Maertz's Half *** Build Thread - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Maertz's Half *** Build Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 02-08-2014, 12:57 PM   #106
Maertz
2009 JK Wrangler
Well rear upper mounts can suck it. Putting in some heavier duty ones...
Should be done soon.
Wishing I Wasn't Part Of The 'JK' Crowd...
A JK On Junkyard 60s
Maertz is offline   Reply With Quote Quick reply to this message
Unread 02-08-2014, 02:16 PM   #107
Randonexplosion
Trailer Queen
Randonexplosion's Avatar
Nice. Hopefully I will be welding link tabs on before too long
Why yellow?
5.3/4l60e swap
August YJOTM
Exiled Offroad - Colorado
Randonexplosion is online now   Reply With Quote Quick reply to this message
Unread 02-08-2014, 02:19 PM   #108
Maertz
2009 JK Wrangler
Yellow is a supreme color and is arguably the secret to curing cancer...
Unread 02-08-2014, 04:20 PM   #109
Maertz
2009 JK Wrangler
Well rear upper mounts done.
Also found my jeep tagged in some racing site. wtf i dont race?
Unread 02-08-2014, 04:50 PM   #110
brianjw
That is likely just the photographer's business name.
brianjw is offline   Reply With Quote Quick reply to this message
Unread 02-08-2014, 06:31 PM   #111
Randonexplosion
Trailer Queen
Was that a pic that Rick took?
5.3/4l60e swap
August YJOTM
Unread 02-08-2014, 07:23 PM   #112
Maertz
2009 JK Wrangler
nope some dude from the new mexico off road group it looks. either way i like the pic.
well another day wheeling.....
Couldnt quite reach full flex here, o well should have drove higher up.
A few trench shots.
Ripped this off, but it went right back on. Reverse lights out though...
Unread 02-09-2014, 10:57 AM   #113
awinski
young & dumb
awinski's Avatar
probably broke the bulb, i remember when i smashed my rear corner, light was fine till i hit a pot hole on the ride home and the light went out according to my buddy riding behind me lol.
The ONLY chlorophyll JK
one more horse power than the average pentastar; http://www.jeepforum.com/forum/f22/p...-build-2157673
twitter/IG - @Becauseracejeep
awinski is offline   Reply With Quote Quick reply to this message
Unread 02-09-2014, 12:57 PM   #114
Maertz
2009 JK Wrangler
My reverse is an led light i wired in, ill have to dig into it
Unread 02-11-2014, 04:48 PM   #115
Maertz
2009 JK Wrangler
Ok well decided to sack up and finally start putting my jeep knowledge to the test. I am in the process of getting a set of dana 60s. The front is a High pinion ford and the rear is a d60 from a dodge. I will be ditching my current axles and all that stuff. I will be doing a double triangulated rear and 3 link front. It will be on 40s and stretched somewhere between 105-110" wheelbase.This will be my first decent sized build and a big learning step for me. I just told my buddy I would buy one of his sets of axles so it may be a bit before I get started on this little project. I need to sell my tires,rims,axles and such before I can really go nuts. I probably wont update much more until I can start getting into it. Will keep everyone posted!
Unread 02-11-2014, 04:58 PM   #116
awinski
young & dumb
awinski's Avatar
Wow that's amazing. I have have a friend that just completed a 60 swap a few months ago, he said the only thing he didn't like about the Dodge rear is he had to weld the brake brackets on himself for the calipers instead of Ford where it would be pretty much a bolt on. He's also debating switching to a Ford rear. He uses uses a 3 link front and rear which so I see no issues with your front. He's also running 14" travel ori's. Also I can't remember where he got his gears? But he's at 15k with no issues and the 5.38s were only like $200 sorry for the rambling, Im bit excited to see this
Unread 02-11-2014, 05:03 PM   #117
Randonexplosion
Trailer Queen
Damn, It's on now. Do you think the rear 60 is up to handling 40s? I've seen quite a few guys say that it isnt all that strong and you should go with a 14 bolt...
5.3/4l60e swap
August YJOTM
Unread 02-11-2014, 05:12 PM   #118
Maertz
2009 JK Wrangler
dodges may have tone rings already in them, thatd be a plus, but im not sure yet. as for the brakes that no big deal and costs about 30 bucks for the bracket. i wont have any clearance issues unless i tried a double tri front. I will have to have the front 3 link onthe passenger side though. Im going to try and fit 16" coilovers in this. I will have alot of welding cutting to do and will have to get a fuel cell also. If i spend over 5-6k to start ill **** a brick. No way i will go near 15k.
as for the 60 being stong enough i worried also. All the buggies here beat on them with 40s and 42s and have no problems, but they have buggies not a fat *** jk. Im hoping its fine once i get chromo shafts. I debated a 14b but this was a good deal and I dont have to go pull one. Also on a 14b id want 42s to help clearance the dif size difference. I dont want to mess with shaving it on my first bit axle swap/jeep build. I am still contemplating just running 37s or 38s also, not sure on that yet though.
Unread 02-11-2014, 05:13 PM   #119
awinski
young & dumb
awinski's Avatar
He's from Virginia, used to do some major mud bogging including owning two deuce and a halfs and now is a supervisor at sikorsky. He's only running 30 spline for now and has no worries. He also beats on his rig pretty badly. He isn't on here because he was hounded for not running 35 spline. I think his entire build is on JK owners. But not sure. He's also on instagram. If you ask me he knows what he's doing. He said he'd go to a 14 bolt or d80, but only after a 5.3 vortec swap. Sorry thought I was replying to maertz lol
Unread 02-11-2014, 05:15 PM   #120
awinski
young & dumb
awinski's Avatar
Seems solid. His only regret is not going 16"
