Peta after me talking like that!
And besides she is carefully bolted to the hood so she can be easily removed for servicing
Jim
Unread 12-08-2010, 08:53 PM   #13
joeranger
I heard a grinding sound and then we smelled burning/stench. I would push the gas and the engine would rev, but the gears would not engage. I let it roll to a stop and shut it off. Called the Roadside assistance.
Unread 12-08-2010, 08:55 PM   #14
paul84043
No, as long as she's "carefully bolted" I'm okay....
F- PITA.
People Eating Tasty Animals.
Yum.
Unread 12-08-2010, 09:09 PM   #15
ak67sd
F- PITA.
Yum.
Leave the glue bottle open?
p.s. my guess is a cluster pack failure (it's in peices) maybe input shaft bearing/gear...
08 Wrangler Unlimited
ak67sd is offline   Reply With Quote
