Made my own mirror brackets! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Made my own mirror brackets!
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 08-13-2007, 04:21 PM   #1
dironrules
Hey all! I just got done building mirror brackets for the ol' jeep. I didn't much care for what's on the market so I brainstormed and came up with this.
It's removable with the small hitch pin. This is the bracket that stays on whill you store the mirror. It doe not get iin the way of the dor at all.
The mirror inserts the bracket and around the bolts. (I used the existing hardware)
dironrules is offline   Reply With Quote
Unread 08-13-2007, 04:33 PM   #2
dironrules
Boy. Only one beer and I'm already spelling words wrong! Sorry.
Also, can someone post them again without the links.....clicking sucks.
Unread 08-13-2007, 04:56 PM   #3
YellowSport
Paint them black
'01 Yellow TJ Sport Lifted
'91 White XJ Limited, Rustys 3" For sale
'07 4dr JK Red Rock sitting on 35's
'98 Cobra Vert #1558 Supercharged
YellowSport is offline   Reply With Quote
Unread 08-13-2007, 04:58 PM   #4
N2rock
N2rock's Avatar
Wow- you do nice work.
I'm with Yellowsport- paint them black
N2rock is offline   Reply With Quote
Unread 08-13-2007, 05:32 PM   #5
dironrules
Thanks! ...as for paint, I've heard the same from most who see it. I'm still working out any kinks in the design before I do , though.
Unread 08-13-2007, 06:06 PM   #6
scrogg
It looks pretty good and I like easily removable part of the design. Definitley agree with needing to be painted, but as you stated you plan on it. I am curious as to how much do they vibrate while driving?
scrogg is offline   Reply With Quote
Unread 08-13-2007, 06:14 PM   #7
dironrules
None. The aluminum tube is 1 inch. The flat elbows fit PERFECTLY inside. I actually used 9 or 10 brackets and just cut them at the elbow. Then mark and drill. Once in the sleve they form a tight (but not too tight) connection. I would have probably machined a piece of nylon for the spacer between the two down posts but, This works fine for a start.
Unread 08-13-2007, 10:10 PM   #8
JayDLT
click free
WILL WORK FOR JEEP PARTS!!
JayDLT is offline   Reply With Quote
Unread 08-13-2007, 10:57 PM   #9
aremee
I took one of the bolts out of the windshield mount, went to the local Home Depot got the same size bolt.The went to the Autozone for cheapo mirror. Welded a nut onto the bolt so I can screw it into the windshield mount and then connected the cheapo mirror to the bolt. Total Price under $10. Works great will post some picks
aremee is offline   Reply With Quote
