MAF sensor - JeepForum.com
post #1 of 8 Old 01-04-2008, 06:19 AM Thread Starter
999666
MAF sensor
For the 3.8 V6 what kind of Mass Air Flow sensor does it use?
Is it the same heated wire type as used by GM and BMW or is it different?
If different can you explain how the ECU makes it's proper fuel/air ratio mixtures on it's various maps.
999666 is offline
post #2 of 8 Old 01-04-2008, 07:21 AM
FatBuoy
FatBuoy's Avatar
Pretty sure it's mapped through MyGig
That damn thing does pretty much everything else!
FatBuoy is offline
post #3 of 8 Old 01-04-2008, 01:02 PM
JeepNorth
The Jeep uses a MAP (Manifold Air Pressure) sensor, not a MAF, so it's measuring pressure, not air flow. The ECU does all the calculations to determine density and air-flow based on the manifold pressure and IAT (Intake Air Temperature) sensor values resulting in the fuel requirments at any given time.
From what I understand, MAP sensors are cheaper.
The MAP sensor is on the upper rear of the intake manifold. The little rectangular sensor.
JeepNorth is offline
post #4 of 8 Old 01-04-2008, 01:32 PM Thread Starter
999666
^^^ thanks,
Was hoping it was a MAF, as I'm not familiar with the pressure system, geuss I'll have to do some research.
999666 is offline
post #5 of 8 Old 01-04-2008, 01:52 PM
jeeparoo
a MAP sensor is a fancy Vacuum sensor.. basicilly the more the engine is under load the closer to 0 your vacuum will be.. so they use the MAP sensor to determine how hard the engine is loaded.. 1/2 open throttle at real low RPM say shifting to too high of a ear for your speed will yield close to 0 vacuum and "full load" of engine indicated.. where as full throttle at super high RPM may read less than full engine load.. I prefer MAF to MAP because it doesnt completely screw up when you add a turbo or supercharger..
I guess I figured by now jeep would be using MAF.. MAP was used in the early 80's cars...
-Christopher
Ordered 2008 4dr 11/24/07 got it 12/28/07 - mall crawler - goin for gadgets on this one. COMFORT
Jeep Memories:
76 Cherokee Chief - got rusty (sold)
97 TJ Sahara 5sp soft top - mudded,sanded,rocked,sunk(sold)
00 TJ Sport 5 sp soft top - mudded, rolled in a blizzard{no damage except top} (sold)
02 TJ Sport auto soft top - roadtripped,mudded (sold)
06 TJ gold eagle 6 sp soft top- not enough room (sold)
Number 10 million of the 'I Love my JeeP' Club
jeeparoo is offline
post #6 of 8 Old 01-04-2008, 03:06 PM
liquids
liquids's Avatar
Chrysler engines use a combination of manifold air pressure (MAP), throttle position (TPS), and RPMs (plus upstream exhaust O2 sensor) as inputs. It's not as simple as one or the other. All these determine fuel injection pulse width and timing.
I don't know if any of the engines has variable valve timing as an "output".
LIQUIDS
2008 Wrangler Unlimited 4X4 - Jeep Green - 23S - Manual - Dual tops - Power group - Limited slip - 17" wheels - Side air bags - Sirius - Born 6 August 2007
1968 CJ5 - President Red - Dauntless - Ramsey PTO winch - 1980's full top - Unrestored and running (... but not stopping)
Have Fun Out There.
Jeep
liquids is offline
post #7 of 8 Old 01-04-2008, 04:04 PM Thread Starter
999666
Liquids, FYI MAF setups need a TPS and O2 sensors as well to make proper mixtures per given RPM.
Jeeparo hit the nail on the head for what my real plan is with this thread.
Turbo or Supercharging the JK.
I supercharged my BMW by simply bolting on a roots M62 SC after the MAF and the compute auto adjusts mapping for me all the way up to 10 PSI of boost (with a rising rate fuel pressure regulator).
Was hoping the JK would be just as easy. So now I have to figure out how to make positive pressure "BOOST" in the intake look like vacume and have the ECU able to map accuratly...
thanks again all for the info , looks like I have my work cut out for me.
999666 is offline
post #8 of 8 Old 01-04-2008, 04:27 PM
nota4re
nota4re's Avatar
You might take a look at some of the little black boxes made by Split Second. They have been one of the leaders in developing electronics to "fool" the ecu. I used their products successfully (albeit with a lot of tuning) in a different MAP-based car when I added a supercharger.
UltraMount CB Ant. Mount for the JK
'07 White 4-door Rubi
nota4re is offline
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 02:29 PM
Crankshaft position sensor and o2 sensor bracket help diy4x4 TJ Wrangler Technical Forum 0 03-02-2009 05:07 PM
My 2.5 takes a while to start, is it the cam sensor or crank sensor!! Divebum TJ Wrangler Technical Forum 9 12-24-2008 01:38 PM
power steering sensor needed? O2 sensor? Zorm YJ Wrangler Technical Forum 8 01-17-2008 09:06 AM
P0135; 02 Sensor Heater Malfunction, Sensor bad???? perley03 TJ Wrangler Technical Forum 5 01-18-2007 09:40 PM
