Manual Tranny Issues new 2012 JK - JeepForum.com
post #1 of 32 Old 04-18-2012, 12:35 PM Thread Starter
Compgod
Hey, has anyone esle had problems with their standard tranny? The clutch engages near the top (release) of the pedal instead of at the bottom. I'm also having some problems trying to get the thing going from a dead stop. I have stalled it 5-6 times in the first 150 Miles. I have to rev it to 12-1500 before I start to disengage the clutch otherwise it will stall.
I don't know if it's me or an issue with the jeep. Any help would be appriciated.
Clutch pedal movement: 100% bottom(pressed to the floor) = 100% top = 0%
The clutch disengages in the top 25% of the pedal range
Compgod is offline
post #2 of 32 Old 04-18-2012, 12:52 PM
73azbronco
are you on a hill by chance during your starts?
73azbronco is offline
post #3 of 32 Old 04-18-2012, 12:57 PM Thread Starter
Compgod
Nope all my starts are on flat ground.....It's pretty flat around here
Compgod is offline
post #4 of 32 Old 04-18-2012, 01:23 PM
73azbronco
Time to go to dealer and try another one to see if it's normal.
post #5 of 32 Old 04-18-2012, 01:27 PM
MudDuck99
2014 JK Wrangler
Mine seems the same way. Try waiting a few seconds after letting off the brake. On hills, mine doesn't really roll for a few seconds after letting off the brake. Its almost like a safety thing for taking off on hills
MudDuck99 is offline
post #6 of 32 Old 04-18-2012, 01:40 PM
73azbronco
It is, hill start assist, brakes stay on till movement is achieved.
post #7 of 32 Old 04-18-2012, 01:48 PM
goose87
i dont think i have to rev mine up that much before i start moving. ill check it out on my way home from work today and see whats up with it and ill post what mine does when i get home. but then again this is my first manual transmission so maybe i dont realize it.
goose87 is offline
post #8 of 32 Old 04-18-2012, 01:53 PM
fltsfshr
Mine will do the same thing. The worst part is it's intermittent. Sometimes it works just fine, other times it falls on it ***. If you rev it too high, you'll smell clutch plate, there's a fine line there. I think it has something to do with their eco system and the fly by wire throttle.
It's not you, I drive an 8puc dual friction on the track. It's easy compared to the jk.
If you find the solution, let me know.
fltsfshr
Past and Present Jeeps 2012 Wrangler, 1997 Wrangler, 1988 Wrangler, M151A
fltsfshr is offline
post #9 of 32 Old 04-18-2012, 02:18 PM Thread Starter
Compgod
I'm going to try and disable the hill start assist and see if that helps. I'm taking it to the service center on Monday to see what they say.
Compgod is offline
post #10 of 32 Old 04-18-2012, 02:38 PM
ncb
I can start out in first with very little gas. Drive a new one on the lot to see if it's the same. I've only owned vehicles with standard transmissions and it took a couple days to get use to the JK. If you're on flat ground killing the HSA won't help.
ncb is online now
post #11 of 32 Old 04-18-2012, 03:02 PM
JPDRUBI12
I have a '12 JKR. 6 speed and it starts of in first with very little gas. I can get rolling with no gas if it's flat or downhill of course. Never have to rev it up past 1000rpm to get moving.
JPDRUBI12 is offline
post #12 of 32 Old 04-18-2012, 03:13 PM
smcutter
The clutch is obnoxious on my 2012 JKR, but I got used to it after the first month or so. Hill Start Assist was causing me to stall frequently because I would give it just enough gas to move the vehicle... but not enough gas to move the vehicle while the brakes were on. So I disabled HSA after the first week.
One thing I find is that the clutch in my JK is irritating on the street, but it's so much smoother than my old TJ when offroading. The most charitable interpretation of this would be that Jeep designed the clutch pedal for the frequent in-and-out clutching that is necessary when rock crawling and otherwise driving really, really slowly.
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #13 of 32 Old 04-18-2012, 05:12 PM
fltsfshr
How did you disable it?
fltsfshr
fltsfshr is offline
post #14 of 32 Old 04-18-2012, 05:36 PM
ncb
What size tires and gear ratio do you have?
ncb is online now
post #15 of 32 Old 04-18-2012, 05:57 PM Thread Starter
Compgod
Standard 18" Rim's and tires that come with the Sahara and 3.73 gears
Compgod is offline
2012 , clutch , manual , standard
2012 manual tranny bulletin 21-002-12 JackTEOD JK Wrangler Technical Forum 40 02-09-2014 02:32 PM
2012 Manual Regear 4.10 or 4.56 mini-me JK Wrangler Technical Forum 12 01-19-2012 06:56 AM
New 6-speed manual in 2012 Wrangler vanwrangler JK Wrangler Technical Forum 11 08-31-2010 08:10 PM
Manual Tranny Shifter Issues with Body Lift? elcidsurfer TJ Wrangler Technical Forum 4 04-28-2010 02:14 PM
99 TJ Manual Tranny Issues GunMetalBlue TJ Wrangler Technical Forum 7 01-19-2009 06:30 PM
