Lower Switch Panel Electrical Issue - JeepForum.com
post #1 of 2 Old 08-20-2009, 04:16 PM Thread Starter
JMW1191
2009 JK Wrangler
I am having an electrical issue with my 09' JK Rubicon Unlimited and the problem is the lower switch panel with the sway bar disconnect, lockers, hazards, and esp off switches is not working as well as the interior lighting. What could be my issue? I checked the fuse and it was blown but every fuse i put in blows out instantly. I took it to the dealership and they wont claim it under warranty because i have a bunch of aftermarket parts on it. I have 4 hella black magics, and then the delta factory replacement fog lights. I had 4 wheel parts install these lights. Im having trouble finding where the problem is... any ideas? Anything that could help me?
JMW1191 is offline
post #2 of 2 Old 08-20-2009, 04:27 PM
Prot
Prot's Avatar
2014 JK Wrangler
Go back to 4 wheel parts and get them to fix what they screwed up. I suspect they did not use relays. Also, putting more powerful bulbs in the factory fog lights is known to make the computer freak out because you are drawing too much current. The JK makes extensive use of the CANBUS system. If you want a more powerful bulb in your factory fog lights, the way to go is to with a relay. I really don't fault the dealer, because a modification was made to your electrical system that caused a malfunction. 4 Wheel Parts should take care of the problem if you bring it to them.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 09:21 PM
Custom Build: JK Electrical Panel waterboarder JK Wrangler Technical Forum 31 08-10-2009 09:44 AM
Instrument Panel Lighting & Trailer Electrical... JohnChrist YJ Wrangler Technical Forum 2 09-07-2006 08:07 PM
Instrument Panel Lighting & Trailer Electrical... JohnChrist YJ Wrangler Technical Forum 7 09-07-2006 08:28 AM
Convert vacuum switch t-case to electrical switch halfline YJ Wrangler Technical Forum 8 09-11-2004 06:24 AM
