-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Maertz's Half *** Build Thread (http://www.jeepforum.com/forum/f96/maertzs-half-build-thread-1857370/)
Maertz 12-04-2013 03:40 PM
Figured I should finally work on getting some basic info on my build up on here. It will take awhile to get it all updated, but will keep working on it. This was my first jeep, and I learned from many of my mistakes. Rambo in the yj section also helped me a ton in the later steps of this build.
This is Where i started out...
http://i772.photobucket.com/albums/y..._2583605_o.jpg
First thing I added was a Bestop Narrow Bumper. I belined it to match the rear bumper I had gotten as the front one was glossy.
http://i772.photobucket.com/albums/y..._6103498_o.jpg
I then added these pos rampage side steps. At first didnt think I would ever get to extreme and they really helped the short girlfriend get in...Still a waste on these.
http://i772.photobucket.com/albums/y..._2560349_o.jpg
Another wasted add on here was the Airraid cai I installed. I was a sucker for thinking i needed this at the time...
http://i772.photobucket.com/albums/y..._4622908_o.jpg
Next on the list was a rear bumper. I went with a ****tybilt tubular for some stupid reason. At the time id say it probably had to do with how inexpensive they were.
http://i772.photobucket.com/albums/y..._7318240_n.jpg
I also had installed crappy utility lights...
http://i772.photobucket.com/albums/y..._2981144_o.jpg
Maertz 12-04-2013 03:46 PM
Next i added a Magnaflow Cat back exhaust. Again more wasted money as this thing sounded like *** and was just waiting to get beat on.
http://i772.photobucket.com/albums/y..._2025006_o.jpg
Next I added some rims. Im a sucker for black on white look.... These have gotten beat to crap over time, but held up fine. I wish I would have went steel so I could have welded on bead lock rings later though. O well, there only 8" wide so there technically poor mans bead locks.
http://i772.photobucket.com/albums/y..._5246448_o.jpg
Seen as i like to wheel alone when I was in Wisconsin i figured i would put on a winch. I got the xrc 8. This thing has been through alot and never let me down. If i were to do it again I would have just gotten a 10k.
http://i772.photobucket.com/albums/y..._6552293_o.jpg
The new rims gave it a slightly wider stance...
http://i772.photobucket.com/albums/y..._2635565_o.jpg
Next on my list was to ditch the carpeting as my dog has white hair and it was annoying as all hell. I bedlined everything. I used rustoleum bed liner. Its held up very well. I also chiseled out all of the sound foam stuff.
http://i772.photobucket.com/albums/y..._4437010_o.jpg
http://i772.photobucket.com/albums/y..._6281185_o.jpg
http://i772.photobucket.com/albums/y..._6763675_o.jpg
Maertz 12-04-2013 03:59 PM
Got to test all of this out briefly. At this point I probably had no idea what a sway bar disco was if I had to guess looks like its still connected...
http://i772.photobucket.com/albums/y..._3052598_o.jpg
http://i772.photobucket.com/albums/y..._3210666_o.jpg
After that I installed a zone offroad 3" lift. Yet another waste of money, but at the time it served me just fine. At the same time I installed some 35" Mud Grapplers and a Dual Steering Stabalizer. I also installed synergy 1.75" wheel spacers.
http://i772.photobucket.com/albums/y...88926744_n.jpg
I also chopped the fenders down.
http://i772.photobucket.com/albums/y...29904034_n.jpg
Next up was some coast 1310 drive shafts.
http://i772.photobucket.com/albums/y...31845542_o.jpg
I clearly didnt have this correctly. ALso over greased the hell out of it.
http://i772.photobucket.com/albums/y...39814511_o.jpg
Also added a cb and antenna. And the ****tybilt oversize tire carrier.
http://i772.photobucket.com/albums/y...59244309_o.jpg
My next up was to finally adress some of the strength issues.
http://i772.photobucket.com/albums/y...20043024_o.jpg
Maertz 12-04-2013 04:06 PM
Again as i love the black on white look I painted the riddler dif covers.
http://i772.photobucket.com/albums/y...36979649_o.jpg
They installed easily.
http://i772.photobucket.com/albums/y...04797043_o.jpg
Also installed were the gussets,sleeves,gears.
http://i772.photobucket.com/albums/y...51628166_o.jpg
I then removed my stock reverse light bulbs and cut out the housing a little to fit in the wall-mart rock lights.
http://i772.photobucket.com/albums/y...90190092_o.jpg
Got some more time to test the lift and all the others installed.
http://i772.photobucket.com/albums/y...69251318_o.jpg
http://i772.photobucket.com/albums/y...08061782_o.jpg
http://i772.photobucket.com/albums/y...00005202_o.jpg
http://i772.photobucket.com/albums/y...12098034_o.jpg
http://i772.photobucket.com/albums/y...ps73b28ecd.jpg
Maertz 12-04-2013 04:14 PM
I opted to remove the cai and utility lights i had on and installed some ebay led lights and lightbar. I also Installed a chinese replica snorkel... Go ahead flame away.
http://i772.photobucket.com/albums/y...psa78885ca.jpg
Installed some basic tailight guards..
http://i772.photobucket.com/albums/y...psee21727c.jpg
Next i removed the magnaflow exhaust and installed an MBRP offroad exhaust. Much happier with this one.
http://i772.photobucket.com/albums/y...ps11365059.jpg
Also installed a poison spyder evap skid while i was there.
http://i772.photobucket.com/albums/y...psf951f07b.jpg
Next I ditched the ****tbilt rear tubular for an eautogrilles swing out tire carrier. This thing has been beat on pretty good and I have no complaints at all. Sure the coating got its *** kicked and it got dinged a little on rocks, but all in all i was happy.
http://i772.photobucket.com/albums/y...ps665d275f.jpg
Mounted my hi-lift to it by drilling 2 holes and putting 2 bolts thru them..
http://i772.photobucket.com/albums/y...ps04db287d.jpg
I then bought a hitch cargo rack from harbor freight for like 75 dollars and cut it up a little.
http://i772.photobucket.com/albums/y...psaa944a7a.jpg
Grinded my swing out bumper to prepare it for the cargo carrier.
http://i772.photobucket.com/albums/y...psb2963bec.jpg
And walla.
http://i772.photobucket.com/albums/y...ps40f78243.jpg
http://i772.photobucket.com/albums/y...ps5f353311.jpg
Maertz 12-04-2013 04:18 PM
That was about it in Wisconsin, I then packed up and for some reason moved to Albuquerque New Mexico...
http://i772.photobucket.com/albums/y...50528346_o.jpg
http://i772.photobucket.com/albums/y...63769179_o.jpg
Once I got here and got to experience he new type of wheeling to do, alot of my build plan changed.
http://i772.photobucket.com/albums/y...psf275adfc.jpg
http://i772.photobucket.com/albums/y...ps77280929.jpg
http://i772.photobucket.com/albums/y...ps97cc7fc4.jpg
Now comes alot more of the fun stuff...
ROCKR8R 12-04-2013 04:21 PM
Have you since replaced the Zone kit? Dual steering stabilizer qualify as a waste of money too? :)
Nice, build. How most of us learn, trial and error.
-Dan
Maertz 12-04-2013 04:29 PM
-Dan
Yes i now have custom built my whole lift now except the springs and shocks. And yes dual ss was a waste I now run no steering stabilizer.
Maertz 12-04-2013 04:37 PM
Next was a real quick basic install of some hood louvers as its hot as hell down here.
http://i772.photobucket.com/albums/y...psb46b34ab.jpg
http://i772.photobucket.com/albums/y...ps72618643.jpg
My stock bjs were about shot at this point having about 1/4 of play. So i swapped them with some synergy ones. Prolly used way more tools then needed.
http://i772.photobucket.com/albums/y...98090533_o.jpg
This was my bj press. Id recommended anyone else doing this to just get the tool...
http://i772.photobucket.com/albums/y...73408780_o.jpg
Got tired of driving a few miles to air up so I installed a 5 gallon tank.
http://i772.photobucket.com/albums/y...66033022_o.jpg
I installed the dual viair 444cs here.
http://i772.photobucket.com/albums/y...47158363_o.jpg
Next up i did the rubi locker modification as the stock set up really annoyed me.
http://i772.photobucket.com/albums/y...psa3b597f6.jpg
Also moved the winch controller into my dash.
http://i772.photobucket.com/albums/y...ps6f55cde0.jpg
Somewhere I bent my rear axle flanges so I installed some chromolys.
http://i772.photobucket.com/albums/y...56929699_o.jpg
Maertz 12-04-2013 04:47 PM
Got tired of the short wheel base and no good control arms. Started making my own. I used 1-1/2od x .250 wall dom tubing. The rest of the bungs and rod ends I got from Ballistic Fab.
http://i772.photobucket.com/albums/y...ps32d2edc3.jpg
http://i772.photobucket.com/albums/y...psb6a1aa1f.jpg
http://i772.photobucket.com/albums/y...47535313_o.jpg
http://i772.photobucket.com/albums/y...15715164_o.jpg
The front I ran into and issue because the axle mounts have massive bushings. Every other arm I could just drill out to 5/8 Bolts, not these. I had to reuse the stock end. So cut it off and weld it to the dom tubing I had.
http://i772.photobucket.com/albums/y...37994229_o.jpg
Got the rear arms in and it will be pushing the axle back about 4" You can see where i will have to trim.
http://i772.photobucket.com/albums/y...ps3bd40e60.jpg
http://i772.photobucket.com/albums/y...ps3eb88513.jpg
Here is the rear stretched and cut out. I dont have pictures, but I also had to move the coil mounts and trackbar. Track bar bracket I got was a ballistic fab weld together bracket. Not really for this application but it worked great. The coild mounts I welded to the axle using 1/4 flat stock for the Flat part and gussets.
http://i772.photobucket.com/albums/y...pse6cea7ab.jpg
I got new shocks at this point some 12.5" travel shocks. With the stretch I had to move the rear sway bar and track bar. I also had to move the shock mounts. I welded a square tube that perfectly fit down to the frame and added tabs.
http://i772.photobucket.com/albums/y...ps4093de03.jpg
Heres a better pic of where it fits.
http://i772.photobucket.com/albums/y...ps781a2cca.jpg
Maertz 12-04-2013 04:56 PM
The front was also stretched about 1" but you cant really notice it to much. I should have went more...
http://i772.photobucket.com/albums/y...74220353_o.jpg
Next up was a drag link. This was pretty straight forward...
http://i772.photobucket.com/albums/y...30016452_o.jpg
At the same time i flipped it to the top of the knuckle and added a synergy track bar mount.
http://i772.photobucket.com/albums/y...ps8fabaa5c.jpg
As you can see the pos dual ss is always getting hit so I removed it. Also fyi the drag link flip can be done safely on 2.5" on my rig. Everyone claims 3", but 2.5 is plenty safe.
Next up was a track bar and tie rod.
http://i772.photobucket.com/albums/y...psb2e0dfeb.jpg
http://i772.photobucket.com/albums/y...psb9f5cd00.jpg
The 1.5"od x 1/4 wall tie rod got bent to **** the first trip...
http://i772.photobucket.com/albums/y...ps2bcd9340.jpg
I also made a rookie mistake and made the rod ends have mo alignment... This is what i got next.
http://i772.photobucket.com/albums/y...pse840c130.jpg
So I upgraded to 1.75 od by 1/4... So far much better. Also used misalignment.
http://i772.photobucket.com/albums/y...ps4b09daca.jpg
Heres everything installed.
http://i772.photobucket.com/albums/y...pse2be267a.jpg
Tested out the new shocks, and RK 3.5 coils.
http://i772.photobucket.com/albums/y...ps69f81b4a.jpg
http://i772.photobucket.com/albums/y...ps42f180c0.jpg
Worked out ok. But my shock was rubbing the frame, had to move the lower mount out a little. Also contrary to what most say the rear sway bar does limit the flex about 3" in my tests. I removed the front sway bar as its useless. Keeping the rear is plenty.
Maertz 12-04-2013 05:06 PM
Did a little bit of trail riding...
http://i772.photobucket.com/albums/y...ps90cda298.jpg
http://i772.photobucket.com/albums/y...ps0d560fac.jpg
http://i772.photobucket.com/albums/y...ps7af36e7a.jpg
http://i772.photobucket.com/albums/y...ps1e7cdb99.jpg
Then we took a pretty intense trail and this happened...
http://i772.photobucket.com/albums/y...psfa98ea04.jpg
Heres a closer look.
http://i772.photobucket.com/albums/y...psfc71938f.jpg
It also almost took out my bj.
http://i772.photobucket.com/albums/y...pse4817b47.jpg
We just pulled the shaft and drove home. I ordered up some alloy usa chromolys and havent had another problem....yet.
Learned the hard way on a few g5 bolts. So i swapped everything to grade 8.
http://i772.photobucket.com/albums/y...pse197a49c.jpg
http://i772.photobucket.com/albums/y...ps99efae4f.jpg
Few more carnage pics...
http://i772.photobucket.com/albums/y...psd90aeffb.jpg
http://i772.photobucket.com/albums/y...psaf0c8dcd.jpg
http://i772.photobucket.com/albums/y...ps508c0a60.jpg
http://i772.photobucket.com/albums/y...ps422e5365.jpg
Had some issues with the rear coils coming out. So I had to make some coil retainers top and bottom...
http://i772.photobucket.com/albums/y...psea295e98.jpg
Some more wheeling and measurements...Testing clearance.
http://i772.photobucket.com/albums/y...ps4fe86131.jpg
http://i772.photobucket.com/albums/y...ps10089209.jpg
http://i772.photobucket.com/albums/y...ps04910dee.jpg
http://i772.photobucket.com/albums/y...psb9884029.jpg
I have since moved to Farmington and havent done much since. Except Explore.
http://i772.photobucket.com/albums/y...ps072709c7.jpg
http://i772.photobucket.com/albums/y...ps6e63a75c.jpg
http://i772.photobucket.com/albums/y...ps7923d8e3.jpg
http://i772.photobucket.com/albums/y...ps7f6629cd.jpg
http://i772.photobucket.com/albums/y...ps5760d18d.jpg
I will however be getting a metalcloak rear trackbar brace, so I will be installing that and making a rear track bar as well. SO that will be coming up soon. Heres a quick mock up.
http://i772.photobucket.com/albums/y...psbe0fd968.jpg
Well thats my super quick recap. Im sure I missed a ton of stuff and I know i didnt go into much detail, I always forget to take pics...Slowly getting better...Ive learned tons just in this project alone...The whole time in albuquerque we were also working on this guys build. http://www.jeepforum.com/forum/f22/m...41/index6.html
Hes the one who helped do all of the welding.
BlkOpsRubi 12-04-2013 05:16 PM
Great build; and thank you for documenting what you have. I've learned so much by reading build threads, understanding the logic and decision making process for mods, and respecting those that go to the trouble to take pictures and write it down. :thumbsup:
BTW ... the wheeling pictures are just awesome!
Maertz 12-04-2013 05:24 PM
Thanks man looking back i still would have done stuff differently and documented way more. But all in all im happy!
When i get more time ill try and go into more detail.
ROCKR8R 12-05-2013 09:08 AM
So when are tons and coil overs?
-Dan
The time now is 11:52 PM.
