Maertz's Half *** Build Thread - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Maertz's Half *** Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 12-06-2013, 05:35 PM   #31
Maertz
2009 JK Wrangler
Thanks 1222! N randon his gas tank failed so now hes got that project to.. Hes running off his 2 jerry cans using airhose lol
Wishing I Wasn't Part Of The 'JK' Crowd...
[URL="http://www.jeepforum.com/forum/f96/maertzs-half-build-thread-1857370/"]A JK On Junkyard 60s[/URL]
Maertz is offline   Reply With Quote Quick reply to this message
Unread 12-06-2013, 07:18 PM   #32
Randonexplosion
Randonexplosion's Avatar
I have a tank... too bad I'm 4 hours away. Let him know. I'll ship it on his dime.
5.3/4 link build
2016 Moab Trip
Randonexplosion is offline   Reply With Quote Quick reply to this message
Unread 12-06-2013, 11:56 PM   #33
Maertz
2009 JK Wrangler
Fixed My Shock Bolt
Put on the metalcloak rear track bar bracket and laughed....
Its obsurdly tall and my axle will be 2" off center until I get my damn rod ends in to finish my track bar...I wish that bracket wasnt so tall. I may have to cut it down and grind the sides for clearance. This looks to be a newer model as the older ones just had 2 bolt holes. This damn thing is like a 6.5" rear trackbar raise. Just stupid. If i can get it mounted in the next hole down itll be more like 3.5 wich will match my front better. Its so high i might not even have to bend my track bar if i leave it that high... Its an ok bracket, but kind of a pain for my set up. I have to remove shock and control arm and whole track bar just to get it in.
Unread 12-07-2013, 10:00 AM   #34
awinski
Originally Posted by Maertz View Post
Fixed My Shock Bolt
Weird that they would make it that tall when they only offer a 3.5" lift
The ONLY chlorophyll JK
one more horse power than the average pentastar; [URL="http://www.jeepforum.com/forum/f22/plus-1-horse-power-after-build-2157673"]http://www.jeepforum.com/forum/f22/plus-1-horse-power-after-build-2157673[/URL]
twitter/IG - @Becauseracejeep
awinski is offline   Reply With Quote Quick reply to this message
Unread 12-07-2013, 10:05 AM   #35
Maertz
2009 JK Wrangler
Agreed. The one plus is if im ever stranded somewhere I can put my cell phone by it and probably get a signal lol.
Unread 12-07-2013, 10:25 AM   #36
awinski
Hahaha
Unread 12-07-2013, 04:46 PM   #37
Maertz
2009 JK Wrangler
Well threw the jeep on the forklift to get a half *** idea if it would hit with this Eiffel tower in the back. Its damn close, but it just might clear at full stuff.. I may need to cut out the old shock mount location in the worst case scenario.
No damn clue why its about 6.5" up though. im still not sure I want to run it that high as my fronts only raised 3.5"... I also cant use the second hole down due to the crap design of this.. I feel it would be come pretty weak cutting it up enough to get it to fit. That second hole would be ideal. My track bar will be damn near level in the top hole....Would make the track bar simple though with no bends possibly.
Side note, best radio reception ever...
Unread 12-07-2013, 07:05 PM   #38
STORM_JK
Haha sweet and entertaining build man! Love the fab work
'13 JK 6-spd | 3.5" RK | 35" MTR/K | Lots Of Welding
STORM_JK is offline   Reply With Quote Quick reply to this message
Unread 12-07-2013, 07:44 PM   #39
Tanimal
Read the whole thing and really enjoyed it. Looking forward to what comes next !
[URL="http://www.jeepforum.com/forum/f96/tanimals-2008-2d-jk-build-thread-1397184/"][COLOR="Blue"][B]-=-CLICK HERE FOR MY JK BUILD THREAD-=-[/B][/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f11/tomimal-tanimals-1993-cherokee-country-build-thread-1440379/"][COLOR="GREEN"][B]-=-CLICK HERE FOR MY XJ BUILD THREAD-=-[/B][/COLOR][/URL]
[B][I]Learning as I go and it's worth every penny![/I][/B]
Tanimal is offline   Reply With Quote Quick reply to this message
Unread 12-09-2013, 08:09 AM   #40
Maertz
2009 JK Wrangler
Thanks man. Should be getting my rod ends and bungs so hopefully this weekend I can make the rear track bar. Im going to try and make it straight if at all possible.
Unread 12-16-2013, 08:49 PM   #41
Maertz
2009 JK Wrangler
Well track bar is almost ready to get welded and tested out.
Hopefully this weekend I can see if it will hit anything.
Also played around with my suspension geometry slightly.
On my rig with the mc bracket in the rear raising it 6.5" (wich barely hits my frame on uptravel) and the front raised 3.0" (synergy kit) my roll centers are 22.3" rear and 22" front. That seems fine imo. Slight understeer, but nothing major. I need to work on the rear antisquat a tad bit though, but its hard to figure out the exact sprung mass cg. I might call it good. To fix it though i would have to raise my rear lower arms, at the same time I would raise the shock mounts. It would only gain about 1" Clearance on the arms and maybe 1/2 on the shocks... The more i look at there bracket its a good setup.
Unread 12-16-2013, 08:53 PM   #42
Randonexplosion
Make sure that **** is ready for New Years. My junk still smells faintly of gasoline. ..
5.3/4 link build
2016 Moab Trip
Unread 12-16-2013, 08:59 PM   #43
Maertz
2009 JK Wrangler
What weekend we going i think Sunday the 5th i have to leave for ABQ? And ha i believe it. That thing was a purebred fumeinator.
Unread 12-16-2013, 09:01 PM   #44
Randonexplosion
Saturday the 4th
5.3/4 link build
2016 Moab Trip
Unread 12-16-2013, 09:04 PM   #45
Maertz
2009 JK Wrangler
Saturday the 4th
ait. I think rambos in but u better check. You just coming up for that saturday?
